Here is a list of all the postings david simmo has made in our forums. Click on a thread name to jump to the thread.
Thread: colour |
25/03/2016 16:37:21 |
hi what colours br standard class 2-6-4 t jubilee 3 1/2 inch gauge inside and out and marking I know it black out side and red buffers but underside ??? thanks dave |
Thread: brass or steel |
27/09/2015 09:13:49 |
hi is brass or steel screws best for cylinders (gun metal) or any advice would be helpful ( 3 12/ gauge jubilee) thanks dave |
Thread: acid |
01/11/2013 16:52:17 |
hi how do you stop mould growing in your citric acid it is in a close container(barrel)with sealed lid thanks dave |
Thread: lathe |
18/10/2013 11:32:11 |
hi I have a chester b8vs lathe the cross slide and tool slide has movement on the hand wheel of 12th how can I remove most of the play this is my 1st lathe any advice would be greatfully received thanks dave |
Thread: wheels |
09/09/2013 07:54:42 |
hi thanks lads all fixed now thanks dave |
Thread: casting |
25/08/2013 15:19:57 |
hi mickw it a3 1/2 gauge brittania hopefully along time thanks dave Edited By david simmo on 25/08/2013 15:20:29 |
25/08/2013 08:12:55 |
hi on gun metal casting(cylinders) whitch is best gunmetal to gunmetal or gunmetal to s/steel it for the pistons and bobin(vavle) thanks dave |
Thread: wheels |
28/07/2013 08:01:58 |
hi the hole in the wheel is to big(ebay) which is best drill and fit bushes brass or cast any help would be appreciated thank dave |
Thread: connecting rods |
08/07/2013 15:39:21 |
hi mikew it the up and down movement before the rods are fitted ( the trailing rod movement at the linkage thanks dave |
08/07/2013 09:15:10 |
hi on a 4-6-2 the connecting rods ? how much movement on the joint between the rear couple rod and drive rod thanks dave |
Thread: loco tender |
07/03/2013 08:25:38 |
thanks all leak fixed thanks all dave |
06/02/2013 10:06:49 |
hi how do you repair water leaks on 3 1/2 gauge tender very hard to solder it right at the bulk head second skin in thanks dave |
Thread: melals |
09/09/2012 10:36:15 |
hi jasonb bolt and rivet |
09/09/2012 09:28:10 |
can you use brass angle(small sizes)to joint to bms |
Thread: wheels |
30/07/2012 06:22:10 |
hi les 3 1/2 tender wheels dave |
29/07/2012 08:32:12 |
whitch is the best way to machine wheels or is there agood book thanks |
Thread: Boiler and Metal Theft. |
25/05/2012 06:38:59 |
hi sorry about your loss is it not time to number boilers ect i know the cost would be high be all could be traced when been sold and could be traced if recovered simmo |
Thread: Technical and engineering drawing. |
24/04/2011 10:50:28 |
hi after reading most of the post on this subject clive you was young once and had to learn the young off to day just like most of us in are young days beer girls and motorbikes but you learn eg from the the people around you help each other even at work someboby will help you . sam if that test drawing was draw right 1st time most people would know the corect shape .in model engineer in the 1950s (before my time)the mag had a novices corner so even then you all have to learn sometime and thing progrese and some people stand still but have a great knowledge to pass on to the young (there children) and friends and work colleague so have patientwith the young so more help for the novice dave |
Thread: manifold |
13/06/2010 12:12:05 |
Posted by david simmo on 13/06/2010 08:38:16:
hi whitch is the best metal for ic engine manifoids thank simmo hi it a rcv91 ic 4 stroke engine hoop to make maifold exhaust thank simmo |
13/06/2010 08:38:16 |
hi whitch is the best metal for ic engine manifoids thank simmo |
