What issue and have you built one?
Martin Johnson 1 | 14/03/2023 16:37:38 |
320 forum posts 1 photos | Long ago there was an article on making a Beugler pinstripe lookalike published in MEW. If anybody knows which issue it would save a lot of looking through on my part. More importantly, has anybody made one and did it work and was it worth the effort? Failing that has anybody got any foolproof methods of putting 1/4" lines on a stlightly over half size steam lorry. I have been fooling around with a lining brush for a while and we just don't seem to be getting along. It's not her it's me. Thanks in advance, Martin |
Martin Johnson 1 | 14/03/2023 16:43:36 |
320 forum posts 1 photos | Just found it Issue 155 by Dave Fenner. Still interested to know if anybody other than Dave has made one and how you got on lining. Martin |
Dalboy | 14/03/2023 17:04:17 |
![]() 1009 forum posts 305 photos | Edited By Dalboy on 14/03/2023 17:05:12 |
duncan webster | 15/03/2023 00:21:28 |
5307 forum posts 83 photos | If you know someone with a vinyl cutter you could get some circles cut, then cutting those up, taking off the bit you'd usually leave, and masking tape you should be able to build up a stencil on the job. Or cheat big time and just use vinyl! |
Paul Lousick | 15/03/2023 03:01:06 |
2276 forum posts 801 photos | When I did the striping on my engine, I made one of the pens as shown in the above video but did not have a lot of success with it. I used proper sign writers paint but found that the paint would continue to flow thru the nib and cause a blob, especially on wider lines. I then bought a Beugler roller and recommend them. Youtube video of improved version of the DIY pen: (**LINK**) (https://www.youtube.com/watch?v=X6PDb8WFs1A)
Edited By Paul Lousick on 15/03/2023 03:07:47 |
Circlip | 15/03/2023 09:47:23 |
1723 forum posts | As a wrinkly ex Draughty, these used to be called 'UNO' stencil pens when Pounce and Indian ink were kings. Regards Ian. Sorry, for the wokeries 'Sub continent ink' Edited By Circlip on 15/03/2023 09:48:35 |
noel shelley | 15/03/2023 10:04:23 |
2308 forum posts 33 photos | One way out would be to buy the beugler roller of the size you need and make the paint holder ? Noel. |
KWIL | 15/03/2023 10:15:23 |
3681 forum posts 70 photos | Search for the tapes that car painters use, they are availble for various widths and you can curve some of them. As they are tight to the surface bleeding under is not a problem. |
Paul Rhodes | 15/03/2023 10:56:35 |
81 forum posts | I agree with KWIL’s advice. I have had success with J Tape and 3 M tape. Both can be used to apply multi coloured parallel lines . Avoid the budget tapes however as much more difficult to achieve sharp edges. |
Martin Johnson 1 | 15/03/2023 12:01:16 |
320 forum posts 1 photos | Thanks for all the replies. To Paul L and Dalboy for links to the UNO lookalike as Circlip notes. Like Circlip I remember the UNO from Drawing Office days and have a fair selection of them in the back of the drawer still. I have tried them on paint and the results were not great, probably need more clearance to function on paint. To be fair, they weren't great on ink either - the Rotring was like waking from a nightmare! Anyway, the real problem is that I need to do 1/4" lines and while twin lines with a UNO and fill in the gap with a brush is possible it is very slow. Some of my 4" Burrell was done that way with a draughtsman's pen rather than a UNO. Thanks to KWIL and Paul R for the experience on lining tapes. I might go that route as I do have some curves to do. I went down the scrap mine last night to see if a Dave Fenner pen might appear and I have found some scrapium that might be suitable. However, there is a more interesting possibility as a result of this thread, which I will tell you about if it comes to fruition. Thanks to everybody, an excellent forum as ever, Martin |
