NVR Switch no longer staying on...
IanT | 25/07/2023 23:31:11 |
2147 forum posts 222 photos | Recently, I was using the Myford and everything was fine. I'd turned the lathe off to change something and when I went to turn it back on, the lathe spun up but died as soon as I removed my finger from the green 'On' button. So I removed the NVR switch and wired the lathe direcly to a 13A plug and switched it on. The lathe started normally as far as I could tell and ran OK. Assuming the 'on' coil might be damaged (in the NVR switch) I found another switch on Ebay and ordered a replacement. It arrived yesterday and I fitted it this morning. No change, the fault remains the same. Had a think about this and decided that the emergency stop button hadn't been eliminated, so went down later and removed that from the circuit by shorting it's wires together. Nothing changed. So I'm back to wondering about the motor. It's a centrifugal switch (not capacitor start) kind and I can hear it click out as the power is removed but the 'on' coil must be unhappy about something. Any thoughts or suggestions for further tests? I've had this NVR switch fitted for some years now, so something has clearly changed. Think I probably got it from Axminster but it was a while ago now but the NVR (KJD17) switch itself is pretty generic... Regards,
IanT
David George 1 | 26/07/2023 07:50:56 |
![]() 2110 forum posts 565 photos | It sounds like a wireing problem with the NVR switch. On some switches you hsve to put in a link from live to coil power and it is possible the wire has a break inside insulation. Check wiring diagram and wires end to end. David |
Emgee | 26/07/2023 07:56:43 |
2610 forum posts 312 photos | Have you checked any limit switches fitted for correct operation, such as a chuck guard switch ? Emgee
DC31k | 26/07/2023 08:10:47 |
1186 forum posts 11 photos | Wire old and new NVR switches into a lightbulb and verify their correct operation or confirm dead with red and green buttons. Also verify NVR capability by turning off and back on at the wall socket. |
IanT | 26/07/2023 08:35:32 |
2147 forum posts 222 photos | Doubt it's a wiring problem as the NVR has been fine for some years and was working OK just before the problem occured. It's a Mk1 Super 7, so no limit switches etc are fitted connection is direct to the motor. I'll connect the NVR to a different load and see if it shows the same fault. Just off to see our newest Granddaughter today and it's a long round trip, so this will have to wait until tomorrow now. I'll report back then... Thanks for help everyone. Regards,
IanT |
noel shelley | 26/07/2023 09:33:56 |
2308 forum posts 33 photos | The stop button and emergency stop are a NC contact check this. Many after market NVRs are not of the highest quality or built to industrial standards. If you think the motor is at fault then check both start and run windings for continuity, then run thhe motor (lathe ) for a while and let it warm up. If the motor is OK then it can only be a simple fault. Broken wire, loose screw or terminal, incorrect wiring or a faulty NVR, check all wiring from the plug to the motor. Good Luck, Noel. |
Samsaranda | 26/07/2023 09:50:45 |
![]() 1688 forum posts 16 photos | Had the same problem with my Champion mill last week, motor would only run with the green button on the NVR held in. Changed the NVR but the same problem, eventually found that the problem was with chuck guard micro switch. Dave W |
Robert Atkinson 2 | 26/07/2023 10:32:57 |
![]() 1891 forum posts 37 photos | Any chance of a picture of the rear of the NVR/E-Stop and wiring? Robert. |
Nicholas Farr | 26/07/2023 11:09:48 |
![]() 3988 forum posts 1799 photos | Hi IanT, if the motor runs while holding the green button down, or that you have wired it directly, then I very much doubt there is anything wrong with the motor. The start/stop button is not latching, and I agree with what Robert has said. Regards Nick. Edited By Nicholas Farr on 26/07/2023 11:10:10 |
IanT | 31/07/2023 13:00:45 |
2147 forum posts 222 photos | Sorry for delay, been off-line for a few days busy with trips away etc. I did manage to fugure this out. The original NVR switch had four connections, two inputs and two outputs. The coil was simply across the output connections (live & neutral) so that when the green button was pressed, the coil latched. In my set-up there is also an emergency botton, which was originally wired in series with the live input. The new NVR switch has five connections, apparently the same as the original four connector version but with the addittion of an 'A1' pin. I was somewhat misled by an older thread (on another forum) suggesting this pin was an "optional" connection for some types of motors. That is certainly not true of my switch. I metered (tested resistance) across all connections on both switches. I could still 'see' the coil across the ouput connections on the old switch (so it had not gone open circuit) but it was clearly no longer functional. When I looked at the new switch, it became obvious that the coil was just wired across the 'A1' and one O/P connector. I connected the mains (live & neutral) to the two I/P connectors and the motor to the matching O/P connectors. A connection was then made from 'A1' ( via the emergency switch) to the coil side of the O/P. This is probably an improvement on the original set-up, as the emergency switch is now in series with the coil, rather than the full motor current. I haven't named the connectors, as my switch numbering appears to be different to others mentioned elsewhere. The key is to establish where the coil is connected and wire up accordingly. The new set-up now works exactly as before and the old NVR switch has been consigned to the bin. Regards,
IanT Edited By IanT on 31/07/2023 13:02:15 |
