petro1head | 02/06/2023 15:08:38 |
![]() 984 forum posts 207 photos | Treated myself to a new SG iron vise from Arc Its very nice except the handle (see below) Bottom one came with the new vice Middle on came with the cheaper Versatile vice I am not complaining as i made my own handle, top. Just a pity for such a nice vice to supply a nast finished handle. Also for anyone thinking if buying the SG vice the handle is 12mm hex as oppsed to 14mm for the Versatile vice here |
Andrew Johnston | 02/06/2023 15:23:48 |
![]() 7061 forum posts 719 photos | What's wrong with the bottom handle? Looks similar, if slightly rougher, to the one that came with my Kurt machine vice, which works well for me. Andrew |
petro1head | 02/06/2023 15:35:06 |
![]() 984 forum posts 207 photos | Nothing wrong, just the finish |
JasonB | 02/06/2023 15:40:21 |
![]() 25215 forum posts 3105 photos 1 articles | Not hard to put it in the lathe and skim to a smoother finish if you have oft hands |
petro1head | 02/06/2023 16:00:08 |
![]() 984 forum posts 207 photos | Posted by JasonB on 02/06/2023 15:40:21:
Not hard to put it in the lathe and skim to a smoother finish if you have oft hands Oft hands? |
Nick Wheeler | 02/06/2023 16:07:51 |
1227 forum posts 101 photos | Posted by JasonB on 02/06/2023 15:40:21:
Not hard to put it in the lathe and skim to a smoother finish if you have oft hands A couple of minutes with coarse to fine emery cloth would remove the flash and give a good looking, nice to handle satin finish. |
petro1head | 02/06/2023 16:20:09 |
![]() 984 forum posts 207 photos | Posted by Nick Wheeler on 02/06/2023 16:07:51:
Not hard to put it in the lathe and skim to a smoother finish if you have oft hands A couple of minutes with coarse to fine emery cloth would remove the flash and give a good looking, nice to handle satin finish. Indeed but no need as i have a nicer handle |
not done it yet | 02/06/2023 17:34:42 |
7517 forum posts 20 photos | Guess you bought the smaller version - or your new parallels would need up-grading.🙂 I still prefer the type II, btw.😉 |
Robert Butler | 02/06/2023 17:47:06 |
511 forum posts 6 photos | The finish of the vice is critica, the handle finish so long as durable is irrelevant. Robert Butler |
old mart | 02/06/2023 18:12:26 |
4655 forum posts 304 photos | I know what is better with the redesign, you can spin the handle much faster. We have a 5" ARC vise and I find the handle fine for about one turn, but not so good if moving the jaw any distance. |
Clive Foster | 02/06/2023 19:56:27 |
3630 forum posts 128 photos | Never cared much for those folding joint handles. I know the theory is that the swivel joint gives you clearance between the handle and the end of the vice or milling table without the business end being over long. In practice they always seem to be at the wrong angle so a good deal of removal and re-fitting is involved when adjusting and final tightening the vice. Always seem to need two goes at tightening 'cos they are at exactly the wrong angle. I prefer the breed with a short offset socket and extension piece. The extension is permanently on my favourite Vertex wide opening, three nut position, vices so I can always twirl the handle. Clive |
Andrew Johnston | 02/06/2023 20:58:51 |
![]() 7061 forum posts 719 photos | I've never had much of a problem with the handle on my Kurt. It is heavy enough that if you give it a good swing it'll go round a few times on its own. That makes it quick to move the jaw some distance. Manufacturers choose the length of the handle to provide proper tightening without the risk of over-tightening and resultant damage. it seems that the nice new handle is rather shorter than the supplied handle so will be less useful in tightening the vice. Andrew |
petro1head | 02/06/2023 21:24:04 |
![]() 984 forum posts 207 photos | The one i made is based on this, same dimensions used by quite a lot of peple |
John Reese | 03/06/2023 00:12:34 |
![]() 1071 forum posts | Would that bottom handle perform any better if it were polished? |
petro1head | 03/06/2023 00:15:43 |
![]() 984 forum posts 207 photos | Posted by John Reese on 03/06/2023 00:12:34:
Would that bottom handle perform any better if it were polished? Nope |
Tony Pratt 1 | 03/06/2023 09:14:29 |
2319 forum posts 13 photos | Posted by Clive Foster on 02/06/2023 19:56:27:
Never cared much for those folding joint handles. I know the theory is that the swivel joint gives you clearance between the handle and the end of the vice or milling table without the business end being over long. In practice they always seem to be at the wrong angle so a good deal of removal and re-fitting is involved when adjusting and final tightening the vice. Always seem to need two goes at tightening 'cos they are at exactly the wrong angle. Totally agree! Tony
Hopper | 03/06/2023 09:25:01 |
![]() 7881 forum posts 397 photos | Might not the rougher finish provide a better grip for oily workshop hands? I do like your shop made crank though, with the extra short-throw hex hole for 'rapid traverse'. |
petro1head | 03/06/2023 09:28:00 |
![]() 984 forum posts 207 photos | Posted by Hopper on 03/06/2023 09:25:01:
Might not the rougher finish provide a better grip for oily workshop hands? I do like your shop made crank though, with the extra short-throw hex hole for 'rapid traverse'. Thanks
old mart | 03/06/2023 19:21:43 |
4655 forum posts 304 photos | An improved handle like yours is among the many "to do" modifications I have in the pipeline. Alan has already made a short radius handle for the Bison vises which will miss the Y axis handle on the round column mill when being turned. We now have three variations of handles for the 100mm Bison vises which get used most often. At the moment, the 5" ARC vise is being used exclusively on the round column to hold the new cross slide for the Atlas lathe which should be finished within the next 2 weeks. |
John Doe 2 | 04/06/2023 10:57:46 |
![]() 441 forum posts 29 photos | Posted by John Reese on 03/06/2023 00:12:34:
Would that bottom handle perform any better if it were polished? A pity though that a rough unfinished item is now considered good enough to sell, without caring what the customer thinks? Even the casting flashing has not been removed. |
