Model Engineers Workshop Issue 5
Stephen Middleton | 17/01/2010 20:51:34 |
15 forum posts 4 photos | Hello,
I am new to the forum and as an old engineer (28 years ago) I am trying to pick up the threads again for my retirement.
Does anyone have copies of the drawings for the clutch that apparently came with issue 5.
Any info would be most welcome.
Thanks,
Steve. |
Jim Whetren | 18/01/2010 00:56:10 |
50 forum posts 1 photos | Hello Steve,
It just so happens this was the first MEW issue I bought, and as I don't have a Myford, I only gave the plans a passing look.
What was it you wanted to know?
Jim |
Stephen Middleton | 18/01/2010 13:35:49 |
15 forum posts 4 photos | Thanks Jim,
What I am looking for is a copy of the plans,the background info is in the digital archives and I can print that off.
Thanks for your reply,
Steve. |
Jim Whetren | 18/01/2010 15:04:30 |
50 forum posts 1 photos | Hello again Steve,
I have sent you a message with my e-mail address so we can make contact outside of the forum.
Jim |
KWIL | 18/01/2010 16:22:14 |
3681 forum posts 70 photos | I have the plans also if required, they would scan to 10 off A4 |
Michael Wilde | 02/05/2010 09:52:33 |
![]() 25 forum posts 16 photos | Hi, would it be possible to get a copy of these plans? Many thanks Mike |
Jim Whetren | 02/05/2010 11:55:39 |
50 forum posts 1 photos | Hello Mike,
I have sent a PM.
Jim |
Adam Wells | 21/07/2012 13:00:07 |
1 forum posts | Hey, I know this is an old thread, but could I have a copy the plans? Thanks Adam. |
Richard Fallas | 10/01/2013 00:50:24 |
3 forum posts | First post to MEW forum. As per Adam's last post, is it possible to get a copy of the plans? I have printed out the article, but drawings would make life easier. Have acquired a 60yrs younf ML7 which means it is slightly older than I am, but its original Hoover motor is telling that I need a clutch! Can anyone help please? Thanks Richard (NZ) |
John C | 10/01/2013 21:45:05 |
273 forum posts 95 photos | Hi Richard, PM me with your e-mail address. John |
Robbo | 12/01/2013 10:24:09 |
1504 forum posts 142 photos | Hi all, I scanned these drawings a couple of years ago for a chap in Australia, still have the files in pdf, so can send them, subject to server capacity, in short time. If anyone would like a set, send me a PM with email address.
Phil |
_Paul_ | 12/01/2013 15:29:52 |
![]() 543 forum posts 31 photos | @Robbo PM sent Thanks Paul |
Richard Fallas | 13/01/2013 23:39:11 |
3 forum posts | Thanks for all responses. Really helpful for a new member. Have PM'd to John. I've known about (and lusted after) Myfords since I was 14 (Model Engine Encyclopaedia, c1968), and now I have one. Having used a Unimat for 25 years or so for modest sized stuff, its great to have the bigger machine. But size isn't everything and I have a lot of learning to do. In fact the reason I didn't go Chinese (was looking at Seig SC4 and 6's) was mainly that I knew I would be tapping into decades of accumulated wisdom. Seems I was right. Meanwhile if anyone is remotely interested in what can be done on a Unimat there is an entry in the Gallery on the Model Engine News Dec 2012 page. I am now working on a Mills 075 replica which will have benefitted from both Unimat and Myford. Will broadcast more when finished. Thanks again. Richard
Robbo | 16/01/2013 10:17:17 |
1504 forum posts 142 photos | Ken, I have replied to your PM. I need your email address to send the drawings. Phil |
Richard Fallas | 16/01/2013 21:50:04 |
3 forum posts | Thanks to John C I now have the drawings. Puzzled by what actually causes the clutch to stay engaged ie spring to force cone into ring. Maybe that will be clear when I print out the dwgs. I can see the small spring providing return pressure for disengaging shaft, but not what forces the clutch closed again. Anyone care to explain? Probably very obvious! Cheers Richard
Kevin F | 09/11/2013 10:04:03 |
96 forum posts 24 photos | Sorry for raking up an old thread,but does anyone have the drawings for the ML7 clutch system, I would like to incoperate the ML7 system onto my ML4 ,thanks in advance . Edited By Kevin Fenrich on 09/11/2013 10:04:59 |
KWIL | 09/11/2013 13:03:36 |
3681 forum posts 70 photos | Kevin, PM your email and iI will send you scanned copies |
