For Jan Ridders engine
The Real Ron Skingley | 29/09/2023 13:22:59 |
46 forum posts 2 photos | Hello from Ireland Ron |
JasonB | 29/09/2023 13:48:50 |
![]() 25215 forum posts 3105 photos 1 articles | Any reason you can't use a slice of round bar? Someoen like M-machine may well be happy to cut you a thin slice from square or round brass but you may have to pay a small premium over the typical 1" length increments they generally sell by, drop them an e-mail. If you can use something other than brass then a Stuart Progress flywheel casting can be bought from them, look under spare parts. |
The Real Ron Skingley | 29/09/2023 14:26:30 |
46 forum posts 2 photos | Thanks for that. |
SillyOldDuffer | 29/09/2023 16:39:55 |
10668 forum posts 2415 photos | Mine was entirely made from 5" x ¼" Aluminium flat bar - base, top and flywheel. I found plate easier to slice to size than round bar - 5" round stock is too big for my band-saw and challenging to part off on the lathe. An electric jigsaw cuts ¼" Aluminium no bother, and it could have been hand sawn. I sawed squares, converted them to octagons, and rounded off on the lathe. The base-plate was superglued to a mandrel, but top plate and flywheel can both be gripped through centre holes. The spokes were milled - easy with a rotary table. Bought some Brass a few months ago and still haven't got over the shock! Ouch. Aluminium is considerably cheaper than Brass and my engine runs well with an Aluminium flywheel. I've an idea the plan specifies Aluminium. Could be because the engine's power output is extremely low and a Brass flywheel might be too heavy for it. Dave |
The Real Ron Skingley | 29/09/2023 18:36:58 |
46 forum posts 2 photos | Thanks Dave, Yes I keep looking round the kitchen at all the ally things and wondering......
Edited By The Real Ron Skingley on 29/09/2023 18:37:43 |
bernard towers | 29/09/2023 18:59:05 |
1221 forum posts 161 photos | go round your local ind est and look for engineering places and walk in with your drawing and ask if they could help with materials or info, its surprising how accommodating people can be. |
The Real Ron Skingley | 29/09/2023 19:12:14 |
46 forum posts 2 photos | Nice idea. |
bernard towers | 29/09/2023 20:49:14 |
1221 forum posts 161 photos | Sorry Ron there are small engineering companies everywhere you just have to find them. |
Michael Gilligan | 29/09/2023 21:34:17 |
![]() 23121 forum posts 1360 photos | Ron I have no idea what there Irish operation is like, but I have in the past had excellent service from Richard Austin Alloys … they don’t seem to publish lists on the web, but they do, inevitably, have off-cuts of various materials and I purchased a good off-cut of Aluminium Tooling Plate from the Manchester branch. I would suggest you give the Dublin branch a call … not ‘bargain basement’ prices, but realistic. MichaelG. . **LINK** https://raaltd.com/branch/ireland/ |
The Real Ron Skingley | 30/09/2023 07:00:25 |
46 forum posts 2 photos | Posted by bernard towers on 29/09/2023 20:49:14:
Sorry Ron there are small engineering companies everywhere you just have to find them. Not in Bantry, Skibbereen, Clonakilty, or even Kenmare in Kerry. |
The Real Ron Skingley | 30/09/2023 07:09:18 |
46 forum posts 2 photos | Posted by Michael Gilligan on 29/09/2023 21:34:17:
Ron I have no idea what there Irish operation is like, but I have in the past had excellent service from Richard Austin Alloys … they don’t seem to publish lists on the web, but they do, inevitably, have off-cuts of various materials and I purchased a good off-cut of Aluminium Tooling Plate from the Manchester branch. I would suggest you give the Dublin branch a call … not ‘bargain basement’ prices, but realistic. MichaelG. . **LINK** https://raaltd.com/branch/ireland/ Thanks Michael, I'll try them. |
JasonB | 30/09/2023 07:18:56 |
![]() 25215 forum posts 3105 photos 1 articles | I've built a couple of engines for a guy in near Skibbereen and he also says it is hard to get anything for when he builds the smaller engines |
The Real Ron Skingley | 30/09/2023 07:26:57 |
46 forum posts 2 photos | It is very difficult. Edited By The Real Ron Skingley on 30/09/2023 07:35:05 Edited By The Real Ron Skingley on 30/09/2023 07:36:03 Edited By The Real Ron Skingley on 30/09/2023 07:36:37 |
larry phelan 1 | 30/09/2023 08:55:00 |
1346 forum posts 15 photos | There used to be a supplier based in Dublin, with a branch in Cork, who stocked Ali, Brass, Plastic, ect ect. Sad to say, they closed down a year or two back, maybe due to the Brexit cock up, so getting almost anything here now is "difficult" to put it mildly. Has become a case of mend and make do. As you say, tractor parts, now that,s another matter, to be sure, to be sure ! Perhaps that,s why there are no "local" clubs over here. If you want to do any machining around here, you are on your own ! |
Circlip | 30/09/2023 09:09:28 |
1723 forum posts | Late mate of mine decided to build a 'Simplex'. Already started a Black Five but gave that away when he moved house from southern England to Cebu - Philippines. Think you have problems sourcing materials? He completed it but then had a problem obtaining COAL. Coals to Newcastle became coals to Cebu. Regards Ian. |
Howi | 30/09/2023 09:11:11 |
![]() 442 forum posts 19 photos | Jan ridders designs are superb, just be aware that you MUST use the materials he spcefies. Deviate from his plans at your peril. I now await your future posting on how to get it to run...... good luck Howi |
The Real Ron Skingley | 30/09/2023 09:31:56 |
46 forum posts 2 photos | Thanks Howi, and everyone. |
larry phelan 1 | 30/09/2023 10:43:50 |
1346 forum posts 15 photos | You should know by now that bus and/or train services are not intended to work together, sure what use would that be ? Next thing, you would expect them to run on time !!!! Not at all, they are not there for your benifit, or mine. I just remembered, that company I mentioned was called James Healy, but while Jimmy might still be with us, his company is not. There are a few small engineering companies around but there is a limit to what they can offer, depends what type of work they do. |
The Real Ron Skingley | 30/09/2023 10:49:15 |
46 forum posts 2 photos | Ah, James Healy. Yes. Edited By The Real Ron Skingley on 30/09/2023 10:49:48 |
