Blueing
petro1head28/03/2023 12:01:05
984 forum posts
207 photos
Years ago, when i spent most of my school days in the enginnering workshop we used to blue a lot of the work we made. If i remember we heated the part up and dropped it in an oil solution, loved the smell
So whats the modern equivant as i fancy blueing some of my work now?
bernard towers28/03/2023 12:12:23
1221 forum posts
161 photos
Clockmakers still blue their screws the same way as always by heating the screws whilst laying in a bed of brass swarf ( heated underneath) until they turn blue then quench in oil. Alternatively you can black your parts chemically, just google blackit solution.
Martin Kyte28/03/2023 12:30:58
3445 forum posts
62 photos
Any thin clean oil will do. The colours develop just by heating to tempering heat and stopping at blue. The oil prevents the process from continuing by cooling the part and providing an oil film to protect the surface. The colour comes from the thin oxide layer developed on the surface when heated and is an optical phenomenon caused by interference which is why the colours change according to the thickness of the oxide layer.
Oil does however make the surface look blacker presumably by mopping up the blue photons somewhat.
regards Martin
Edited By Martin Kyte on 28/03/2023 12:33:34
petro1head28/03/2023 13:14:50
984 forum posts
207 photos
Cheers guys.
Did a bit of Google work and see that gunsmiths blue their barrels using **THIS**
I also found a good video on how to use
Dalboy28/03/2023 13:27:35
1009 forum posts
305 photos
This can be a confusing term as petro1heads post above compared to bernard towers post which are both called blueing.
See Clicksprings video.
jaCK Hobson28/03/2023 13:35:07
383 forum posts
101 photos
If you can get hold of low temp heat treating salts then the process is much easier to get repeatable. I had to buy 20kg bag, with a minimum £50 pallet delivery... I haven't used em much but I hoard them.
SillyOldDuffer28/03/2023 13:36:41
10668 forum posts
2415 photos
The thing about bluing is how thick the protective layer needs to be.
An attractive thin layer suitable for decorative purposes is achieved as described above, but it's not hard wearing.
Deep hard-wearing bluing requires heat and repeat treatment with nasty chemicals, such as molten Nitrates. Coild be done, but not really a home workshop process.
'Cold Blue' is a safer alternative, often based on Selenium. Much used to touch up worn firearms. The resulting layer isn't particularly tough, but it's easily redone.
A thicker protective layer can be achieved by plunging red-hot metal into dirty engine oil. Results vary, black rather than blue, and unlikely to be pretty.
Martin W28/03/2023 15:18:38
940 forum posts
30 photos
I have used a cold bluing paste which seems to be quite resistant to abrasion and that is Birchwood Casey Perma Blue which can readily obtained from the this site. The depth of colour can be controlled by the length of time that the paste is left on the metal, this can be a bit variable so requires a bit of experimentation to get a even depth of colour
Martin
petro1head28/03/2023 15:29:29
984 forum posts
207 photos
So its a toss up between these three
Edited By petro1head on 28/03/2023 15:44:35
Bezzer28/03/2023 16:24:18
203 forum posts
16 photos
Posted by petro1head on 28/03/2023 13:14:50:
Cheers guys.
Gun barrels aren't cold blued they are hot blued/blacked, if a gunsmith used cold blueing it would just be a minor mark or scratch they were trying to hide. Not used or found a decent hard wearing cold blue and I've tried over the years.
Oldiron28/03/2023 16:30:22
1193 forum posts
59 photos
I used the Nickerson Cold Blue on all the toolholders I made. Got pretty good results with it. Parts need to be very very clean. I warmed them up a bit till they were just hot enough to handle then duncked them in the solution till they looked about right. Then oil and wipe over. Look very good.
I got good results on another job after reusing the solution.
regards
Fowlers Fury28/03/2023 17:57:33
446 forum posts
88 photos
I'm really not being facetious but I wish some folks posting queries would first try the site's "Search for" box. There's already a wealth of information and advice on the subject - "Blueing".
Whichever method is adopted, worthwhile protection is possible by the (regular?) application of black shoe polish to the metal surface followed by light buffing.
petro1head28/03/2023 21:15:39
984 forum posts
207 photos
opps
Edited By petro1head on 28/03/2023 21:19:06
petro1head28/03/2023 21:23:22
984 forum posts
207 photos
Posted by Fowlers Fury on 28/03/2023 17:57:33:
Wheb someone starts a reply to a post "I am really not being facetious" it usually means they are
I did a search and there were only 7 replies.
Fowlers Fury28/03/2023 21:33:02
446 forum posts
88 photos
There are a total of 87 replies according to the search box. Yes, there may be repeat postings included in that total. My point was that there's useful information already on the site.
petro1head28/03/2023 21:35:40
984 forum posts
207 photos
Well thats very strange as i hva just searched "blueing" again and only get 7 topics
Edited By petro1head on 28/03/2023 21:36:16
Fowlers Fury28/03/2023 22:01:41
446 forum posts
88 photos
petro1head28/03/2023 22:04:18
984 forum posts
207 photos
So we are both right, 7 topics and x number of posts.
well i think we have covered that
Grindstone Cowboy28/03/2023 22:20:31
1160 forum posts
73 photos
Well, you missed this one,
Rob
Links to https://www.model-engineer.co.uk/forums/postings.asp?th=177264
petro1head28/03/2023 22:33:01
984 forum posts
207 photos
Posted by Grindstone Cowboy on 28/03/2023 22:20:31:
Rob
Cheers, ordered some of the Nickerson from Amazon
Edited By petro1head on 28/03/2023 22:35:54
