Steve Crow | 09/07/2023 12:04:47 |
429 forum posts 268 photos | Apologies if this link has already been posted. Steve |
Bill Davies 2 | 09/07/2023 13:22:24 |
357 forum posts 13 photos | All the machines where I worked were green or grey, to the extent that I've never wanted green in my life subsequently. The walls were green, too."Restful" was the supposed logic in the use of green. Although, as a chind, older peoples' kitchens were always painted green or brown (or two-tone both). Bill |
Samsaranda | 09/07/2023 13:48:39 |
![]() 1688 forum posts 16 photos | I remember that when I was in the Forces, rooms were predominantly painted Eau de Nil as it was psychologically supposed to be the most relaxing colour. Can’t stand that colour now. Dave W |
Dave Wootton | 09/07/2023 15:27:08 |
505 forum posts 99 photos | I worked at a small engineering works which had some old but wonderful machines, Holbrooks, Thiel mills, and other quality machines in there original paint. We all went away for two weeks for the annual shutdown, returning to find the new so called " Millwright" had daubed all the machines in the shop I worked in a hideous mid blue, his idea of an overhaul. I can still recall the horror on entering the workshop on the first morning back, and the look of thunder on the works managers face. The change of colour and the pitiable appearance of the machines really put me off the job and changed the whole outlook of the working environment, I left soon after. Since that time I've had a horror of machines repainted in mid blue! |
larry phelan 1 | 09/07/2023 17:26:59 |
1346 forum posts 15 photos | Perhaps Mr Ford got it right when he said, "You can have any colour you like, as long as it,s black " I dont see why the colour should be an issue ,but I would prefer something easy on the eye Most of the old machines I ever saw were painted black, sure to get you off to a good start on a cold morning. My own lathe is painted a sand colour, which is easy enough to live with, not so keen on those red or blue, or green ones.. |
Ady1 | 09/07/2023 17:33:58 |
![]() 6137 forum posts 893 photos | The cockpits of spitfires were green because you stayed calmer with that colour around you as bullets knocked lumps from your aircraft Allegedly |
john fletcher 1 | 09/07/2023 17:51:46 |
893 forum posts | Well when I was in the forces all the tents were the same colour, bleached, and the flies were like sparrows. John |
Chris Pearson 1 | 09/07/2023 17:56:48 |
189 forum posts 3 photos | When I am machining something, I tend to look either at the cutting tool or the dials (I do not have a DRO), so the colour is immaterial. The walls of my workshop are magnolia, or something approaching it. I feel sure that a light colour is appropriate for better lighting. Any study of this type needs to be very well controlled to avoid a Hawthorne effect. |
Vic | 09/07/2023 18:39:24 |
3453 forum posts 23 photos | When I worked as a car mechanic it was easier seeing what you were doing under the bonnet of a white car. I therefore agree with the sentiment in the article. I like the slightly off white of some machines and pale green is nice as well. Mid blue is for Record Vices and nothing else! |
Bazyle | 09/07/2023 19:42:45 |
![]() 6956 forum posts 229 photos | While I like to repaint a machine in a close approximation to original I also include a significant area in a very non standard colour to deter thieves. It might detract from its resale value - until I point out the reason. If I could easily paint polka dots that would be good. |
