Lathe question
Lathe belt
Leigh Davies29/02/2012 21:02:29
10 forum posts
6 photos
Hello again
first thanks very much to all involved in my last question.
After running my lathe for seconded day I have now broke the motor belt. !! First does anyone know where I can get a belt for a Colchester 6 1/2 mater 500. ?
I have just fitted a single phase motor with an aluminium pulley wheel ,the belt was a little tight would this be the reason why it has snapped ?
thankyou very much
leigh.
JohnF29/02/2012 22:04:21
1243 forum posts
202 photos
Hi Leigh,
Assuming it is a V belt it is unusual but not unknown for them to snap -- they often wear due to poor adjustment thus causing them to slip.
It will be a standard unit and if you look on the outside it will have some letters and numbers denoting the section and diameter or circumference. You can get Kevlar re-inforced belts now and they are very good for high power transmission.
Look at Simply Bearings web site http://simplybearings.co.uk/shop/Belts/c4601/index.html I have used the people and find them very helpful and good on price.
Regards John
michael burton 129/02/2012 22:52:14
126 forum posts
32 photos
hi it may not be of help but when i was working in the industry the belt on the bridgeport snapped and we got hold of a belt that clicks togethor in sections i cant rember what the system was called but should be avalable as it was not over long ago the beauty of it is that you can make to a length to suit we used it for ages and never had a problem mayby some one on here will no the name of it so if you get stuck that might be an option
regards mike
John Coates29/02/2012 23:03:29
558 forum posts
28 photos
Michael
Do you mean T-link V belts?
http://www.lathes.co.uk/page4.html (about 25% down this page)
michael burton 129/02/2012 23:11:51
126 forum posts
32 photos
hi john yeah thats the ticket it was very handy as we didnt have to take much off the bridgeport apart just threaded it thru like i say we used it and never had a problem
Ady129/02/2012 23:43:39
6137 forum posts
893 photos
What tpi are you after??
It all boils down to tpi, 25.4 for a 1mm thread etc
If you can give me the tpi and your gears, plus your leadscrew tpi, I can find your perfect or nearest combination.
oops
sorry, wrong thread
Edited By Ady1 on 29/02/2012 23:48:58
Mike Wainwright01/03/2012 06:55:25
149 forum posts
8 photos
Leigh
RDGTools sell the link / V Belting by the metre.
www.rdgtools.co.uk Code No.874923
Bazyle01/03/2012 09:24:02
6956 forum posts
229 photos
I saw some horrible plastic linkbelt at a recent show which seemed rather rigid and hard. I was tempted for a few seconds as the proper stuff is horribly expensive but have since seen a post saying it slips. Newcomers to the hobby might not be aware of the proper fibrous stuff.
Wait five more minutes and Queeny ' queen of the spam' Lin will start a factory making the stuff.
Ian S C01/03/2012 11:06:10
7468 forum posts
230 photos
There are a number of types of link belting, the T link belts are good, I use that and also belting similar to the origional Brammer belt, but with rivits with a T shaped head that just pops through the holes in the belt, and is then rotated 90*. Definately makes belt changing easier. For the head stock of my lathe, I have a bit of wire with a hook on the end, feed the wire through, pull the belt through, hook it together, done. With ordenary V belt, disassemble the mandrel and counter shaft, remove from the lathe put the belt in and reassemble, first time took two or three days because I bumped the pin on the back gear, and broke it. I used the mill to turn a new pin after I went to town and got a bit of silver steel to make a new one, and a die to put a thread on it. The new belt lasted about as long as the first, about a year, the link belt does better than ten years. Ian S C
Stub Mandrel01/03/2012 19:40:21
4318 forum posts
291 photos
My mini lathe is running on 1/4" plastic belt, the kind you join using a hot knife. Perhaps not a long term solution but it got me up and running. The pulleys I made for a standard V-belt though.
Ian S C02/03/2012 09:14:46
7468 forum posts
230 photos
Neil, if you have the green stuff, it will last well, I'v got 5mm green on my Super Adept, and a local clothing factory used it on their sewing machines, until their production went to China, or some where similar.
Ian S C
