Speedy Builder5 | 15/08/2023 15:02:48 |
2878 forum posts 248 photos | I cam across this rule n with a load of clock making tools, but suspect it got there by something unconnected ?? Its a plastic rule with 2 scales one in cm/mm and the other in inches and 1/16". At one end is a clear plastic 'reticule' with a raised point in t5he centre. The reticule can rotate 360 degrees in the body of the rule. At the same end, the end of the rule is marked in degrees 0 - 75 in 15 degree increments. At the other end, there is a mark to indicate the centre line of the rule. A clear lockable/sliding plastic cursor can be positioned up and down the scale and there are two "pencil point " holes that are 1" apart. By pressing down on the reticule and inserting a pencil in one of the hole, an arc can be swung once the cursor was locked in position. By locating the reticule on to a point on a line, the rule can be swung to an angular position and a line drawn through its origin. The maker was TRIMAN Ltd ref 1001 So what was its intended use ? |
Mark Simpson 1 | 15/08/2023 15:36:09 |
115 forum posts 30 photos | Something very similar is still on sale from Ajax Scientific and others, it's a ruler, compass and protractor all in one... Aimed at middle school children apparently... search for TRIMAN OPAQUE RULER/COMPASS in your search engine of choice... Edited By Mark Simpson 1 on 15/08/2023 15:36:21 |
KWIL | 15/08/2023 15:36:27 |
3681 forum posts 70 photos |
Product Features:
Speedy Builder5 | 15/08/2023 16:00:10 |
2878 forum posts 248 photos | that is that one solved - mental note - Must start drawing more triangles ! Thank you gents. |
Michael Gilligan | 15/08/2023 18:16:50 |
![]() 23121 forum posts 1360 photos | Given where you found it … I think it might be worth exploring whether it could be a convenient aid to sketching the layout of clock wheel trains. MichaelG.. |
JasonB | 15/08/2023 18:29:09 |
![]() 25215 forum posts 3105 photos 1 articles | I used to have one of those when I was at school, may have just used it for geometry (maths) work. I suppose these days it should be safer than a compass if not as good. |
Russell Eberhardt | 15/08/2023 20:15:44 |
![]() 2785 forum posts 87 photos | Posted by JasonB on 15/08/2023 18:29:09:
