Johan van Zanten | 29/10/2012 16:17:59 |
![]() 52 forum posts 98 photos | Hi David, As you may know I am a frequent "user"of our Website but I have a problem with reading the text because the advertising banner is partly covering the text. Is this a problem or setting of my computer or is this a problem for the web designer? The added document is only an example of the problem. I have the fault on almost every page. |
Steambuff | 29/10/2012 16:25:33 |
![]() 544 forum posts 8 photos | Johan, You don't say if you are using a PC/Mac, which operating system and version .... or what Internet browser you are using. If you you are using Windows and using IE8 or 9 then try setting compatability mode. Dave
Grizzly bear | 29/10/2012 18:33:06 |
337 forum posts 8 photos | Windows 7 & IE 9 work fine for me. Regards Bear.. |
wheeltapper | 29/10/2012 18:40:33 |
![]() 424 forum posts 98 photos | It happens when someone posts a long link.
this subject has been beaten to death so many times you would think it would be fixed my now, but no.............. Roy Edited By wheeltapper on 29/10/2012 18:41:07 |
JasonB | 29/10/2012 18:51:14 |
![]() 25215 forum posts 3105 photos 1 articles | There are no long links in the Domestic thread that Johan shows but as Steambuff says Compatability mod eis the best bet.J |
Johan van Zanten | 30/10/2012 08:19:12 |
![]() 52 forum posts 98 photos | Hi Steambuff,
Yes, I use Windows Explorer 8 and your solution cured my problem ! A useful tip ! You made me happy ! Thanks, Johan. |
roy entwistle | 30/10/2012 09:12:15 |
1716 forum posts | Im using windows xp and i e 8 how do i set compatability mode |
Terryd | 30/10/2012 09:13:36 |
![]() 1946 forum posts 179 photos |
Posted by JasonB on 29/10/2012 18:51:14:
There are no long links in the Domestic thread that Johan shows but as Steambuff says Compatability mod eis the best bet.J It also happens if someone posts a picture that is too wide, but only in some circumstances, I think it happens when a picture is linked from some hosting sites. T |
_Paul_ | 30/10/2012 09:39:06 |
![]() 543 forum posts 31 photos | I bet if it were the other way around with the text covering the Paying Adverts something would be done pretty quickly........ Paul |
Ian P | 30/10/2012 09:55:51 |
![]() 2747 forum posts 123 photos |
Posted by _Paul_ on 30/10/2012 09:39:06:
I bet if it were the other way around with the text covering the Paying Adverts something would be done pretty quickly........ Paul That is probably the most relevant and true comment that has ever been posted on this subject! Ian P |
Steambuff | 30/10/2012 10:56:57 |
![]() 544 forum posts 8 photos | Roy, In IE8 there is a icon (like a torn sheet of paper) to the right of the box that you enter the web address into. Dave |
roy entwistle | 30/10/2012 12:00:37 |
1716 forum posts | Steambuff Thanks it worked Roy |
