moving a 1250kg bridgeport clone
Carl Farrington16/09/2023 13:50:35
47 forum posts
Hi all
I have bought one of Taiwan's finest - a King Rich KR-V2000.
I need to move it. I have read lots, but have a couple of concerns.
Firstly, my engine crane is only a 1T Clarke. But I could remove as much as possible from the mill first (head etc).
Plan is to hire a twin-axle braked plant trailer. I suppose I would try to remove the rear door/ramp and wheel the trailer under, then lower into trailer. If there is enough height. The documentation doesn't show height to the top of the ram which has the lifting eyelet on it.
I also have access to a pallet truck and have considered tying to it and winching up ramp of trailer. Could be sketchy though. I understand the single turning-wheel in the centre introduces instability and is a worry.
I also have skates, and a machine-lifting toe-jack. I am probably going to buy a roller pry bar to lift it.
The skates worry me a bit because it is two rear skates (which can be tied to each other with a bar, and then the front skate is a large one but it just has a central pivoting pad, which means the machine isn't supported on all four corners. The skate set is basically like this:
Steve Landylift is not available (he moved my lathe for me and was very good), and also a larger van (one with a tail lift that can cope with more than 500kg) will not get close to my workshop / garage, but the plant trailer will.
Simon Williams 316/09/2023 14:05:36
728 forum posts
90 photos
Machinery skates with a Bridgeport on top loading up a ramp onto a trailer. I hate to be the party pooper but you are right to think this is a mite iffy.
Know any farmers? With a nice chunky front loader on a big green tractor? One each end of your journey maybe?Much more re-assuring.
Otherwise there are specialist machinery movers - if you would like to indicate approx locations for start and finish of this adventure perhaps the combined knowledge of the forum can identify suitable alternatives to Mr LandyLift.
Carl Farrington16/09/2023 14:10:40
47 forum posts
Posted by Simon Williams 3 on 16/09/2023 14:05:36:
Yes I don't see it being pulled up a trailer ramp. Also the trailer that I was looking at appears to have the 'suitable for walk-on loading' ramp option on it. hmm. That's definitely not going to work. So my only DIY option currently is the 'raise in air and wheel trailer underneath'. If I have to buy or hire a 2T hoist then so be it.
There are many farmers around here but I don't think they will get around to the garage/workshop due to narrow driveway.
The locations are north west. From north Wales, to home which is in Kelsall near Chester.
Pete Rimmer16/09/2023 14:13:31
1486 forum posts
105 photos
Any floor that skates will rol over, will be just as suitable for pipe rollers and much less risky. I wouldn't bother much with a roller pry bar either, a normal prybar will be plenty god enough and you don't even need a full sized one. Just take plenty of packing/cribbing.
Is the V2000 really that much heavier than a Bridgy?
Carl Farrington16/09/2023 14:16:33
47 forum posts
Posted by Pete Rimmer on 16/09/2023 14:13:31:
Thanks. That should save me some money on the prybar then. OK I'll get some bar ready.
Yes they're 1,250kg. BP is 900kg I think.
Edited By Carl Farrington on 16/09/2023 14:19:07
Clive Foster16/09/2023 14:20:35
3630 forum posts
128 photos
Carl
Don't even think about a pallet truck.
As you surmise the close coupled pair of swivelling wheels at the handle end make things very unstable at the slightest provocation. I've seen a Bridgeport overturn off a pallet truck when a turn was attempted on less than perfect ground. Very impressive bang. The mill appeared to survive but i didn't give it a close inspection and it was on its way to auction anyway.
A pallet truck is possibly acceptable on a smooth, flat surface with wide sweeping turns but nowhere else.
When I moved mine I bolted sturdy timber H sections under the ends of the table and adjusted things so they just skimmed the ground. Inch or less clearance. So if things started to tilt the machine couldn't go very far and would sit at a stable, small, tilt whilst figuring out what to do next. Turned out to be a good idea when mine, not unexpectedly, tilted towards the lawn where the path made a right angle off camber turn. Having already laid a sheet of plywood "just in case" supporting things level whilst inching round the rest of the turn was simple pry bar exercise. The plywood suffered.
I shifted mine on a self made, super heavy duty dolly having a frame of 2 1/2" x 1" alloy bar with 4 heavy duty castors having 2 1/2" diameter by 2 1/2" wide wheels. Probably good for 3 tons or more. The small diameter wheels kept everything reassuringly low to the ground.
I took the head and ram off separately before moving which made a big difference. By far the easiest way to deal with the head is to arrange an R8 arbour on a stout foot that can be bolted to the table. Fit the arbor into the spindle then bolt the foot to the bed. After removing the bolts use the Y feed on the table to draw it off. Bring the table down to a sensible height and lift off. Reverse procedure to replace head when the mill is where it needs to go.
If you don't have a hefty dolly I've found that laying steel rod or stout, small diameter, pipe down rail fashion and sliding the machine along works much better than pipe rollers or skates. Especially if the surface isn't particularly good.
Carl Farrington16/09/2023 14:25:41
47 forum posts
Thanks Clive. I did see your picture and have read some of your prior posts on this sort of thing.
I could make a similar dolly, but what about getting it into the trailer?
This was the trailer I had in mind up to now:
Carl Farrington16/09/2023 14:26:59
47 forum posts
The surfaces at both ends are smooth by the way..
Carl Farrington16/09/2023 14:35:48
47 forum posts
I see what you mean about removing the head with the table - https://www.youtube.com/watch?v=HFE_nXQCH6E
Edited By Carl Farrington on 16/09/2023 14:43:06
Carl Farrington16/09/2023 15:26:45
47 forum posts
Actually Clive it's not your dolly I have seen, it was KWIL's.
Do you by any chance have pictures of how you bolted the wood H frame to the table?
Dave Halford16/09/2023 16:24:01
2536 forum posts
24 photos
There is another mover I have a recommendation for moving machines. | Model Engineer (model-engineer.co.uk)
Carl Farrington16/09/2023 16:39:01
47 forum posts
Posted by Dave Halford on 16/09/2023 16:24:01:
I have watched some of that chap's youtube videos before! I'll get in contact - thanks very much.
not done it yet16/09/2023 16:59:15
7517 forum posts
20 photos
First, I would be removing everything I could, to reduce the weight and height.
My next move would be to raise it sufficiently to get it on a large, sturdy, fully-boarded pallet. Secured properly, the pallet truck should be able to move it to the trailer - no real problem as the pallet only needs to be raised by a few mm.
Loading /unloading on/from the trailer depends.
I might expect the pallet could be pulled up some scaffold planks with suitable support beneath. The length and number would be longest and widest arrangement practical. If lift is adequate, the crane might be used, as you say, by moving the trailer under the machine, but safe slinging might be a problem?
I’ve shifted all manner of agri machinery, but never a bridgeport. Good luck, but be safe!
Clive Foster16/09/2023 17:14:27
3630 forum posts
128 photos
Sorry Carl, no pictures. 20 odd years back was the pre-smartphone camera era!
The H went on sideways with the cross bar vertical. I made the cross bar about the same width as the table, maybe a touch wider. Two struts joined with some off-cut OSB left over from building the workshop. Sidebars were maybe double or a bit more table width with the upper one suitably packed out to avoid the screw. Another piece of timber across the top of the table and two long bolts or all-thread and nuts ran through suitable holes to clamp the frame in position.
I imagine I used 2 x 2 timber, more left-overs from workshop build, possibly 2 x 3 for top clamp and bottom foot. Very much designed by eye and what I had lying around. No need for super strength as the idea is to stop the tilt before it build up enough to put any real load on things.
Jacking the table down so the H frames touched the trailer floor also stopped it rocking in transit so the straps had an easier life.
The mate who helped me with the move reckoned I was over-engineering as usual but I was much happier knowing the machine wasn't going walkabout.
Fulmen16/09/2023 17:23:04
120 forum posts
11 photos
I've moved an A&S Bridgeport a couple of times. Placed on a pallet, used a pallet jack and a winch to pull it onto a twin axle trailer. Not fun but doable back when my back wasn't completely fubar.
Martin Cargill16/09/2023 17:24:28
203 forum posts
How high off the ground is the lifting point? Most engine cranes do not have the height to lift a mill onto a trailer. I have a two tonne crane and it took a bit of mucking about to get the slinging and lift chain on the crane short enough to allow us to lift a Viceroy lathe onto a trailer (pushing the trailer under the crane once the lathe was lifted). Remember to hitch the trailer up before loading it.
Be careful as well because stripping bits of the mill to reduce the weight will change the centre of gravity and you may end up with the lifting point not being at the correct point for the lift being made.
Martin
Carl Farrington16/09/2023 17:36:23
47 forum posts
Posted by Fulmen on 16/09/2023 17:23:04:
In terms of that method, I'd expect the pallet jack to go up the trailer ramp backwards best - big wheel first, but then there's that possibility of the pallet and load sliding off the forks. Which way round did you do it?
Also I do have the issue of the ramp being 'for walk-on loading', rather than 'drive machinery on'. It's a builders trailer. I can pick other trailers but this one looks sturdy and not too wide for my spiral driveway, but it has that crappy ramp. I'm wondering how I can fashion a ramp to go over that one. I suppose long planks with varying thickness bits of wood underneath to support and raise.
I have contacted Ian anyway as per the recommendation here so I have my fingers cross for that
Carl Farrington16/09/2023 17:37:22
47 forum posts
Posted by Martin Cargill on 16/09/2023 17:24:28:
Martin
That is the one dimension that isn't in the KRV2000 PDF instruction manual. They show dimensions from bottom to top (including motor), which was 81" from memory. but doesn't show height of eyelet. I will ask the seller if they can measure for me.
Fulmen16/09/2023 18:51:01
120 forum posts
11 photos
Posted by Carl Farrington on 16/09/2023 17:36:23:
I really can't remember. But if you reverse the jack while pulling on the machine you should be safe.
Pete16/09/2023 19:13:09
128 forum posts
If your going to move it as one single piece, then first lower the knee, slack the 4 head bolts off and rotate the head 180 degrees. On most or maybe all BP type mills, those tilt and nod gears are a bit fragile, take as much of the weight with your off hand to support the head as it's rotated around to lessen the load on that gearing. Place a wide wooden board or piece of plywood between the table top and the end of the motor that's now facing down. Raise the knee to just take some of the motor and head weight. Then set the knee locks. That lowers the center of gravity as much as possible and its how afaik all the new one's are shipped from whatever manufacturer is building them. Mine was shipped exactly like that.
Once anything is picked up with a pallet jack, the pallet can't slide off the forks. The jack starts out lowered to the bottom of it's lift range, the forks and front wheels get shoved all the way through the opening in the pallet and then the whole thing is lifted. The weight and the front wheels prevent the pallet from ever sliding off the forks.
