SverreE | 28/11/2012 07:17:12 |
22 forum posts 14 photos |
Professional machine worklights tends to be very expensive for the home workshop. Now, LED-lamps can be a very good alternative, like this lamp I found at Ikea in Norway. It is called "Jansjo" and costs £10 in the UK. The advantage with this lamp - apart from the low cost, is that it is a a low-voltage lamp (6 V, 3W I think, safe voltage for swarf) and its long flexible gooseneck. Here is how I mounted it on my milling machine: And here a view of how strong the light is with two of these lamps: I think I will fit my lathe with a lamp or two! Regards Sverre |
modeng2000 | 28/11/2012 07:21:16 |
340 forum posts 1 photos | Sverre, I use them on my lathe and mill. They are good as they are not too large and don't get in the way and at the same time bright enough to give a good working light. John |
Geoff Theasby | 28/11/2012 08:30:02 |
615 forum posts 21 photos | Look for an article on this subject in MEW 200. Mains operated, clip-on, many types of bulb. Regards Geoff |
SverreE | 28/11/2012 08:55:03 |
22 forum posts 14 photos | Geoff - MEW 200? The last issue out now is MEW 197.... Sverre |
Geoff Theasby | 28/11/2012 10:02:24 |
615 forum posts 21 photos | Yes, Sverre, David Clark accepted an article from me on this subject, and said it would appear in MEW 200, the special issue. Regards Geoff |
David Clark 1 | 28/11/2012 10:06:39 |
![]() 3357 forum posts 112 photos 10 articles | Hi There Yes, issue 200. All scheduled in. We are working ahead because of Christmas. Currently scheduling articles into MEW 201 but really I should be working on MEW 202 schedule now. regards David |
Andrew Johnston | 28/11/2012 11:13:50 |
![]() 7061 forum posts 719 photos | They'd better live up to expecations, because I've just ordered three of them! One for the lathe, one for the vertical mill and one for general use. The lathe does have an industrial low voltage (25V) light on it, but I gave up using it because it eats bulbs, and they're not cheap. Andrew |
ChrisH | 28/11/2012 11:21:54 |
1023 forum posts 30 photos | Hi SverreE, I recommended these lamps from Ikea back in March in the thread 'Workshop Lighting'. I have the one with a base for my mill, and the clip-on one for my lathe. I think they are excellent value for money and provided a very good degree illumination right where you want it, with the bulb bit being so small it doesn't get in the way. I would still recommend them! Chris |
Bazyle | 28/11/2012 11:46:51 |
![]() 6956 forum posts 229 photos | Any suggestions for converting regular worklight? google quickly comes up with GU10. Is that suitable. (voltage conversion obviously) Might actually bother with an xmas sale to look for a triffid light as I don't have an IKEA around. |
Les Jones 1 | 28/11/2012 16:20:53 |
2292 forum posts 159 photos |
Hi all, Les. |
Another JohnS | 28/11/2012 16:34:59 |
842 forum posts 56 photos | As one of our workshop people here said: You get a great little light, AND if you permanently mount the light, you get a hunk of cast iron from the base, too! Certainly much better than CFLs or incandescents. Another JohnS. |
Bazyle | 28/11/2012 18:38:12 |
![]() 6956 forum posts 229 photos | Les, thanks for that - I thought the GU10 must be the size designation for one of those 12v downlighters. I was thinking of the traditional 24v rather solid machine lights as I have 3 machines with them but no bulbs as Andrew mentioned above. Seems a pity to scrap the housing if it was possible to do a simple LED conversion with a different transformer and LED bulb. |
Stub Mandrel | 28/11/2012 19:36:03 |
![]() 4318 forum posts 291 photos 1 articles | Probably cheaper to by cheap and cheerful powerful LED torches and take the LEDs and drivers out of them than to go to the bother of buying the bits from Farnell or RS. They ought to be fittable to most types of housing. There was one in Machine Mart for about £7 last week. Neil |
Les Jones 1 | 28/11/2012 20:33:09 |
Hi Neil, Bazyle, You could use the 12 volt MR16 spot lights if you changed the transformer. Some of the £ shops have down light fitting which is the cheapest way to get the holders. Les. |
Michael Gilligan | 28/11/2012 20:55:57 |
![]() 23121 forum posts 1360 photos |
Posted by John Alexander Stewart on 28/11/2012 16:34:59:
John, For info ... At least in recent models; the insert in the base appears to be some sort of Iron-loaded Rubber, not actual Cast Iron. MichaelG. |
Stub Mandrel | 28/11/2012 21:33:08 |
![]() 4318 forum posts 291 photos 1 articles | Hi Les, I was suggesting them as a source for replacing traditional bulbs in existing mountings. My stepson has found some very good torches on fleabay. neil |
GaryM | 28/11/2012 22:26:41 |
![]() 314 forum posts 44 photos | For info GU10 refers to the base connector style of the lamp. HTH Gary
Michael Gilligan | 28/11/2012 22:49:09 |
Posted by Gary Marland on 28/11/2012 22:26:41:
Please also be aware that GU10 bulbs are Mains Voltage The light source itself may be LED, or whatever ... but the terminals are Mains Voltage. Useful list here MichaelG.
Edited By Michael Gilligan on 28/11/2012 22:50:46 |
merlin | 29/11/2012 00:32:31 |
141 forum posts 1 photos | At £10 these Janso low-voltage lights are what I have been searching for for years. Ikea's website reads as though I can't order, and have delivered, via the internet in the nomal way. There is a basic charge of £15 within the branch delivery area, or have I misunderstood?
merlin | 29/11/2012 01:57:27 |
141 forum posts 1 photos | My apologies: Ikea do deal with internet orders in the usual way, but I didn't find it easy to register. Perhaps it is my fault - it often is these days. |
