SillyOldDuffer | 07/03/2023 13:35:37 |
10668 forum posts 2415 photos | On the way to visit mum I stopped in Corston to buy her some stamps, and took the opportunity to photograph this building which has intrigued me for years: It's an old outhouse, built on the corner of a walled garden. The hatch and slit window are consistent with hauling bags from a roadside cart into the upper part of a stable. The outhouse is built on top of an existing wall, that's been laid at an odd angle (red line), not horizontal (green line). Peculiar in my limited experience, because brick and stone walls are normally built in strictly horizontal courses. If laid at an angle as in the photo, the weight tends to cause sloped courses to slide down the ramp. The construction is unstable, and I think it's dangerous to build on a sloped wall as has been done here. The outhouse on top is built conventionally with horizontal layers. Though it doesn't show in the photo, the lower wall is a different type of stone to the building, which is the area's usual limestone, likely 19th Century or earlier. Presumably to save money the outhouse builder took a risk by reusing an existing wall, even though it was tilted. And got away with it, because there's no sign of movement! But why build a wall with off-horizontal courses in the first place? To me it implies a need to support something heavy resting on it at an angle, in the distant past. Anyone know the answer or able to offer an intelligent guess? Dave
Peter Cook 6 | 07/03/2023 14:38:16 |
462 forum posts 113 photos | Possibly the original wall was built when the road surface sloped down like the top of the wall. If you could dig down below the pavement level, I suspect you would find the foundations of the wall sloped down below pavement level. Subsequent road "improvements" have levelled the road surface. |
Ady1 | 07/03/2023 14:52:39 |
![]() 6137 forum posts 893 photos | Old research photos might throw up an answer, local library? |
JasonB | 07/03/2023 15:07:43 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by SillyOldDuffer on 07/03/2023 13:35:37:
Peculiar in my limited experience, because brick and stone walls are normally built in strictly horizontal courses. Not if it started out as a 3 ft high boundary wall or similar and was subsequently used for the base of the existing building. Most dry stone walls for example follow the slope of the ground and are not stepped or laid in horizontal courses |
Michael Gilligan | 07/03/2023 15:11:46 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 07/03/2023 13:35:37:
[…] But why build a wall with off-horizontal courses in the first place? .
Because it was originally built as a boundary wall, and followed the terrain. MichaelG. . Edit: __ Post crossed with Jason’s Edited By Michael Gilligan on 07/03/2023 15:13:18 |
JasonB | 07/03/2023 15:15:37 |
![]() 25215 forum posts 3105 photos 1 articles | Good example of the old wall following the natural contours just up the road on google maps |
Brian Wood | 07/03/2023 15:18:50 |
2742 forum posts 39 photos | I have to take issue with you here Jason. In Yorkshire. dry stone walls are built horizontally, in steps if need be on sloping ground, for the very reasons of stability you mention. The use of the wall doesn't alter whether or not that is the case Regards Brian |
JasonB | 07/03/2023 15:23:57 |
![]() 25215 forum posts 3105 photos 1 articles | What about this and loads more images on a google search of Drystone wall Yorkshire Edited By JasonB on 07/03/2023 15:24:08 |
gary | 07/03/2023 15:33:28 |
164 forum posts 37 photos | nothing wrong with building on a slope. done very often when needed. |
Brian Wood | 07/03/2023 16:15:27 |
2742 forum posts 39 photos | Field walls with random stone are one thing, ornamental walls are usually built with coursed stone |
JA | 07/03/2023 16:17:31 |
![]() 1605 forum posts 83 photos | Dave Pay a visit to the Withshire County Archives at Chippenham. They should be able to tell you all about the building. It seems to me that we are suffering from cabin fever having been driven out of our workshops by the cold. It should be warmer at the weekend. JA |
JasonB | 07/03/2023 16:40:49 |
![]() 25215 forum posts 3105 photos 1 articles | Different types of wall only one with horizontal coursing the double stack, as me and Michael said it was possibly a (field) boundary in another life Admittedly the wall in question has fairly regular coursing which would make slipping more likely, usually you would have more raddom stone sizes so there are no long sloping joint lines to slip
File Handle | 07/03/2023 18:28:08 |
250 forum posts | I have seen brick walls built following the slope of the ground rather than horizontaly, especially in farm buildings.One I remember only looked odd after it was pierced with a vertical doorway, or rather the doorway looked odd. . |
Grindstone Cowboy | 07/03/2023 19:02:38 |
1160 forum posts 73 photos | Works for the Chinese! Rob |
SillyOldDuffer | 07/03/2023 19:12:27 |
10668 forum posts 2415 photos | I like the boundary wall suggestion. This clip from the 1909 25" Ordnance Survey map shows the road slopes down to cross a stream. The road is the A39, built as a Turnpike in 1707 connecting Bath to Wells, and re-engineered by McAdam sometime before he died in 1832. My guess is the original road dipped down steeply to ford the stream, but was raised high over a causeway that removed the awkward dip. In which case the sloping wall could be earlier than 1832, and it's right for the boundary of the Brookside property, sat in a 0.852 acre garden. Not sure going to Chippenham will help, because Corston was in Somerset, not Wiltshire. Since then it's been in Avon, and is now ruled by the wonderfully named Banes, straight out of Lord of the Rings. I guess the records are in Taunton. Much of the village is owned by the Duchy of Cornwall. The current Duke is Prince William, heir to the throne, but he wasn't there to ask when I dropped in. Dave
ChrisLH | 07/03/2023 20:52:55 |
111 forum posts 7 photos | Looks like there are two Corstons. One in Wilts on the A429 near Malmesbury and SOD's one in Somerset. |
Martin Kyte | 07/03/2023 21:12:31 |
![]() 3445 forum posts 62 photos | I think the boundary wall suggestion is probably the correct explanation. However if you take a look at some of the canal roving bridges especially ones that cross at an angle you will see many examples of brickwork anything but horizontal. On the skew bridges the brickwork forming the arch starts off on the slope and then straightens out to the crown and ends up with the opposite slope on the other side. Admittedly the courses are perpendicular to the direction of thrust. They really are gems of bricklaying art. regards Martin |
Martin Kyte | 07/03/2023 22:16:01 |
![]() 3445 forum posts 62 photos | Oh and you should see some of the older houses out in the fen. They started off upright but then the fen shrank and the whole building ends up tilted. regards Martin |
File Handle | 08/03/2023 08:09:04 |
250 forum posts | Isn't one explanation the whoever built the wall might not have had a spirit level, common now, but less likely to be so in the past. Built by eye a wall following the ground level looks better!
Anthony Kendall | 08/03/2023 09:02:36 |
178 forum posts | I think we might have to get Corston CID in to get the real answer? |
