Here is a list of all the postings IVATTLMS has made in our forums. Click on a thread name to jump to the thread.
Thread: Digital Archives - Manna from Heaven? |
22/08/2018 21:02:46 |
Can only read back to MEW May 18 if clicking onto library in the archives iam i stupid |
Thread: Age related macular degeneration. |
11/07/2018 15:56:59 |
What is the name of the stuff |
Thread: Sentinel 5 inch gauge shunter |
11/06/2018 11:02:21 |
I have one half built from many years ago engine and boiler built never finished it (some day) saw one running at Cardiff track years ago went good and fast,remember something about the frame drawing I made my buffer beams solid steel for extra grip . |
Thread: Tony appelby |
06/12/2017 21:21:35 |
Found it 1955 built a traction engine in 11 months and won the students cup at the me exibition nor bad at 16 year old where is he now |
06/12/2017 09:19:50 |
does anyone remember I think in the 60s tong appelby built a model traction engine when he was in his teens exibitied at the ME exhibition when was that and what happened to him |
Thread: Mild steel |
28/10/2017 15:07:37 |
What is the grade of mild steel that has very little spring back when you bend it Thanks |
Thread: Expansion LInks |
02/08/2017 20:30:07 |
Round die blocks will not revolve they will just slide . |
Thread: Anyone on the Isle of Bute? |
14/12/2016 09:09:01 |
Hi Diane i am in Houston Renfrewshire about 12 miles fro Bute + 1 ferry going next week Robert |
Thread: Australian model engineer magizine index |
25/11/2014 20:14:06 |
Can none of our Aussie friends tell what happened to this fantastic site |
20/10/2014 13:05:35 |
Is this website finished ca not get into it |
Thread: Looking for boiler plans |
07/10/2014 12:14:20 |
You are possibly thinking of Midge Martin Evans did a upgrade on the boiler the modern version is the 0-40 Dock tank by Jim Vass now Horley |
Thread: Rapid Prototyping |
27/06/2013 18:37:40 |
Hi John I started in cnc in 1982 at work neither having seen a cnc or heard of them told i going on a weeks cource to Watford to learn about cnc .The first m/c i was on a vertical m/c centre with Fanuc 6m the only way of getting the program into the m/c was write the program on A4 notepad doing the trig etc(no cad cam) the typist would type a paper tape to get it into the memory was it was proved a copy was punched out onto a tape and stored ,that was the start.I always thought about that a small version in the home workshop would be great,at this time no home computer nor did not know about the internet,went to Florida on holday and found Home Shop Machinist in a mall and adverts for small cnc,then it started i bought Ahha cnc software which i think John and i were some of the early one using it on this side of the pond and still use it suits me could go on still use a very old version of bobcad on DOS This my adventure in home CNC |
Thread: Backface milling cutter |
10/03/2013 09:52:42 |
Were used all the time in the old days by the radial arm drillers ,the the bar which had a blind slot in it was put through the hole then the spotface cutter was inserted in the slot. |
Thread: Myford |
18/09/2012 18:13:09 |
any experiences with myford screw on er 25 collet holders |
Thread: Identify some Stainless steel. |
26/07/2012 09:54:58 |
If the material is non-magnetic and machines easily probaly 304 if magnetic 416 or mild steel |
Thread: Cobalt drill speed to remove broken tap |
24/02/2012 17:50:17 |
I agree solid carbide slotdrill no problem |
Thread: Mill/drill return spring |
22/11/2011 05:35:22 |
where did you get the spring and what size is it as i need one for an old warco mill/drill |
Thread: NEW Original MYFORD Dickson type tool posts & holders |
01/11/2011 13:56:34 |
Pardon my ignorance what is the W |
Thread: Myford collets |
07/10/2011 21:32:02 |
Using myford coolets the saddle tends to be over the gap in the bed which i do not like
,i have a few myford collets but i changed to using Er collets with Arrand holder ,Arrand not cheap but the quality is top notch akin to myfords quality, when buying Er collets on E-bay you never know the quality till you receive them so take your choice. |
Thread: flip up toolholder |
20/06/2011 20:38:31 |
Very good attachment but surely depends on how quick you can reverse your lathe i do not think i can throw my Myford into reverse quick enough and also the chuck could unsrew ,i wait to be enlightened. |
