melals
metals
david simmo09/09/2012 09:28:10
33 forum posts
can you use brass angle(small sizes)to joint to bms
JasonB09/09/2012 10:17:26
That would really depend on how you intend to join the brass to the steel and what loads will be placed on the joint.
More info needed.
J
david simmo09/09/2012 10:36:15
33 forum posts
hi jasonb bolt and rivet
Ian S C09/09/2012 12:54:00
7468 forum posts
230 photos
David, wot's it for? Does it require strength, is it going to be wet often, that could create a galvanic effect, causing corrosion. The ideal would be steel angle, but if you are like most of us you just have to use what ever you have.
On one of my hot air engines, it has a copper cooling hopper, and I tryed a bit of extra cooling by puting an aluminium heatsink in the water. After the motor had been running a while I thought about the galvanic effect, so I put the volt meter across the copper, and aluminium, and got .5 volt, with just plain tap water. Ian S C
fizzy09/09/2012 17:12:23
1860 forum posts
121 photos
you can rivet it, bolt it, bond/glue it (often overlooked by the die hard brigade but things hace come a long way since the end of the war!) and silver solder it...need more detail before one can advise
Gordon W10/09/2012 09:40:21
2011 forum posts
And soft solder, maybe the easiest ?
