Dasqua tools?
Dave S28/08/2023 19:53:06
433 forum posts
95 photos
Evening all,
Contemplating some new micrometers, I need to measure 100 - 150mm range things more accurately/repeatably than with very-near callipers.
I don’t really have the budget for mitutoyo, and given M&W seem to be generic Chinese now I looked at the other options.
Noticed Dasqua brand - never heard of them, but seem to be cheap enough and claiming DIN compliance.
Anyone got actual experience with them?
not done it yet28/08/2023 20:03:40
7517 forum posts
20 photos
When I wanted a bit more ease of operation, I went directly to Arc Euro Trade. Unfortunately (afaIk) they only do digis up to 100mm.
John Hinkley28/08/2023 21:28:52
1545 forum posts
484 photos
i've no personal experience of the brand, but others on here have given favourable reports. Chronos have their 125 to 150mm micrometer at a sale price at the moment. 100 to 150mm don't seem to be available.
Chronos link
RDG don't do larger than 75 to 100mm ones, unless you want a six-piece set at £180 a pop.
RDG link
Dave Smith 1428/08/2023 22:09:12
222 forum posts
48 photos
I have their 0-25mm and 25-50mm versions, had no problems with them.
Baz28/08/2023 22:28:42
1033 forum posts
I have bought some Dasqua kit from Chronos and I am very pleased with the quality.
Huub28/08/2023 23:12:14
220 forum posts
20 photos
I have 4 Dasqua outside micrometers from 0..25 to 75..100 (From HBM Netherlands). These are absolutely not the quality of Mitutoyo but more than accurate enough for hobby use. I would buy them again without hesitating.
I also bought 4 Dasqua inside micrometers from 5..30 to 75..100 (From HBM Netherlands). I have returned the set because it looked like they where (mis)used/tested/unboxed and 3 of 4 micrometers didn't turn smoothly.
Dalboy28/08/2023 23:19:27
1009 forum posts
305 photos
You would need to buy two Dasqua micrometers from Chronos 100mm-125mm and 125mm -150mm.
100-125
125-150
Dave S29/08/2023 07:12:11
433 forum posts
95 photos
Thanks all.
i am aware I’ll need a couple of micrometers to cover the range.
considering getting a full set, as I don’t have any metric mics at the moment
JohnF29/08/2023 09:22:52
1243 forum posts
202 photos
Dave may be worth a look at Amadeal, see shopping partners on here, I use imperial mostly but did buy a set 0 -100 mm form Amadeal and have to say the quality is amazing for the price, they were about £40 when I bought them, now £55
However they seem to do larger sets by other makers, at least a different design but there is a new set 0 - 200 at £168 which appear to be the same tools as the ones I purchased.
The Dasqua also look to be nice tools, some of the Eastern makes are IMO chunky and not "nice" tools, Dasque look to be fine in this respect ??
Just my thoughts !
Mike Hurley29/08/2023 09:44:49
530 forum posts
89 photos
I've got a couple of Dasqua tools (not Mics though) and very happy with the design and build quality for the price.
Taf_Pembs29/08/2023 09:59:21
126 forum posts
96 photos
I have a Dasqua surface plate (18" square ish) and it is really good for the price (it was very cheap !) but there is a 'feelable' mark about the size of a match head in 1 of the corners so I suspect it is someone else second .. perfectly usable and way more than flat enough for a workshop.
I also have a 0 - 150 depth mic and as has been said, by no means Mitutoyo but very good for the price, smooth and pretty well made.
John Doe 229/08/2023 10:03:00
441 forum posts
29 photos
I have bought some Dasqua rulers and a dial calliper so far.
All are CNC and laser cut, and very nice tools. The dial calliper is for my 3D printing and is nicely made. It is quick to read and there is no battery to run down, so my original callipers - which ate batteries - have stayed in their box ever since !
Cannot speak for accuracy and quality of Dasqua tools at accuracies below calliper level, but they generally seem well designed and made, and certainly worth considering.
SillyOldDuffer29/08/2023 10:10:08
10668 forum posts
2415 photos
Posted by Taf_Pembs on 29/08/2023 09:59:21:
Not necessarily a second. I recall surface plate standards allow a margin. Te flat surface doesn't have to be correct all the way to the edges, perhaps because margins are harder to grind perfectly and are prone to damage.
old mart29/08/2023 21:36:59
4655 forum posts
304 photos
I have an 8" digital height gauge and a 6" digital caliper of that make and can throughly recommend them. The Dasqua 6" digital caliper is as smooth as my Mitutoyo and Tesa's, larger numbers and 1/3 of the price.
Robin Graham30/08/2023 20:52:21
1089 forum posts
345 photos
I have a Dasqua 75-100mm mic. It seems nicely made - the action is very smooth. Checking with grade 1 gauge blocks it's good to the width of a graduation mark (2 microns?) over its range, so spot-on for practical purposes in a home workshop I'd say.
It's always worth having a look at G&M tools for second-hand measuring equipment. At the moment they have a 100-125mm Starrett mic up for £20 - without setting bar unfortunately, but likely a good instrument.
Robin.
Mike Poole31/08/2023 00:27:39
3676 forum posts
82 photos
I find Dasqua to be good value for money and was not disappointed with my purchases but you are not buying Starrett or Mitutoyo cheaply. M&W seem to have embraced an economy range which again seems to be value for money but is not the standard of their best tools from years gone by, I haven’t bought any of their high end range in recent times so don’t know if they have maintained their quality.
Pete.01/09/2023 06:27:23
910 forum posts
303 photos
Posted by Dave S on 28/08/2023 19:53:06:
Evening all,
No, two ranges of M&W micrometers are still made in Sheffield.
