modeng2000 | 26/05/2023 11:57:42 |
340 forum posts 1 photos | What are my chances for bending 12mm square EN3B bright mild steel bar? I am aiming for a sharp 45 degree bend. Never done this before but have watched it being done but using oxy - acetylene. I have propane sievert burners and the usual bench vice but that is it. I have considered removing a V section on the inside of the bend and then silver soldering the joint but would prefer not to have to do this. John
bernard towers | 26/05/2023 12:12:55 |
1221 forum posts 161 photos | depending on what its use the cut and silver solder route would give you a sharper corner, or it could be big welded. |
modeng2000 | 26/05/2023 12:26:14 |
340 forum posts 1 photos | Thanks Bernard, it would also stop the spreading on the inside of the bend. Probably the best answer. John |
modeng2000 | 26/05/2023 12:38:35 |
340 forum posts 1 photos | I think I just wanted convincing the cut and bend method would give a nice corner, better than just a normal bend. John |
Ady1 | 26/05/2023 13:34:28 |
![]() 6137 forum posts 893 photos | It stretches the top part down and pinches the inner part out if you make it too tight I suppose there are calculations for these things, so the bend radius loses the minimum of strength Also depends upon the steel grade Edited By Ady1 on 26/05/2023 13:38:35 |
modeng2000 | 26/05/2023 15:28:13 |
340 forum posts 1 photos | Ady, thanks I don't want to loose the square of the bar at the bend. I am going for a partial cut removing a wedge and then close up before silver soldering. I may need a shim to take account of the saw blade width. John
bernard towers | 26/05/2023 16:10:02 |
1221 forum posts 161 photos | THis cut and shut idea is fairly common its quick and you don't need 3 hands! |
Mike Poole | 26/05/2023 17:04:40 |
![]() 3676 forum posts 82 photos | I think a blacksmith would upset the point where the bend is required to supply the material on the outside of the bend and then square everything up after bending. If you are after a bend that is very accurate the cut and shut is probably the most straightforward procedure, it could save some years of learning the craft of a blacksmith. Mike |
Grizzly bear | 26/05/2023 17:55:07 |
337 forum posts 8 photos | Hi, May I ask what is it for? Good luck............... |
Howard Lewis | 26/05/2023 17:56:22 |
7227 forum posts 21 photos | If you cut the bar ends at 22.5 degrees, bringing the two ends together should produce a 45 degree bend. Whethyer you chamfer (As weld prep. ) weld, braze, or silver solder, is your chioce, depending on what facilities you have available. Howard Edited By Howard Lewis on 26/05/2023 17:57:43 |
modeng2000 | 26/05/2023 20:06:04 |
340 forum posts 1 photos | I am having another go at making a diamond tool holder. my first problem was how to get a square hole. Well I fabricated it from two V shapes quite sucessfully. Broaching is quite out of my ability. So now I want to progress on to a good shape for the main body of the holder. I am going to try cutting at 22.5 degrees in one plane and a similar angle on the adjacent side. The aim is to leave a bridging piece that will be bent so holding the two halves together prior to soldering. There will might be a need for a shim to fill the saw cut if the two halves do not come close together. I know that there have been plenty of designs for this type of tool holder but I've not seen one made like this. So here's hoping for a good result. John |
Nick Wheeler | 26/05/2023 21:24:46 |
1227 forum posts 101 photos | How big is the hole you're trying to make I can't imagine a diamond tool holder that couldn't be made far easier by drilling a hole and filing the corners square. |
modeng2000 | 27/05/2023 07:05:22 |
340 forum posts 1 photos | Nick, the hole is 1/4" square. Your filing abilities must be better than mine as having tried filing a square hole I was not satisfied that a lathe tool would be held securely enough. So this is why I fabricated the making of a square hole. John |
JasonB | 27/05/2023 07:23:11 |
![]() 25215 forum posts 3105 photos 1 articles | I thought that most of these tools used a slot and separate clamping piece or other way to retain the tool in the slot rather than a square hole. Knowing what it is for now I think I would make from some 12 x 25 or so flat bar. Edited By JasonB on 27/05/2023 07:27:08 |
modeng2000 | 27/05/2023 07:39:34 |
340 forum posts 1 photos | Jason, the square hole would be split so that a clamping screw pulls the slit closed to hold the tool bit. This is really the same as having a separate clamp piece when gripping the tool bit. John |
jaCK Hobson | 27/05/2023 08:01:16 |
383 forum posts 101 photos | I'd go for slot etc. I can't imagine the 45 degrees bit... 45 or 135... still doesn't help my picture. |
Pete White | 27/05/2023 08:03:14 |
223 forum posts 16 photos | Posted by Grizzly bear on 26/05/2023 17:55:07:
Hi, May I ask what is it for? Good luck............... Yes I thought that before we knew and am now thinking a drawing of the project would result in productive comments to help solve the problems? Pete |
Nick Wheeler | 27/05/2023 08:49:23 |
1227 forum posts 101 photos | Posted by modeng2000 on 27/05/2023 07:05:22:
??? There's not much filing to make a 1/4" round hole into a square one. And that's much easier than any of the other suggestions. Quicker too. You might even be able to use the tool steel to sharpen the corners... Edited By Nick Wheeler on 27/05/2023 08:57:50 |
Paul Lousick | 27/05/2023 08:57:40 |
2276 forum posts 801 photos | " I am aiming for a sharp 45 degree bend" Instead of trying to bend a piece of 12mm square, why not cut it out of 12mm plate or flat bar like many other designs on the internet ? |
modeng2000 | 27/05/2023 09:07:20 |
340 forum posts 1 photos | I am trying to copy the shape of the Diamond Tool Holder. This seems to be the definitive shape and it has a lot of users. I used to have one but it went when I downsized my workshop, regrettably! Regarding the clamping method, I want to make a system that I can satisfactorily put together. So I have been looking at the various ways folk have used and taking into account my ability to cut metal the farrication method works best for me. The only milling I can do is on the lathe and so set-up is not as easy as on the mill I used to have. John |
