Here is a list of all the postings Richard Fallas has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ml7 clutch |
16/01/2013 21:50:04 |
Thanks to John C I now have the drawings. Puzzled by what actually causes the clutch to stay engaged ie spring to force cone into ring. Maybe that will be clear when I print out the dwgs. I can see the small spring providing return pressure for disengaging shaft, but not what forces the clutch closed again. Anyone care to explain? Probably very obvious! Cheers Richard
13/01/2013 23:39:11 |
Thanks for all responses. Really helpful for a new member. Have PM'd to John. I've known about (and lusted after) Myfords since I was 14 (Model Engine Encyclopaedia, c1968), and now I have one. Having used a Unimat for 25 years or so for modest sized stuff, its great to have the bigger machine. But size isn't everything and I have a lot of learning to do. In fact the reason I didn't go Chinese (was looking at Seig SC4 and 6's) was mainly that I knew I would be tapping into decades of accumulated wisdom. Seems I was right. Meanwhile if anyone is remotely interested in what can be done on a Unimat there is an entry in the Gallery on the Model Engine News Dec 2012 page. I am now working on a Mills 075 replica which will have benefitted from both Unimat and Myford. Will broadcast more when finished. Thanks again. Richard
10/01/2013 00:50:24 |
First post to MEW forum. As per Adam's last post, is it possible to get a copy of the plans? I have printed out the article, but drawings would make life easier. Have acquired a 60yrs younf ML7 which means it is slightly older than I am, but its original Hoover motor is telling that I need a clutch! Can anyone help please? Thanks Richard (NZ) |
