Help about lagging
please can anyone remember
Springbok18/12/2011 22:33:21
879 forum posts
34 photos
There was a thread in a forum which I am trying to track down which mentioned a material that you could dampen and mould around the boiler or pipes I should have taken a note of it but as usual did not. I remember it saying builders merchants but went in and someone built like a ***** door said duh (just like homer) end of enquiry.
So can anyone remember what the material was !!!
Would help me greatly
Have a good christmas and new year
Anthony Knights18/12/2011 23:35:35
681 forum posts
260 photos
Type "lagging " into the search this site box at the top of this page and away you go.
Springbok19/12/2011 00:11:44
879 forum posts
34 photos
Hi Thank you Tony for your input but this is not what I want I am building a 5"g B1 and need a lot of the stuff. As I said this was a material that could be dampened and moulded around boilers and pipes you will note that I am involved with these posts already.
Bob
Have a nice one.
John McNamara19/12/2011 04:18:01
1377 forum posts
133 photos
Hi Springbok
Recently I had to design a domestic fire place and contacted a fire brick supplier. This company also supplied the foundary and furnace industries
The company had a range of materials for "casting" a fire protective layer.....Some materials were "Air set" while others were heat set. They also had various kinds of matting both flexible and rigid.
I live in Melbourne Australia so the following link may not help you; but it may assist in helping you where to look. and what to ask for.
If you search for "Fire brick" in your location you may find another?
Cheere
Springbok19/12/2011 07:05:19
879 forum posts
34 photos
Hi John
Very helpful gives me some terminolgy to search on.
Hope weather is nicer in Melbourne than here it is -2
Bob
Ian S C19/12/2011 11:08:22
7468 forum posts
230 photos
There was a thread in genral questions sect of Model Engineer Clearing House a few months back, I think it was about a Tich built by Paul? I think, that might set you in the right direction, it was some sort of hi-tech paper.
Ian S C
Robert Dodds19/12/2011 12:18:10
324 forum posts
63 photos
Hi Springbok,
Have a look at Vermiculite cement.
A 6:1 mix with portland cement is used as an insulating filler in firebacks.
http://www.fornobravo.com/forum/f28/tip-mixing-vermiculite-concrete-3793.html
Depending on your thick ness you might need to mod the ratio but vermiculite is on ebay and should be in DIY and garden centres as it also doubles as a soil lightener.
On ebay there is also ready made thin board which might suit your needs
Good hunting
Bob D
Blue Peter19/12/2011 16:18:35
4 forum posts
Springbok
Kaowool Blanket or Kaowool paper is the stuff that is usually recomended which should be available from builders merchants or insulation specialists, but I don't know how big the pack size is. Blackgates list it in their catalogue per square foot.
Weldaguard from insulation specialists is another option.
There's also carboard from cereal packets built up to thickness.
Peter
mick H19/12/2011 16:50:27
795 forum posts
34 photos
Springbok....I am currently experimenting with ceramic fibre and fireclay cements. I have had a bit of success soaking the fibre in the cement mixture and then moulding it to shape. It goes quite stiff and stays in position. Pottery suppliers are the people with good knowledge of this subject. The materials are relatively cheap and the ceramic fibre is available from ME suppliers. Chronos used to do it and Polly I think. If you think that this would be of use to you and want names, leave a PM for me and I will try and sort them out.
Mick
Tony Martyr19/12/2011 19:55:20
226 forum posts
45 photos
I have used exhaust wrap on a track-car and as boiler insulation bought from:
http://www.demon-tweeks.co.uk/Search.do?method=delegate&n=663&p=242387&s=exhaust+wrap
Springbok20/12/2011 06:12:40
879 forum posts
34 photos
Mick
Sounds like the stuff I read about will send a PM
Bob
Ian S C20/12/2011 10:57:50
7468 forum posts
230 photos
Bob, have a look at Thanks NASA by Paul Denny on page 9 General Chat, Model Engineer Clearing House, worth a look.
Ian S C
Dave Martin20/12/2011 13:33:11
101 forum posts
11 photos
Not certain if its suitable for your application, but you can get castable insulation in various grades & densities, such as castable vermiculite, rated to 1050 degrees C, at GBP 35 for 1/2 cwt from Kiln linings
usual disclaimer - no connection with them other than as a customer
Edited By Dave Martin on 20/12/2011 13:34:23
mick H20/12/2011 15:31:39
795 forum posts
34 photos
Dave...brilliant selection of stuff ....but no contact details that I can find.....only an E mail if you are a company.....and presumably big order.
Keith Long20/12/2011 15:44:21
883 forum posts
11 photos
Hi Mick
Just looked at the site Dave highlighted above as interested in this type of material for a kiln/furnace lining.
Scroll down the page (a long way) until you come to a box on the left hand side headed "Information". In the box is a heading "Contact us" click on that and you'll get address info etc.
Looking at the form to register an account there is a box for "Company name" but it ISN'T a "required field" so I don't see any block to you ordering as an individual.
Keith
Dave Martin20/12/2011 15:45:02
101 forum posts
11 photos
Posted by mick H on 20/12/2011 15:31:39:
Haven't got a landline phone number for them, I just ordered off their web site. You might get the number from directory enquiries, the address from the web site is
Kilnlinings
53 Ennerdale close
Dronfield
Derbyshire
S18 8PL
but a quick google gave a mobile 07958-615187
well - they start with insulation bricks at 29p each ....
cheers / Dave
Edited By Dave Martin on 20/12/2011 15:46:28
mick H20/12/2011 17:03:06
795 forum posts
34 photos
Thanks gents....time I went to Spoecsavers I think.
Mick
