Mexican jon | 19/07/2012 08:58:07 |
34 forum posts 5 photos | Does anyone know if a ML7R can be retro-fitted with parts from a Super 7 to provide powered cross feed? I'd like to have the powered cross feed facility but don't really want to go to all the trouble of selling my lathe (Being that I have a screw cutting gearbox, clutch etc. on my lathe already) and then looking for a Super 7. Regards Jon
David Clark 1 | 19/07/2012 09:08:31 |
![]() 3357 forum posts 112 photos 10 articles | Hi There I would not sell my Myford ML7R either.
Your best bet would be to add a power X feed to the ML7R. I would think this is a very simple job. Use a stepper motor and controller. There have been articles about adding a stepper motor feed to a mill and possibly lathes in MEW. There used to be an accessory that ran from a DC motor (low voltage). Look for Keith Ward's Myford ML7 rebuild, there may be a photo of the unit. Have a look at the digital issues. You are a subscriber, aren't you? You are probably looking for articles by Tony Jeffree about converting a Myford ML7 to CNC. This would be a good starting point. regards David |
dcosta | 19/07/2012 10:10:33 |
496 forum posts 207 photos |
Hello Jon. |
David Clark 1 | 19/07/2012 10:13:03 |
![]() 3357 forum posts 112 photos 10 articles | Hi There I have set MEW 139 as the trial digital issue. You can view this article in there. regards david Edited By David Clark 1 on 19/07/2012 10:13:27 |
Bazyle | 19/07/2012 11:10:29 |
![]() 6956 forum posts 229 photos | Electric drill + tuning fork. 30 seconds job done. Seriously how often do you need power x feed. |
Andrew Johnston | 19/07/2012 11:31:06 |
![]() 7061 forum posts 719 photos |
Posted by Bazyle on 19/07/2012 11:10:29:
Electric drill + tuning fork. 30 seconds job done. Seriously how often do you need power x feed. Actually all the time. If nothing else, it makes parting off a cinch. Regards, Andrew |
David Clark 1 | 19/07/2012 12:00:32 |
Electric power screwdriver would be ideal as a removable power feed. Parting off with power feed? Not a good idea on an amateurs lathe unless you want a big bang. Professional lathe with flood coolant yes. regards David Edited By David Clark 1 on 19/07/2012 12:03:07 |
Mexican jon | 19/07/2012 12:08:48 |
Posted by David Clark 1 on 19/07/2012 09:08:31:
You are a subscriber, aren't you? regards David
I am now
Edited By Mexican jon on 19/07/2012 12:15:09 |
JasonB | 19/07/2012 12:38:20 |
![]() 25215 forum posts 3105 photos 1 articles | I'm with Andrew, would not be without my power cross feed. I have used the electric screwdriver method on the topslide when doing long tapered cuts, better than a cordless drill as the speed is slower & constant. J |
Roderick Jenkins | 19/07/2012 12:51:42 |
![]() 2376 forum posts 800 photos | I fitted a commercial power servo motor crossfeed to my S7 lathe a couple of decades ago (Warrington Model something I think, sorry not close to the lathe just at the moment). I use it almost every time I'm facing - it is so convenient. My experience differs from David in that I almost always use it for parting off with a Greenwood TC tool in the back toolpost. Under power I can concentrate on feeding cutting oil into the slot and mild steel swarf comes off in nice tight little coils. I think one of the advantages is that one is less likely to increase the depth of cut until it all goes wrong, as you might do when hand feeding. cheers, Rod |
David Clark 1 | 19/07/2012 14:12:21 |
![]() 3357 forum posts 112 photos 10 articles | Hi Mexican John Does that mean you are a convert? regards David
Mexican jon | 19/07/2012 14:53:46 |
Posted by David Clark 1 on 19/07/2012 14:12:21:
Not so much of a convert
Regards Jon
john Petty | 25/10/2018 11:37:35 |
4 forum posts | THe ML7R can be converted to power cross feed, as long as the bed has the Long indent behind the leadscrew. I think all ML7R lathes have this. The bed of the ML7R is the same as the super 7. Myford rationalised production so only one bed was used. The ML7R seems to be a super 7 without power cross feed. John
Edited By john Petty on 25/10/2018 11:38:08 |
Neil Wyatt | 25/10/2018 20:00:26 |
![]() 19226 forum posts 749 photos 86 articles | Hi John, yes an ML7R has more in common with an S7 than an ML7, but you are six years too late Neil |
john Petty | 28/10/2018 14:55:50 |
4 forum posts | Neil..............
As I have only just looked at and sourced power cross feed for my ML7R. I thought it would add to any Model Engineers body of knwoledge that "YES" you can convert a An ML7R, plus any one who is thinking of converting their Super 7 should also check that the indent in the bed is there enabling PXF So I may be 6 years late but in non of the other replies to this thread apperas to have given info given about putting a Myford PXF on the ML7R, but maybe no one is interested.
John |
Brian Wood | 28/10/2018 15:10:04 |
2742 forum posts 39 photos | John, I am interested, but I must ask---how do I recognise the long indent type of bed over whatever the other bed looks like to see if my ML7R can accept that upgrade? I would have thought it more important to have the leadscrew with the keyway to drive the power cross feed than anything else Would you mind clarifying please? Regards Brian |
john Petty | 29/10/2018 16:36:30 |
4 forum posts | Brian...................
The indent on the bed on the lathe bed is crucial to retrofit Myford PXF to the ML7R. The Apron of the power cross feed models is quite complicated and there is a gear which sticks out on this apron further than the half nuts consequently even if the lathe bed could accomodate the new saddle, without the indent PXF is a no go. The keyed leadscrew is imprtant yes, as that ttransfers the power, also there is a keyed cross slide screw which takes power from the apron to the cross slide via a gear on the new saddle. To get some idea of this take a look at the following Ytube vids.
The end of the 2nd video shoews the gear which sticks out on the apron and you can get some idea of the indent from the first link.
Hope this helps.
John |
Robbo | 29/10/2018 23:40:21 |
1504 forum posts 142 photos | Brian Looking at your lathe in your album "Centring a long bar" it seems to have a bed compatible with Super 7 power cross feed, with a long indent below the front shear almost the full length of the shear. |
Brian Wood | 30/10/2018 08:32:13 |
2742 forum posts 39 photos | Hello Robbo and John, Thank you both for your helpful information, I did wonder if it was possible to be quantitative about this indent and take a reference measurement back, say, from the face of the front shear, it is largely a matter of judgement by observation otherwise. The two links John listed were interesting, I was called away before I could finish the second one and will go back to it, but the lathe shown was clearly a hard worked machine getting some much needed attention. Regards Brian |
Martin Kyte | 30/10/2018 09:01:02 |
![]() 3445 forum posts 62 photos | Before you do anything would it be worth giving Myford a ring, telling them what you have and asking them to quote for an exchange super7 with PXF. It is going to cost you some extra money but you may find it's worth it and anyway it costs nothing to ask. I did an exchange a couple of years ago and it cost me £3000. I exchanged a Super7 without gearbox for a recon Super7 with gearbox and power cross feed. I kept my stand, Newton Tesla drive and Motor and all my tooling. As you have a gearbox on yours you should do better than this On the face of it it may be a lot just for the addition of PXF BUT you do end up with a reconditioned machine (full regrind etc) and its going to cost you some cash to source the parts for upgrading your lathe plus the faff factor in actually doing the work. regards Martin
