Bob Perkins | 01/12/2012 19:32:17 |
249 forum posts 60 photos | Hi all Does anybody have a copy of a user manual/instructions for a 100mm SOBA rotary table they can share? thanks Bob |
Les Jones 1 | 01/12/2012 19:56:29 |
2292 forum posts 159 photos |
Hi Bob, Les |
chris j | 01/12/2012 19:56:31 |
338 forum posts 17 photos |
Worth a try
dcosta | 01/12/2012 20:24:49 |
496 forum posts 207 photos |
Hello Bob! Edited By dcosta on 01/12/2012 20:34:36 |
Bob Perkins | 01/12/2012 20:39:32 |
249 forum posts 60 photos | Thanks Les I have this and there is some useful and interesting info in this. Thanks Chris I tried this earlier today and couldn't get the download to work. Perhaps it's an iPad thing, I'll try on the pc later. Thanks Dias. An email to [email protected] would be great. Thanks all Bob
Michael Gilligan | 02/12/2012 10:18:33 |
![]() 23121 forum posts 1360 photos |
Posted by Les Jones 1 on 01/12/2012 19:56:29:
Hi Bob, Les
A very useful document, thank you Les MichaelG. |
GaryM | 02/12/2012 16:31:16 |
![]() 314 forum posts 44 photos |
Hi Bob, Les The document Les linked to is on LittleMachineShops web site here:- HTH Gary |
Stub Mandrel | 02/12/2012 18:13:30 |
![]() 4318 forum posts 291 photos 1 articles | The document Les found is really excellent, but note that it is for a table with a 72:1 (5 degrees per turn) worm. This is unusual as most are 60:1 (6 degrees) or 40:1 (9 degrees) - be aware you will probably need to allow for this. I am inspired to make a larger index wheel for my table with rather more divisions (although 180 to get the same 2 second divisions seems a bit of a challenge!) Neil |
Michael Gilligan | 02/12/2012 20:23:02 |
![]() 23121 forum posts 1360 photos | Note: It's worth going back up to a higher level on their website ... Lots of useful info. !! MichaelG. |
Brian in OZ | 02/12/2012 21:41:20 |
63 forum posts | Hello "Bob Perkins", The file is there but as Dcosta pointed out be very carefull as the site will try and download some other software to your PC. When it leaves you at the "download" screen simply use your browser to back-up (go backwards) one screen and you will find one of those little boxes to fill in a code, do this and "submit" then a couple of lines above you will seee PDF you are after, simply "right click" it and save, is a good file. Also thanks to Michael, the PDF you made available is really good Regards Brian in OZ |
Bob Perkins | 02/12/2012 21:45:19 |
249 forum posts 60 photos | Hi Brian I caught on to that when I looked at the site earlier. It tries to download some type of media player\reader. Thanks Bob
Brian in OZ | 02/12/2012 22:06:13 |
63 forum posts | Hi Bob, Yes it is one of those sneaky sites, in fact I just checked out the file I downloaded and found it to be corrupted so can't open it. Deleted it and hope I did not get any other "junk" with it, might go back later and figure out what happened, in the meantime I'll do a Google and see if the manual is available elsewhere. Brian |
dcosta | 02/12/2012 22:47:20 |
Hello Bob Perkins! Edited By dcosta on 02/12/2012 22:47:40 |
Andrew Johnston | 02/12/2012 23:05:02 |
![]() 7061 forum posts 719 photos |
Posted by Stub Mandrel on 02/12/2012 18:13:30:
Oeeeer, I think my rotary table is 90:1, ie, 4° per turn of the handle - Andrew |
Michael Gilligan | 03/12/2012 06:57:32 |
Posted by Andrew Johnston on 02/12/2012 23:05:02:
40:1, 60:1, 72:1, 90:1 are all fairly common, and are all "good" ratios for the job, because they have some useful factors. [Although, of course, 40 lacks 3; which must therefore be accommodated elsewhere in the system.] They are all also factors of 360; which simplifies dividing into "degrees". MichaelG.
P.S. If adding a Stepper Motor to a 40:1 table, it's worth considering a 48-step motor instead of the now common 200-step ... so as to introduce the factor 3.
Bob Perkins | 03/12/2012 07:09:47 |
249 forum posts 60 photos | Hi Dias No email yet. Please try again. I'll send back a thank you message to confirm when it arrives. Thanks Bob..
Michael Gilligan | 03/12/2012 07:13:15 |
Posted by Brian in OZ on 02/12/2012 22:06:13:
Bob / Brian I didn't like the look of that site either. Here is a direct link to six more pages on the LittleMachineShop site. MichaelG. |
Bob Perkins | 03/12/2012 14:02:27 |
249 forum posts 60 photos | Thanks all I now have loads of info to look at, including a guide for the SOBA table. Regards Bob |
John Hinkley | 07/12/2012 18:28:43 |
![]() 1545 forum posts 484 photos | Now that it looks like you have the answer - can I hi-jack your thread? Some while ago,I bought a 4" rotary table from a UK supplier, but never got around to using it! Now that it's out of guarantee, I've dug it out and tried it. It seems to have been manufactured using a revolutionary elliptical worm gear, in that it has a couple of tight spots when turning a full circle. I'll try to sort it when I have more time. However, my question to you, Bob, is, assuming you've got one, how good is the Soba one? I've arrived in the UK today and was intending to go to Chronos in Dunstable, on Monday, to pick up one with tailstock and dividing plates. Don't want to spend all that money and have a wasted journey if they are of dubious quality! John
Bob Perkins | 07/12/2012 19:25:30 |
249 forum posts 60 photos | Hi John I'm really pleased with mine. The quality for the price is good value. I haven't used the index plates or the tail stock yet as I've only had it a few weeks. I've only used it a couple of times to mill 4 slots at 90 degrees to each other. The movement is smooth with no tight spots. I think Cronus supply theirs with a user manual, if not I have a PDF thaks to Dias. Happy shopping regards Bob.. |
