Graham Rounce | 17/11/2012 19:29:08 |
28 forum posts 2 photos | For my gyroscope project, I've obtained some metal rings (pipe "slices") about 6" diameter and say 1cm x 1cm in cross-section. (I've put a pic in my Album - is it visible?) Now they just need a little trueing up ![]() As I don't have the money or the room for a whole lathe, I was wondering... If I bolted just the carriage to my wood lathe, is there any reason why it shouldn't work? I'd have to adjust the feed position by moving the carriage manually and re-bolting, but the X and Y tool movement should be ok? Among my worries are ![]() Is there any point in even thinking about this? Thanks, |
NJH | 17/11/2012 20:21:04 |
![]() 2314 forum posts 139 photos | Hi Graham In principle it could work. You will need some secure way of holding the rings and a very much slower speed than is usually available on the wood lathe. Using a compound slide on a wood lathe is not a new idea see HERE It might be safer and quicker to seek the services of a friendly model engineer though! Good luck Norman |
Jeff Dayman | 17/11/2012 23:54:33 |
2356 forum posts 47 photos | The spindle speed on a wood lathe (usually 500-2500 rpm for hobby lathes) is far too high for metal cutting especially a large dia piece as you describe. Unless the cutting speed is about 150 surface feet per minute for steel, you will burn up the tools. A 6" diameter is 1.57 feet in circumference. At 150 sfpm this is around 95 rpm (slower than that will work too). JD |
Ian S C | 18/11/2012 10:37:10 |
![]() 7468 forum posts 230 photos | I'v got the "Popular Mechanics do it yourself Encyclopedia", and vol 13 has a build artical for a compound rest for a wood lathe. From what I can see at a glance, the only machine needed (you could proberbly do without), is a drill press. It does suggest a jack shaft to drop the speed to something usable for metal turning. It's one of many articals from the Popular Mechanics mag of the 1940s to the 1960s. Ian S C |
Terryd | 18/11/2012 13:16:15 |
![]() 1946 forum posts 179 photos | Hi ian, Do you have the original publication details for the article as the Popular Mechanics magazines are published on Google Books Regards Terry |
KWIL | 18/11/2012 13:19:13 |
3681 forum posts 70 photos | The Myford ML8 woodworking lathe used to have as an optional accessory, a compound slide. |
NJH | 18/11/2012 17:30:06 |
![]() 2314 forum posts 139 photos | Graham If you decide to persue the wood lathe option....... Does your lathe have the option for fitting a faceplate to the left hand end of the mandrel? If so you could fit this and make a handle from a piece of broomstick and screw this such that it is at right angles to the plate. Disconnect the drive belts and enlist the services of a willing (?) volunteer to wind the handle slowly, in the manner of a barrel organ operator, whilst you operate the tool slide. You will then have what many of us wish for - a variable speed drive for free! ( Although I guess it may have some hidden costs later in terms of favours or beers owed ) I still favour the path of finding a willing ME friend! Norman
Springbok | 19/11/2012 04:27:44 |
![]() 879 forum posts 34 photos | Graham
Where are you if in west country welcome to come and use my workshop |
Ian S C | 19/11/2012 11:42:17 |
![]() 7468 forum posts 230 photos | Terry, I'v got the "Popular Mechanics DIY Encyclopedia", my dad had it, so I just hung on to it as there are some useful bits in it. I imagine all this stuf is on line, under Popular Mechanics. The artical covers 6 pages, including 2 pages of drawings. Ian S C |
Graham Rounce | 21/11/2012 12:04:19 |
28 forum posts 2 photos | Sorry I've been absent, but thanks for all that info & suggestions (and the offer, Bob, but unfort I'm in Bethnal Green, London). I'll post pix (eventually) when it's done. Cheers again, |
Dunc | 21/11/2012 17:10:01 |
139 forum posts | While this video deals with wood machining the idea of a metal-working tool approach is evident https://www.youtube.com/watch?v=_E3VG6dsVYs
Don't know if these reference the same article above but Popular Mechanics Feb 1959 shows a home-built lathe. Might get some ideas there. Last (& not least), I have noted references "on the net" to building small lathes in old issues of ME but I have no further data. |
