Member postings for LionelGedling Goodwin
Here is a list of all the postings LionelGedling Goodwin has made in our forums. Click on a thread name to jump to the thread.
Thread: You might be able to help me
14/10/2009 00:29:56
Hi Alex,
I also am not an engineer (yet) but it looks to me remarkably like the end of a Pentel P205 0.5mm clutch pencil. The overall length is only 21mm and the outer body shape is two tapers totalling 16.1mm in place of the 8mm and 12 mm length sections.  The 4mm section is an exact match with 0.8mm outside diameter and 0.5 mm inside diameter.
No doubt the cone could be turned down to your specification if necessary.If the overall length is not critical and if the internal thread is a match, then this may be your answer.
Regards, Lionel
