Chuck Taper | 29/06/2023 12:54:30 |
![]() 95 forum posts 37 photos | Acquired the following recently: Unfortunately some teeth on the gear (pinion?) portion are damaged which cause the rack on the barrel to foul - preventing any useful operation. Can anyone direct me to information re the specifications for the gear teeth? Thanks in advance for any help. Regards Frank C. Edited By Chuck Taper on 29/06/2023 12:55:44 |
Michael Gilligan | 29/06/2023 15:21:04 |
![]() 23121 forum posts 1360 photos | Sorry, not at the moment, Frank … but I can tell you that it is the Cowell design [ not to be confused with Cowells, who make the little lathe ] MichaelG. |
Phil P | 29/06/2023 15:23:41 |
851 forum posts 206 photos | I have the same capstan attachment and have always assumed it was Cowells lathes that made them. Every day is a school day. Phil |
DC31k | 29/06/2023 15:53:54 |
1186 forum posts 11 photos | The handwheel is graduated. What is the total travel for one revolution? Divide that number by the number of teeth on the gear and it tells you the circular pitch of the gear. There is a relatioship between circular pitch and diametral pitch. Measure the OD of the gear. There is a relationship between diametral pitch, number of teeth and OD. The two methods should arrive at the same answer. 'Gears and gear cutting' by Ivan Law is the de facto model engineering reference work. Edited By DC31k on 29/06/2023 15:54:35 |
Ian P | 29/06/2023 15:59:43 |
![]() 2747 forum posts 123 photos | My goto solution when identifying gears is the HPC catalogue Link to their catalogue request page Ian P |
Michael Gilligan | 29/06/2023 16:11:21 |
![]() 23121 forum posts 1360 photos | Posted by Phil P on 29/06/2023 15:23:41:
I have the same capstan attachment and have always assumed it was Cowells lathes that made them. Every day is a school day. . ’ere we go : **LINK** http://www.lathes.co.uk/cowellkitlathe/ I bought my tailstock unit from Mr Mole [N Mole &Co. of Watford] long, long ago … and he made a point of mentioning that it was a local firm that made them. MichaelG. . Ref. __ The tailstock featured a quick-action, rack-driven 2-inch travel spindle, this assembly also being offered an accessory (with a 4-spoke capstan) for a range of small English lathes. Edited By Michael Gilligan on 29/06/2023 16:15:07 |
Chuck Taper | 29/06/2023 16:34:36 |
![]() 95 forum posts 37 photos | MichaelG Cowell was what I was missing - I knew the item had a designation but there was an void in my brain. I'm hoping to work out the specification of the gear and possibly find something that can be engineered to replace the damaged piece. Hopefully measurement and first principles should allow me to work these out. The Internet has not (as of this note) yielded anything detailed in the way of exactly what I need without making any effort......etc.* Although following your Cowell suggestion, this turned up Link - [ https://www.model-engineer.co.uk/sites/7/documents/myfordracktailstock.pdf ] - which is at the very least a read. Regards. Frank C. * DC31k that what I'm talking about. Thanks a mill.
Edited By Chuck Taper on 29/06/2023 16:38:16 |
david bennett 8 | 30/06/2023 21:29:54 |
245 forum posts 19 photos | Here's a long shot request - does anyone have a Cowell-kit-lathe headstock casting that they might sell? (I have all the other castings.) dave8 |
Nigel Graham 2 | 30/06/2023 22:07:12 |
3293 forum posts 112 photos | Identify the pinion DP etc and it may be possible to find a stock one you can modify to fit the existing or a new spindle, accepting that the existing component is a single piece of steel.. |
Kiwi Bloke | 01/07/2023 07:04:09 |
912 forum posts 3 photos | Sorry, late to the party - had to do some serious excavating to find this. The following dimensional info is taken from an old Cowell blueprint, with my notes, in addition. Imperial dimensions. The pinion, its shaft and the capstan boss are all machined from one piece of mild steel. Pinion OD 1.034 - 1.031". 24T X 1/8" CP. Wire = 0.083" dia. Measurement over wires = 1.099 - 1.097" Hope this is enough info. PM me if you'd like a pic of the plan, but beware, the quality is rather poor. Edited By Kiwi Bloke on 01/07/2023 07:08:22 |
Michael Gilligan | 01/07/2023 07:12:15 |
![]() 23121 forum posts 1360 photos | You are a Star, Kiwi Bloke an actual specification, to identify the pitch circle ! MichaelG. |
DC31k | 01/07/2023 07:45:21 |
1186 forum posts 11 photos | Posted by Michael Gilligan on 01/07/2023 07:12:15:
an actual specification, to identify the pitch circle ! The over-pins measurement is usually used as an inspection method, but it is useful here to identify the pressure angle, which we do not yet have. Two gears of the same circular pitch and tooth count but differing pressure angles will have the same OD and same pitch circle diameter but will not have the same over-pins measurement. I cannot find a really handy reference just now, but this one should be enough to start: https://gearsolutions.com/departments/tooth-tips/determining-tooth-thickness-of-various-gear-types-part-iii/ There are also a few online calculators where you enter the information you know and it gives you that which you do not. Searching on 'pressure angle from over pins measurement' might find something suitable. --- Since the question was originaIly posted, it turns out that the answer was here already in this old thread: https://www.model-engineer.co.uk/forums/postings.asp?th=98925&p=2 a post by CotswaldsPhil 20/08/2014 17:40:18 confirms the specification as 1/8" circular pitch and 24 teeth. |
JasonB | 01/07/2023 07:50:09 |
![]() 25215 forum posts 3105 photos 1 articles | Bit of CAD to draw the gear and a couple of circles representing the wires and you should be able to confirm the pressure angle. |
Michael Gilligan | 01/07/2023 08:08:37 |
![]() 23121 forum posts 1360 photos | Excellent point, Jason That said: my ‘educated guess’ from just eyeballing the photo would be 14.5° MichaelG. |
Chuck Taper | 01/07/2023 11:48:33 |
![]() 95 forum posts 37 photos | Thanks to all who responded. The (collective) measurements supplied correspond closely to measurements taken from the item in my possession. So I now have the parameters of the gear and I can take a first pass at some sort of solution. I intent to remove the damaged gear teeth by turning and to then fit a bored out gear onto the shaft. The options being interference fit, locktite etc I have ordered an inexpensive gear on eBay with a view to machining it as a test case [ that being to ] bore out the centre hole to an interference fit. This can then be slid onto the turned shaft. If the gods are with me I can then put more effort into finding an item with exact specs.
So I have a new query. Is this approach rational or is the resultant gear likely to be too weak for the job it will have to do? Any and all views welcome. Regards. Frank C. Edited By Chuck Taper on 01/07/2023 11:48:43 Edited By Chuck Taper on 01/07/2023 11:48:48 PS - To hell with it let it line break wherever it wants!!!!!! Edited By Chuck Taper on 01/07/2023 11:49:58 |
DC31k | 01/07/2023 16:04:15 |
1186 forum posts 11 photos | Posted by Chuck Taper on 01/07/2023 11:48:33:
Any and all views welcome. If I click on the link to the drawing you have generated, it generates something with 3.195mm circular pitch. To the best of my knowledge, 1/8" is 3.175mm. If the wall thickness is too small, turn down the shaft 'above' it in the photo and sleeve it back up to fit the casting after the gear is installed. Not specific to your question, but something at least to investigate before removing any metal:- The handwheel is graduated. Do the graduations have or require any relationship with the clock position of the teeth of the gear? It would be maddening to put on the new gear and then find the zero mark does not line up the first time you go to use it. --- Jason's idea of using a CAD model of the gear to work out the pressure angle is in principle good. No complicated formulas involved. However, it is not clear how any particular CAD program represents an involute nor if any CAD program has the (snapping) facility to place a circle simultaneously tangent to two involutes. Let us hope the CAD program represents the involute by something that can be offset the radius of the pin. |
Michael Gilligan | 01/07/2023 17:34:51 |
![]() 23121 forum posts 1360 photos | Of course, the simplest way to check the pressure angle is to make a little gauge [or two, or three, or more] and check the angle of the Vees in the rack. MichaelG. |
JasonB | 01/07/2023 19:03:47 |
![]() 25215 forum posts 3105 photos 1 articles | 20pa looks like it fits the bill in Alibre, generate the gear, draw the wire, tangent to one side of a tooth and then tangent to another, mirror and measure.
14.5pa pushes the wires a bit further apart |
Andrew Johnston | 01/07/2023 19:28:26 |
![]() 7061 forum posts 719 photos | Given that the CP is rational then the DP has to be irrational. It is unlikely that an off the shelf gear will be found, so it will have to be made. CP = 0.125 DP = Pi/CP hence DP = 25.1327 or thereabouts, which fits nicely the OD specified on the drawing It is not clear if the boss below the gear allows a cutter at full depth to pass over it. I wonder if the teeth were formed by shaping? Andrew |
Nigel Graham 2 | 01/07/2023 19:46:37 |
3293 forum posts 112 photos | Your question of cutter clearance might yield to more drawing. There is a fairly wide run-out groove but as the rack teeth seem cut into the full cylinder, not a flat, the fall towards the rack teeth ends might clear any pinion gullets ending shallow anyway. |
