Harmonograph
JimmieS30/07/2023 19:37:00
310 forum posts
My granddaughter will soon be starting her 'GCSE' year and is thinking of making a harmonograph as her practical project. Any advice, guidance and/or hints on the project would be much appreciated
Jim
Michael Gilligan30/07/2023 19:49:29
23121 forum posts
1360 photos
Vague ‘folk-memory’ tells me that there was [once upon a time, I know not when] a constructional article in Model Engineer.
Peter Greene30/07/2023 20:32:13
865 forum posts
12 photos
Go here and download the March 1952 edition of Practical Mechanics (and any others that take you fancy). It was also published in one of the (two) Practical Mechanics How to Make it Books.
Speedy Builder530/07/2023 20:34:07
2878 forum posts
248 photos
its all out there. The difficult bit is not to plagiarise anything you find on the net.
Harmonograph
noel shelley30/07/2023 20:57:33
2308 forum posts
33 photos
One was shown at the midland mex a few years ago, and it was I think on The tube. Dubious engineering then add harmonograph might find it. Noel.
Dick H30/07/2023 22:31:58
141 forum posts
At risk of suggesting the blindingly obvious, try searching Harmonograph. One of the links Model Engineer 1960 vol 3087, p.300 even has plans for a pendulum version.
DiogenesII31/07/2023 06:48:42
859 forum posts
268 photos
A useful historical discussion /instructions here;
1920-1930.com.. ..Things To Make.. ..Harmonographs..
Michael Gilligan31/07/2023 07:04:30
23121 forum posts
1360 photos
Posted by Dick H on 30/07/2023 22:31:58:
I guess that would be the one I half-recalled
Journeyman31/07/2023 09:43:56
1257 forum posts
264 photos
I can remember making harmonographs at school to show off on an open day (an awful lot of years ago). Made two different versions, one with two pendulums and one with a compound pendulum. The twin pendulum version had a wooden frame, basically a plank with two square holes in. Tthe pendulums were simply steel rod about 3/8" dia 30" below the pivot and about 6" above. The pivots were fabricated from steel bar and rod to form a collar which clamped to the pendulum rod by a bolt in a tapped hole. The pivots were knife edges located in a groove made as i recall by simply filing the edge of a steel bar and a groove cut on a shaper. the bar was brazed onto the collar before drilling the centre hole through the collar and bar. Large lumps of 2" rod were drilled through for the weights again just a tapped hole for a bolt to allow adjustment up and down the rod. The fixed side of the pivot was fixed to a plate which fitted to the frame.
One of the pendulums carried a table fixed to the top and the other a rod to hold the pen suitably counterbalanced. The pendulum with the table swung fore and aft whilst the pendulum with the pen swung left and right. By suitably adjusting the weight up and down different swing periods could be set up.
The single compound pendulum worked much the same but with a shorter main pendulum with another bob on a short rod suspended at the end of the main pendulam rod by means of a short length of fine chain. The arm with the pen was fixed to the table and just pivoted up and down.
Both machines worked quite well as I recall and produced a suitable selection of Lissajous figures duly affixed to the classroom wall. All good fun and I might even have learned something from the exercise. I least I can still remember the basics after nearly 60 years.
P.S. Saw a harmonograph being demonstrated at The Midlands Show in 2018
Found a link to a Video of the one at Midlands *** LINK ***
Edited By Journeyman on 31/07/2023 09:46:59
Edited By Journeyman on 31/07/2023 09:49:40
Nicholas Farr31/07/2023 10:15:40
3988 forum posts
1799 photos
Hi, I've got a copy of the Practical Mechanics of March 1952, which is one of bundle of those that my father bought.
Regards Nick.
Bazyle31/07/2023 12:00:20
6956 forum posts
229 photos
Couple of points.
Make the weights out of water bottles so that there is less bulk to move and store and adding a variable.
Don't make the bearings too low friction so they just go on for ever. Children will want things to come to an end fairly quickly.
Peter Greene31/07/2023 18:15:48
865 forum posts
12 photos
Posted by Bazyle on 31/07/2023 12:00:20:
... not to mention that if the friction (bearings and writing point) is too low you won't get those nice harmonograph patterns. It'll just keep scribing the same path over and over.
Ed Dinning 131/07/2023 21:43:45
39 forum posts
Hi, there were a couple of designs in the 9/10 set and supermodels leaflets associated with Meccano in the 40's/ 50's.
These may be available on line
Ed
Nigel Graham 231/07/2023 23:14:40
3293 forum posts
112 photos
If the harmonograph cited here is the one I think it is, with two pendulums (pendula?), its owner has exhibited it at 'The Fosse' a few times now.
It is a lovely piece of work!
Tendor01/08/2023 06:57:34
39 forum posts
5 photos
Here's an old book, available online.
"Harmonic Vibrations and Vibration Figures" by Joseph Goold. 1884.
https://archive.org/details/dli.ministry.13780/mode/2up
or... Internet Archive link
Edited By Tendor on 01/08/2023 06:58:08
Michael Gilligan01/08/2023 08:20:27
23121 forum posts
1360 photos
Thanks for the link, Tendor yes
… The author’s wishes have been granted [ see PREFACE ]
JimmieS01/08/2023 08:58:38
310 forum posts
Many, many thanks to all who have provided advice, suggestions and guidance. Now it is time for her to get down to work and get her draft submissions ready for the teacher's decision at the start of term.
Jim
