flatness of faceplate ?
gerry madden20/01/2012 20:15:07
331 forum posts
156 photos
Ive just bought a cast iron faceplate. I bolted it on the the spindle and checked the runout in several places. This was fine. But as I wasnt intending to use it I started to remove it. Suddenly I noticed that it didnt seem to be totally flat. On more careful inspection I have now found that the last 20mm or so of its radius is cambered off (in the headstock direction) by about 1mm. Is this normal ?
JasonB20/01/2012 20:18:15
Always best to skim a new faceplate when its on the lathe.
J
gerry madden20/01/2012 20:42:05
331 forum posts
156 photos
But to make this faceplate nominally flat all the way across its 160mm diameter I will have to skim 1mm from two thirds of face. Thats not so much a 'skim' as a significant machining operation !
Im not sure if this cambering is deliberate/normal or accidental.
JasonB20/01/2012 20:58:46
Accidental.
What lathe is it for and if a new one I would be asking for an exchange as it is a bit excessive
mgj20/01/2012 22:41:27
1017 forum posts
14 photos
Don't forget that it will never be truly flat because if the lathe is set correctly, it should turn very slightly concave.
And as Jason said, it would be someone being a touch unwise if they just put a faceplate (or a chuck backplate) onto a lathe and expected it to be true.
Still 1 mm is a bit more than one might have expected, but it won't matter so long as the outer edges remain thick enough to remain rigid in use. So that might be a machining allowance?
gerry madden21/01/2012 12:27:30
331 forum posts
156 photos
Gentlemen, what is it they say, the taste of poor quality lasts a long time after the pleasure of a low price fades ! I have a decent lathe but decided the makers own faceplate was faaaaar too expensive. So I bought a surprisingly cheap one - almost too cheap to even bother sending back. So I live and learn, again !
Thank you all for your comments which have been quite both helpful and enlightening. I suppose its not often I will need to use the whole 160mm face so in the mean time I can just skim a little each time to get a flat and true 'working' area.
And I see also now that its not particularly thick (about 10mm) compared to others so it may have a quite limited life and be simply unsuitable for bigger tasks. But at least now, thanks to you, I know the characteristics I need to look for and appreciate what Im paying for when I buy my next one.
Gerry
Tony Pratt 121/01/2012 13:16:32
2319 forum posts
13 photos
Gerry, there is another similar pearl of wisdom "the quality remains long after the cost is forgotten" This was penned a long time ago by a Mr Rolls or a Mr Royce I can't remember which and still remains as true today. We have all been tempted by cheap, cheap, cheap and paid more in the end.
Tony
NJH21/01/2012 13:30:09
2314 forum posts
139 photos
Hey Gerry
So you've got a cheap faceplate and it needs 1mm removed. It is probably still the most cost effective solution to skim off that 1mm ( unless you can persuade the vendor to supply a more accurate replacement.) As has been said, nearly all faceplates will need truing up from time to time and, in truth, how often are you likely to use your faceplate?
Norman
David Clark 121/01/2012 13:40:07
3357 forum posts
112 photos
10 articles
Hi Gerry
The first thing I would do is see how much material stands proud of the mandrel nose.
I f you have to skim the faceplate true, you don't want the mandrel nose protruding beyond the faceplate.
regards David
blowlamp21/01/2012 13:44:31
1885 forum posts
111 photos
Don't throw it away, Gerry.
Maybe consider fastening a sacrificial plate to it once you've got rid (probably in years to come) of the 1mm camber.
Even some thick aluminium plate would be OK and could be skimmed when needed.
The beauty of this is you can drill/tap it at will for those awkward jobs and replace when you need to.
Martin.
jason udall21/01/2012 15:43:11
2032 forum posts
41 photos
futher to the sacrificial face plate...have heard of using old brake discs ...obviously mounted on other faceplate.
