Member postings for clive swinney
Here is a list of all the postings clive swinney has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart 10H and 10V build thread
19/11/2015 14:26:16
Should be interesting. I have built the 10H and 10V and am now building the Score.Out of interest the 10H cost £12.19 at the Model Engineering Exhibition in 1983
Thread: QUICK CHANGE TOOL POST
23/04/2013 16:19:08
I have just made a version of Harold Hall's QCTP for my mini lathe with a couple of modifications.
I used two locating keys and a lock nut for the height adjustment instead of a grub screw.
One problem I found, was that. because of the extra overhang, there was more judder unless the top slide was wound fully in, this may apply to all QCTPs.
The other problem was parting off, the tool jambed and broke the operating piece, I have now remade this using 12.5mm steel and it is much stronger.
Apart from this it seems a useful bit of kit.
Regards Clive
Thread: Gas burner
20/06/2011 17:58:47
Thanks for the information David, I will try these groups.
20/06/2011 15:00:29
I have nearly completed my first locomotive, it is ERIC from Steam trains in your garden. The gas burner is a10mm brass tube with fine slots cut into it and one end sealed. This fits into a 19mm tube running lengthwise through the boiler. The burner lights well outside the boiler, but will not light in place, the flame coming out of the end of the boiler tube in the smokebox. Does anyone have any experienceof this or suggestions. Thanks Clive
Edited By clive swinney on 20/06/2011 15:00:56
Thread: An "Omega" spring to keep Parallels in place
12/03/2011 11:18:44
Hi all
I use flexible magnetic self adhesive strip attatched to all my parallels. It works for me.
Thread: Cleaning up after Silver soldering (brazing)
13/11/2010 12:28:46
I read recently on the web that kettle descaler can be used for pickling. Has anyone tried this and does it work
