Compressor for testing steam engines
Roderick Jenkins | 10/09/2011 11:04:17 |
![]() 2376 forum posts 800 photos | Hi chaps, Can anyone please recommend a cheap and cheerful compressor for testing small steam plant e.g ST engines or 3 1/2" gauge locos. cheers, Rod |
Gordon W | 10/09/2011 11:53:30 |
2011 forum posts | For very cheap you could convert an old freezer comp. , info. was given in MEW not long ago. I would advise buying a cheapo, sub £100 , one. I think mine came from Machine Mart some years ago and still working. So useful you will wonder how you managed without it. Mine is used beyond its intended duty regularly, spraying car underseal, running a windy spanner etc.' course only in short bursts. |
blowlamp | 10/09/2011 11:58:01 |
![]() 1885 forum posts 111 photos |
Martin. |
Ian S C | 10/09/2011 14:13:28 |
![]() 7468 forum posts 230 photos | I got an old freezer compressor for $NZ 15, switch second hand $NZ 5, 1/2 hp Hoover capacitor start motor (and blacksmiths wall drill) $NZ15, I had an old aircraft low pressure oxygen cylinder. Put it all together, about half a day, its a good one, but a bit slow for some things.
Just got to repair the switch on a second one that I was given, that will improove the capacity. All that for less than 20 pounds. Ian S C |
NJH | 10/09/2011 15:12:46 |
![]() 2314 forum posts 139 photos | Hi Rod Bought one similar to these a few years ago ( the 6L version - but it was much cheaper then!). Works OK and seems well built - but very noisy. Norman Edited By NJH on 10/09/2011 15:13:37 |
ChrisH | 10/09/2011 18:21:29 |
1023 forum posts 30 photos |
Hi Rod,
I bought an oil-free compressor from Halfords for £99 which is quite good -but it's really only for low air consumption use as it only has a 6litre air bottle. But if you could get another cylinder - like Ian above did - then you could pipe them into together and that should improve things. Be aware that if you go down this route Halfords sail a bit close to the wind IMO as the box leads you to think you're maybe getting the wood kit with a nailer/stapler, only when you look closely they have ticked the box that says 'compressor only'!
Look also at Machinery Mart - I am sure last time I looked they had air compressor/cylinder kits for under £100 also.
Chris
Edited By ChrisH on 10/09/2011 18:22:00 |
