Spirit Level vials?
Bo'sun | 21/04/2023 11:56:12 |
754 forum posts 2 photos | Good morning All, Do regular/domestic spirit levels have curved vials? |
Thor 🇳🇴 | 21/04/2023 12:02:27 |
![]() 1766 forum posts 46 photos | I think they have a slightly curved inside, the more accurate/sensitive levels have less curvature than a coarser one. Thor Edited By Thor 🇳🇴 on 21/04/2023 12:04:46 |
Nicholas Farr | 21/04/2023 12:33:46 |
![]() 3988 forum posts 1799 photos | Hi Bo'son, if you mean the type from DIY stores, many of them have slightly barrel shaped ones. Regards Nick. |
SillyOldDuffer | 21/04/2023 12:35:35 |
10668 forum posts 2415 photos | I don't think you can generalise. Most of mine of the rough levelling type are definitely bent, others are straight and probably barrel ground. My collection varies tremendously with vials ranging from dubiously bent plastic to well-made glass. They all work, but the cheap ones are only OK for finding a rough level, untrustworthy if an accurate flat is needed. Dave |
Bo'sun | 21/04/2023 12:47:21 |
754 forum posts 2 photos | Thanks Guys, The reason I ask is: I was reminiscing through some old FMC Trade School log books, and I came across some of my notes from the Standards Room Instructor, who said the curvature on the reference level vial, which I recall as being about 24" long, was equal to the curvature of the earth. It just got me wondering as these things often do. |
mark costello 1 | 21/04/2023 20:42:20 |
![]() 800 forum posts 16 photos | It must work the earth stays level. |
old mart | 21/04/2023 21:00:22 |
4655 forum posts 304 photos | Not exactly true, the average flatness of the earth greatly exceeds the requirements of an optical flat. |
Nigel Graham 2 | 21/04/2023 22:02:32 |
3293 forum posts 112 photos | I suspect an old wives', or all old instructors' tale there. Try measuring the displacement of a couple of inches of glass tube. (Yes, it's calculable, but...) |
Clive Hartland | 21/04/2023 22:20:02 |
![]() 2929 forum posts 41 photos | Yes, the internal diameter of a precision vial is hand ground to a curve. I seem to remember that a 20" bubble had a radius of 60'.
Nealeb | 22/04/2023 10:09:38 |
231 forum posts | I think the sums are pretty easy here. Let's say that 20" of tilt give a 1mm movement of the bubble - about right? So we need to find the radius of the curve in which 20" of rotation is equivalent to 1mm at the circumference. Think of a giant toroidal tube if you like, of which the vial is the tiny bit that you can see. Clearly, rotate the toroidal tube and the bubble will move, giving the numbers we are working with. 20" is equivalent to 1/3', 1/(3*60) deg, 1/(3*60*360) revolutions. So the full circumference is 1mm times (3*60*360), which my calculator makes 64800mm Radius equals circumference/2*pi, =10313mm. So approx radius of vial is about 10m. Substantially less than the radius of the earth?
roy entwistle | 22/04/2023 11:09:59 |
1716 forum posts | I thought that the earth was flat And why did they call it earth if over three quarters of it is water Roy |
SillyOldDuffer | 22/04/2023 13:46:00 |
10668 forum posts 2415 photos | Posted by Nealeb on 22/04/2023 10:09:38:
I got a bigger equivalent radius for a Starrett 98-18 Machinists Level, where the graduations measure an angle equivalent to a slope of 0.43mm per metre. Assuming I did it right, always a big if, this calculator suggests the Starrett vial has a radius of 1162.79081 metres. (Or would be the vial was really a bent tube; actually it's a much easier to make straight tube with a shallow barrel ground inside.) Still much less than the radius of the earth though, which is about 6700km. Pedantically, the bubble aligns with the planets centre of mass, and the accuracy of the level relative to a true right angle is limited by the vial mounting. I don't know what the most accurate way of setting a level is. With a theodolite, two staves, extreme care, many traverses, and much error checking it's possible to survey a level accurate within to about 10mm per kilometre. Though I have an ancient theodolite, I doubt I could achieve that accuracy in practice, though it might be fun to try. Establishing an accurate level over several neighbouring properties does me no good at all - the level can't be used in a workshop! Dave |
Andrew Johnston | 22/04/2023 14:30:12 |
![]() 7061 forum posts 719 photos | Precision vials are made by very slightly bending a straight tube in a fixture. A straight hole is the created and honed. When the tube is released the result is a hole on a very large radius. Andrew |
Grindstone Cowboy | 22/04/2023 16:36:23 |
1160 forum posts 73 photos | To answer the original question, yes they do (or at least they used to, they may have been superseded by the barrel type shown by Nick). Precision / engineer's levels are another matter Theodolites will give you a flat plane, but that may not be what you want - the towers on the Humber bridge are further apart at the top than at the bottom, otherwise they wouldn't be perpendicular to the Earth's surface (other bridges are available). Rob |
Pete Rimmer | 24/04/2023 19:32:54 |
1486 forum posts 105 photos | Vials might be ground of bent. The one in my box square is certainly ground as it works inverted. |
SillyOldDuffer | 25/04/2023 11:45:08 |
10668 forum posts 2415 photos | Posted by old mart on 21/04/2023 21:00:22:
Not exactly true, the average flatness of the earth greatly exceeds the requirements of an optical flat. I'm worried about this one. On average, I think it's true all spheres are flat, but this must be misleading maths, because spheres aren't flat in any direction, ever. This is true all the way down to a geometric point, which has no dimensions, and can't be flat or curved in a human sense. Unlike a line between two points, which is also dimensionless, but is perfectly straight. I think the first truly flat thingy is a dimensionless plane defined by two dimensionless lines at a right-angle. My brain hurts! Anyway, if optical flat is levelled with a clear view to the horizon, the flat can be shown experimentally to be tangent to the surface. Even a small optical flat 's more than capable of showing the earth isn't flat, whatever the average says. Interesting that we live in a universe where mathematics can describe almost everything logically and precisely, except several worrying exceptions prove something else deeply contradictory is also going on. Dave
Michael Gilligan | 26/04/2023 06:23:03 |
![]() 23121 forum posts 1360 photos | In answer to the opening question … it would depend upon your interpretation of the term ‘regular/domestic’ Here is a short verbatim quote “from the horse’s mouth” : The manufacturing process varies considerably based on the vast range of precision levels, level vials, electronic level sensors, and angle-measuring inclinometers that we produce. However, the general process usually starts at our own dedicated vial-making department. Here, glass tubes are meticulously checked for cracks and deformities before being cut into smaller cylinders and a radius ground into the inner diameter. […] MichaelG. . Ref. __ https://www.leveldevelopments.com/2020/08/the-manufacturing-process-at-level-developments/ Ref. __ https://www.leveldevelopments.com/products/ Edited By Michael Gilligan on 26/04/2023 06:28:15 |
Nicholas Farr | 26/04/2023 07:58:54 |
![]() 3988 forum posts 1799 photos | Posted by Bo'sun on 21/04/2023 12:47:21:
Thanks Guys, The reason I ask is: I was reminiscing through some old FMC Trade School log books, and I came across some of my notes from the Standards Room Instructor, who said the curvature on the reference level vial, which I recall as being about 24" long, was equal to the curvature of the earth. It just got me wondering as these things often do. Hi Bo'son, I think that if a 24" long vial was equal to the curvature of the earth, it would be almost flat, and would probably only measure less than microns, and for practical purposes would be next to useless. The earth anyway is slightly squashed, as it is lager at the equator than at the poles by about 27 miles, due the the rotational forces exerted on it. You may have part of the equation missing, in that the reference vial might be a ratio of the average radius of the earth to its length, which to me would make more sense. Regards Nick. |
Andrew Johnston | 26/04/2023 08:34:08 |
![]() 7061 forum posts 719 photos | Posted by SillyOldDuffer on 25/04/2023 11:45:08:
...dimensionless plane defined by two dimensionless lines at a right-angle. Not true! In Euclidian geometry a plane can be defined by distinct three points, a line and a point that is not on the line, two lines that intersect at a point or two parallel lines. There is no requirement for the two intersecting lines to be at right angles. Andrew |
SillyOldDuffer | 26/04/2023 09:24:14 |
10668 forum posts 2415 photos | Posted by Andrew Johnston on 26/04/2023 08:34:08:
...dimensionless plane defined by two dimensionless lines at a right-angle. Not true! In Euclidian geometry a plane can be defined by distinct three points, a line and a point that is not on the line, two lines that intersect at a point or two parallel lines. There is no requirement for the two intersecting lines to be at right angles. Andrew He's right! I was thinking of a Cartesian Plane, and planes don't have to be Cartesian. Dave |
