Terryd | 21/11/2012 21:14:28 |
![]() 1946 forum posts 179 photos | H Folks, I need to shorten a vertical digital scale - i.e. digital readout bar, Can anyone suggest the best way of cutting it and what must I avoid doing to prevent damage. Thanks in advance Terry |
John Stevenson | 21/11/2012 21:51:33 |
![]() 5068 forum posts 3 photos | Wrap it with masking tape and slice it with a slitting wheel on the dremel or one of those thin 1mm cutting wheels. |
Les Jones 1 | 21/11/2012 22:59:59 |
2292 forum posts 159 photos |
Hi Terry, Les. |
I.M. OUTAHERE | 21/11/2012 23:48:55 |
1468 forum posts 3 photos | I cut two of mine with a hacksaw and had 0 problems . I would probably be worried about static build up using a grinder . Ian Edited By SLOTDRILLER on 21/11/2012 23:52:10 |
_Paul_ | 21/11/2012 23:59:37 |
![]() 543 forum posts 31 photos |
Posted by John Stevenson on 21/11/2012 21:51:33:
Wrap it with masking tape and slice it with a slitting wheel on the dremel or one of those thin 1mm cutting wheels. +1 These things are rather hard IMHO the Dremel makes a clean job of it. |
mark mc | 22/11/2012 07:47:31 |
92 forum posts 16 photos | When i had them i cut mine with a 6x4bandsaw, did a fine job. Not sure about the dremel tho, those disks can build up a far bit of heat the speeds they run at. |
Les Jones 1 | 22/11/2012 08:56:55 |
2292 forum posts 159 photos | Static would not be a problem as there are no electronic components on the PCB attached to the bar. Heat would be less of a problem using a Dremel than an angle grinder but care would still be required. I think the Dremel would give the cleanest cut. Using a saw could possibly tear the tracks on the end of the PCB causing them to short but this could easily be fixed with a sharp knife. Les. |
Stub Mandrel | 22/11/2012 21:31:50 |
![]() 4318 forum posts 291 photos 1 articles | I feel embarrased to admit I cut mine with a hacksaw. Neil |
I.M. OUTAHERE | 23/11/2012 01:56:54 |
1468 forum posts 3 photos | Why Neil ? Isn't that what Hacksaws are for ? Never been one for re - inventing the wheel as those i have seen always seem round enough for me ! Hacksaw did the job and the reader head is no where near the cut anyhow . Give it a clean up with a fine file and fit it . The static build up will not hurt the bar as stated there is no electronic components on it but could it jump to the reader head which has CMOS components ? Probably a long shot but if you have luck like mine it will happen sooner or later ! More important than cutting is getting the mounting set up right and you will find the pressed metal brackets supplied to be lacking . Make some from square alluminium bar stock on the mill and it will help . Once you have Digitized you will never go back !
Ian .
Stub Mandrel | 23/11/2012 16:56:56 |
![]() 4318 forum posts 291 photos 1 articles | Not mentioned so far are drive brackets for the head! I used 20 gauge brass, flexible enough to take minor misalignment but the plate shape stops any twist that could give a false reading. Neil |
