I need this part
Alex | 13/10/2009 15:00:16 |
4 forum posts | Hi everybody
Firstly i am not a model engineer (or an engineer of any kind for that matter)
i am a designer. I am trying to make a modification to a plotter head - a drawing machine,
I think the model engineering community might be able to help me.
Can anyone make this part?
There will never be enough needed to interest commercial companies - but I would be happy to cover the costs.
Rob Manley | 13/10/2009 15:07:38 |
![]() 71 forum posts 14 photos | Im sure there are people around who would have a go for you. Where are you based exactly because it might be better for someone local to help. Otherwise I would make one - as long as you don't mind waiting a fortnight. I would be worried about making it in two parts because of concentricity issues - how important is this? Rob. Edited By Rob Manley on 13/10/2009 15:09:10 |
David Clark 1 | 13/10/2009 16:07:47 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
I would suggest using a hypodermic needle for the tube bit.
I doubt you could easily drill 0.5 through a length of 10mm.
regards David
Circlip | 13/10/2009 18:29:15 |
1723 forum posts | You're basically trying to re-invent the "Rotring" drawing tip then ???
Regards Ian. |
Ian Abbott | 13/10/2009 19:18:19 |
![]() 279 forum posts 21 photos | I picked some of the Rotring tips from a yard sale a while back, though you can still probably buy them. A cheap alternative would be the Stadler draughting pens, you can use them without the body and Stadler compasses sometimes come with screwed adaptor rings. It would be possible to shorten the reservoir to keep the hight down.
Even cheaper would be a spacer to fit a "V5 Hi-Techpoint" pen from any stationary shop.
All this assumes that there is enough space.
Also, the Summa plotter that we sold before we came back from Canada had little fibre tip marker dealies. Boy, they were expensive though.
Ian |
Alex | 13/10/2009 23:21:34 |
4 forum posts | Thanks guys
Rob locality, good point - I am in Sunderland England so probably best if I could get help from someone in the UK, I am not too worried about the time scale It would probably take a few goes to get it right, iron out any problems etc. might turn into a bit of a development project.
David Thats just the kind of thing I wouldn't know about - why I need help!
Ian (circlip) Pretty much but for an automatic pencil - more modify than re invent so it works properly in my application. (I wouldn't presume to try and re invent a Rotring)
Ian (Abbott) I'v tried quite a few pens and pencils, the problem is they don't fit well and end up as a bodge. I think if it can be done properly I will get something that works well is convenient to use and would be repeatable. |
LionelGedling Goodwin | 14/10/2009 00:29:56 |
1 forum posts | Hi Alex, I also am not an engineer (yet) but it looks to me remarkably like the end of a Pentel P205 0.5mm clutch pencil. The overall length is only 21mm and the outer body shape is two tapers totalling 16.1mm in place of the 8mm and 12 mm length sections. The 4mm section is an exact match with 0.8mm outside diameter and 0.5 mm inside diameter. No doubt the cone could be turned down to your specification if necessary.If the overall length is not critical and if the internal thread is a match, then this may be your answer. Regards, Lionel |
Circlip | 14/10/2009 11:42:17 |
1723 forum posts | Ahhhh, the Thotter plickens, as you've now mentioned plotter and pencil, as someone wi a bit of drawing office experience and an ingineer to boot (Although a paid up member of the FW society), main problem with graphite is you have to mechanically feed it through the "Nib", so to ensure that there is always some between the paper and the tip of the hypo you must have devised a fantastish feedback system??
Due to the flooding problem of the tube feed systems and ending up with ink all owert place despite years of developement, this is where the rollerball and felt tip systems score on plotters. O I, forgot the ink jet ones.
Regards Ian. |
Alex | 14/10/2009 15:07:40 |
4 forum posts | Hi Lionel As you rightly surmise the innards of the nozzle are pretty much standard technical pencil (although German-rather than Japanese) except a bit longer than usual - it's the dims of the outside that need to be different.
Hi Ian (Circlip) You are giving me far too much credit with the "fantastish feedback system??" I have just heard of one that might work! The main problem is getting the head/nozzle/nib thing in my sketch to fit. if that doesn't work then I consign the whole thing to the "well that didn't work bin"
The other thing to mention is... In this day and age, (when ink jets are cheap and available). Who in their right mind would want a pencil to work in a plotter. Probably just me. There's just something about a pencil line. I even do drawings for the ink jet and try to make them look like pencil.
cheers Alex |
Ian Abbott | 14/10/2009 19:08:23 |
![]() 279 forum posts 21 photos | Dare I suggest grey ink?
Otherwise, what exactly is the mounting like. Ours was a plastic circular clamp about 3/8" i.d., with a pinch screw and no clearance issues above it.
One potential problem is that the pen or cutter, whichever is installed, lifts between marks, so whatever is used must have a retaining system for the graphite powder or lead for whilst the plotter lifts as well as the feed.
If your plotter works like this, a ratchet could be incorporated between the pen holder and the body, using the lift to operate it.
Ian |
Alex | 15/10/2009 15:39:56 |
4 forum posts | Thanks for all the help and suggestions - BUT
I have just heard that the auto advancing mech I was planning to use does not work very well! - So I am going to have to review the design of the little part i need making to suit an alternative - I am going to try one from Faber Castell in Germany
."The Faber-Castell features a feed mechanism which advances the lead automatically as you write. No shaking or button-pressing required! " "
I am going to check this out and make a new drawing - So project on hold for now.
Thanks for all the suggestions. I would like to enlist help again in the near future if it's not a bother to you guys.
cheers
Alex
alex bonnar | 05/11/2012 14:22:49 |
4 forum posts | just recently joined so uncertian as to correct forum, i am building model aroplanre engine 1st one steel quoted for crankshaft is en30b uanble to source ssmall quantity can any one suggext alternative thanks alex |
JasonB | 05/11/2012 15:50:35 |
![]() 25215 forum posts 3105 photos 1 articles | EN24 will probably do. M-machine sell small amounts Whats the engine you are making as someone who may have made it could give a better answer. Also best in future to create a new topic rather than tag it onto an unrelated post. J Edited By JasonB on 05/11/2012 15:52:12 |
alex bonnar | 05/11/2012 15:57:07 |
4 forum posts | thanks jason should have posted more details, have posted website sent nice gentleman e-mail for further info but as usual they got you money and they dont want know. the one im working on is wt1620 |
Springbok | 05/11/2012 16:40:05 |
![]() 879 forum posts 34 photos | Hi have still got a few of these rotaring bits if you want them bob |
