A simple little device that might help you.
chris stephens | 11/03/2011 19:15:44 |
1049 forum posts 1 photos |
Hi Guys,
Hers's something for all you chaps who use parallels in your milling vice and have difficulty keeping them in place. Or should I say, here's something for all you guys not blessed with three hands.
The spring is made of Phosphor Bronze, is about 4thou thick and the shape I find best is rather like a Greek "Omega" . I hope you can see from the photo how it is used. They take seconds to make but can save "hours of harmless fun" as the advert used to say.
I have seen people use coil springs to do the same job but obviously you can only crush them so far, with the Omega spring you can crush it right down to virtually nothing and it will still spring back to shape.
I am sure the idea is not new, but I had not come across it before and I would think that some of you had not either. I hope some of you find the idea helpful.
chriStephens
Edited By chris stephens on 11/03/2011 19:23:50 |
JasonB | 11/03/2011 20:16:16 |
![]() 25215 forum posts 3105 photos 1 articles | One of those little bits of expanded polystyrene packaging you get 1000s of in a box also does the trick and it won't catch a drill bit as you break through right above a metal spring.
Jason Edited By JasonB on 11/03/2011 20:17:18 |
NJH | 11/03/2011 21:56:44 |
![]() 2314 forum posts 139 photos | That's a good idea. Has anyone tried these "wavey" parallels though? Norman |
ady | 12/03/2011 04:20:28 |
612 forum posts 50 photos | I tend to use toolsteel bits and old bearings as parallels. |
Terryd | 12/03/2011 07:58:14 |
![]() 1946 forum posts 179 photos | Hi All, A guy on another forum recommends using that thin foamed flexible plastic sheet often used in packaging, it feels a bit waxy if you know the stuff. Thin foam food packages suitably washed can be cut up to do the same job of keeping parallels in order Terry |
clive swinney | 12/03/2011 11:18:44 |
6 forum posts | Hi all
I use flexible magnetic self adhesive strip attatched to all my parallels. It works for me. |
KWIL | 12/03/2011 12:33:51 |
3681 forum posts 70 photos | Norman, I have used the wavy parallels, they are very good when your other parallels are too wide. They will take a set if you crush them too far and go easy on the mallet! |
NJH | 12/03/2011 18:23:37 |
![]() 2314 forum posts 139 photos | Hi KWIL Thanks - I will add a set to my " Wish List" then. Norman |
