For centering your mill
Chris Mate | 19/08/2023 19:26:55 |
325 forum posts 52 photos | Hi, Does anybody here owns or used a Diacator made by Dietest for centering a hole below your mill spindle, similar function to the coaxial centering indicators-? |
bernard towers | 19/08/2023 21:59:26 |
1221 forum posts 161 photos | Surely it’s a coaxial indicator by another name? |
DiogenesII | 20/08/2023 07:30:54 |
859 forum posts 268 photos | Looks like a good instrument - how much is it? If I had a choice between buying a co-ax indicator or a DRO, I'd buy a DRO. If you have a DRO you probably don't need a co-ax indicator. |
Michael Gilligan | 20/08/2023 08:04:53 |
![]() 23121 forum posts 1360 photos | I don’t … but Niels does [or did] : . |
Nigel Graham 2 | 20/08/2023 09:04:07 |
3293 forum posts 112 photos | Diogenes... I must be missing something here how do you use a DRO to set a work-piece to the centre of an existing hole without something between it and the rim of the hole? You still need some type of edge-indicator, whether you use a DRO or the handwheel dials. |
Robert Atkinson 2 | 20/08/2023 09:21:55 |
![]() 1891 forum posts 37 photos | The lever below the DTI translates sideways movement of the probe into vertical and pointer deflection. Robert |
Robert Atkinson 2 | 20/08/2023 09:24:30 |
![]() 1891 forum posts 37 photos | Looks like I was right. Google is your friend: https://swissinstruments.com/my_products/diacator/ Robert. Edited By Robert Atkinson 2 on 20/08/2023 09:27:18 |
Clive Foster | 20/08/2023 09:28:13 |
3630 forum posts 128 photos | Nigel Simple way uses the DRO zero and half functions with a solid rod in teh chuck as an indicator. Set up as best you can by eye. Choose an axis. Move until the rod just touches one side of the bore being centred. Zero the axis. Move until the other side just touches the rod. Hit the hard setting button. Move to zero which should be in the middle of that axis. Repeat touch off process and zeroing on other axis. Zero - zero should now be in the middle to within the error of your touch off process. Repeat process to verify before starting work. As touch off errors are opposite they tend to cancel out assuming your process is reliable. Generally feeling for drag as you rotate the spindle is good enough. An advantage of co-axial indicators is that they will show up non circular bores. The DRO method only finds the centre relative to the testing lines. Clive
DC31k | 20/08/2023 09:32:51 |
1186 forum posts 11 photos | A potential advantage of the co-ax indicator types used in a hole compared to a standard edge finder is that they will work at zero rpm. You can turn the spindle gently using one hand and see how the needle moves (even rotating it in discrete 90 degree increments if necessary). With an edge finder, it needs some powered rpm to see the wobble disappear and then observe the 'kick'. With a co-ax indicator, finding centre is quite a smooth single operation. Poke in the hole and adjust until the needle does not move and zero everything. With an edge finder, there are four (maybe six) distinct actions that have to be coordinated with DRO button pressing. Where a co-ax indicator might score is adjusting the height of a dividing head tailstock especially if you are setting it up to cut a taper. Could we come up with something a co-ax can do that a standard indicator and a mirror cannot do? |
bernard towers | 20/08/2023 09:35:41 |
1221 forum posts 161 photos | One of the big problems with a lot of commercial coax indicators is the amount of headroom required so if you have a small mill they can be impossible to use which is why I when the route of making my own. A nice satisfying project which gets used again and again. |
Brian G | 20/08/2023 09:51:41 |
912 forum posts 40 photos | I assume there must be something special to justify a price three times that of a Blake indicator and nearly twenty times that of generic ones? As it is used in the same way I cannot see it speeding up the operation enough to save much cost. Brian G |
Michael Gilligan | 20/08/2023 10:24:19 |
![]() 23121 forum posts 1360 photos | Posted by Brian G on 20/08/2023 09:51:41:
I assume there must be something special to justify a price three times that of a Blake indicator […] . Presumably a combination of ‘country of origin’ and claimed accuracy ’though I note that the certificate is unsigned ! MichaelG. . |
Andrew Johnston | 20/08/2023 11:17:32 |
![]() 7061 forum posts 719 photos | Posted by Michael Gilligan on 20/08/2023 10:24:19:
Presumably a combination of ‘country of origin’ and claimed accuracy ’though I note that the certificate is unsigned ! I have a Haimer Centro: Claimed accuracy is 2 microns not that I have any way of confirming that. The only problem is that (as Bernard says) it does need a fair amount of headroom. Andrew |
Chris Mate | 20/08/2023 16:34:39 |
325 forum posts 52 photos | I am looking at the different types to get a better picture of all. I also saw use of small lazer lights that just clip over spindle and shine a circle which you then position. Edited By Chris Mate on 20/08/2023 16:50:08 |
DC31k | 20/08/2023 17:20:15 |
1186 forum posts 11 photos | Posted by Chris Mate on 20/08/2023 16:34:39:
That brings me to a point after some thought, one could use this tool straight in the boring head and let it swing from there I might be misunderstanding you here, but I do not think that would work. The typical 50mm boring head has two vertical holes in it for the tools. One of those holes would have to be set (adjusted) concentric with the boring head's axis of rotation in order for it to be used to house a co-axial indicator (or even a standard edge finder). You could use a standard lever DTI in the manner you describe but not something where the dial always faces you and the mechanism rotates. When you use the point of the tool to find centre as you describe above, it is always a constant distance from the rotation axis. |
Michael Gilligan | 20/08/2023 17:41:40 |
![]() 23121 forum posts 1360 photos | Posted by Chris Mate on 20/08/2023 16:34:39:
. […] I also saw use of small lazer lights that just clip over spindle and shine a circle which you then position. . There was a long and interesting discussion about laser centring devices on here a few years back. … if you can’t find it, I will have a look later. MichaelG. |
Chris Mate | 20/08/2023 19:17:37 |
325 forum posts 52 photos | Hi Michael,
A)The Lazer device is called "CentreQuick" centering ..... Edited By Chris Mate on 20/08/2023 19:18:40 |
peak4 | 20/08/2023 19:30:20 |
![]() 2207 forum posts 210 photos | I was going to post a link to the excellent Dan Gelbart video, but came across this which has the video embeded. |
Michael Gilligan | 20/08/2023 19:32:33 |
![]() 23121 forum posts 1360 photos | Posted by Chris Mate on 20/08/2023 19:17:37:
Hi Michael, […] . That’s strange … I don’t recall asking a question MichaelG. |
John McNamara | 20/08/2023 22:42:17 |
![]() 1377 forum posts 133 photos | Re the image on the link in peak4's post |
