Colour code.
Clive Hartland | 25/07/2012 15:19:03 |
![]() 2929 forum posts 41 photos | I have a bar of Stainless steel that has a red paint over the end, can anyone identify the grade from that colour? It machines OK and the second question is, can I hard solder it?
Clive |
JasonB | 25/07/2012 15:35:14 |
![]() 25215 forum posts 3105 photos 1 articles | Can't help with the colour/grade but I've silver soldeed stainless plenty of times, just use Tenacity No5 or Cup's HT5 flux.
J |
Andrew Johnston | 25/07/2012 15:41:28 |
![]() 7061 forum posts 719 photos | I think that red indicates 416, a martensitic stainless steel with good machinability, but poor weldability as it includes sulphur and phosphorus. Silver soldering is not recommended, particularly if the joint is to be subjected to moisture. Regards, Andrew |
Stub Mandrel | 25/07/2012 20:24:41 |
![]() 4318 forum posts 291 photos 1 articles | Red Gloss is Humbrol No. 19 - I thought everyone knew that? Seriously , I read a 90's ME with interviews of several steel stockholders and they all used their own coloutr codes and had done so since the Ark. It my be different today, though. Neil |
Boiler Bri | 25/07/2012 20:52:41 |
![]() 856 forum posts 212 photos | Took the words right out of my mouth, stubby. It still is the stockholders choice |
Stub Mandrel | 25/07/2012 21:08:24 |
![]() 4318 forum posts 291 photos 1 articles | ... and to add to Jason's comment, the only stainless I've ever silver soldered that was under load was for the ram of my 'Stan Bray' keyway slotting cutter. The joint ractured clean across in minutes, but luckily the backup taper pin is still going strong. If you don't know what grade stainless it is, don't rely on silver soldering it. Neil |
Clive Hartland | 25/07/2012 21:53:12 |
![]() 2929 forum posts 41 photos | Thank you for the heads up on the grade, it looks as if I will have to order some 304 instead. Annoying as I have made the parts already.
Clive |
The Mad Professor | 26/07/2012 09:12:16 |
12 forum posts | Just a little warning. If you use silver solder, use the lowest melting point you can, a zinc-free solder, or use a special stainless steel grade of solder, such as Argobraze 56 (usual disclaimer). If you silver solder an austenitic stainless steel at about 700 deg C using a zinc rich solder, it is likely to crack due to zinc embrittlement. Remember Flixborough? Edited By The Mad Professor on 26/07/2012 09:14:23 Edited By The Mad Professor on 26/07/2012 09:15:13 |
IVATTLMS | 26/07/2012 09:54:58 |
22 forum posts | If the material is non-magnetic and machines easily probaly 304 if magnetic 416 or mild steel |
colin hawes | 26/07/2012 11:38:10 |
570 forum posts 18 photos | I have given stainles steel springs a speck of silver solder to enable soft soldering electrical wires. Colin |
