Eyelet setting(?) tool - how to use?
Robin Graham08/03/2023 22:14:41
1089 forum posts
345 photos
My wife returned from a charity shop scavenging expedition with this:
It is obviously some sort of eyelet or rivet setting tool, but I'm wondering how it would be used. I'm sure someone on here will know!
As an aside I had a look for Maun Industries and it seems that they started in 1944 making hand tools and are still a going concern based near Nottingham, though now making only parallel-action pliers. I think I shall get some.
Robin
george baker 108/03/2023 22:34:23
39 forum posts
Hi
their pliers are wonderful, various sizes, plane (Plain?) or Ribbed inside jaw etc.
Use the Hole punch (If you have one) to make a hole in the fabric.
Put the peg of the Press stud back through hole,
turn fabric over,
put other part of press stud over peg.
Put back on Anvil
Use punch to spread peg.
EDIT,
I just realized you dont have any press studs, and They are the sort used on Belstaff motorcycle jackets
George
Edited By george baker 1 on 08/03/2023 22:37:15
Michael Gilligan08/03/2023 22:35:35
23121 forum posts
1360 photos
Loads of tools available using the same concept, Robin
Try here for some basic instruction: **LINK**
https://trimmingshop.co.uk/eyelets-setting-and-hole-punch-hand-tool-set/
The trick will be to find components that fit the Maun tool.
Roderick Jenkins08/03/2023 22:36:27
2376 forum posts
800 photos
This Newey tool has a very similar pair of punches and a reversible die. You'll need the correct kit of parts to use it.
I have a plier type hole punch with a rotating head and a yard long straight edge both made by Maun
HTH,
Rod
george baker 108/03/2023 22:45:27
39 forum posts
Hi
a picture is worth a 1000 words
George
Nicholas Farr09/03/2023 08:44:35
3988 forum posts
1799 photos
Hi, I have a small Press Fasteners set, which is used in the same way as shown in the instructions that Rod has posted.
I also have a small Eyelet plier set, which the Eyelets have about a 4.4mm hole, which are really self explanatory to use.
Lastly I have a large Eyelet set with 7/16" holes, and is shown here with their instructions of how to fit them.
They all work very well, even though they were not very expensive.
Regards Nick.
Edited By Nicholas Farr on 09/03/2023 08:45:50
noel shelley09/03/2023 09:45:59
2308 forum posts
33 photos
The one above is great for putting eyelets in tarpaulins Etc where you fold over the edge by 2" TO GIVE GREATER STRENGTH. Noel.
KWIL09/03/2023 11:27:47
3681 forum posts
70 photos
Cousins uk Horological suppliers have a very wide range of pliers etc including Maun.
Robin Graham09/03/2023 22:02:19
1089 forum posts
345 photos
Thanks all - looks like it's a press-stud setting tool then. Probably not much use to me at present, but you can never have too many tools and good to know how it works.
Maun pliers now on wish list!
Robin.
