Rockingdodge | 05/03/2023 17:03:10 |
![]() 396 forum posts 111 photos | Just bought this but no name or company on the tool or box, seems quite old. Anyone able to identify it and it's purpose? |
noel shelley | 05/03/2023 17:09:21 |
2308 forum posts 33 photos | Pistol grip sheet thickness gauge/comparitor. Noel |
Jeff Dayman | 05/03/2023 17:54:55 |
2356 forum posts 47 photos | I agree with Noel it is for measuring sheet material thickness - but it may be specifically intended for measuring the wall thickness of thinwall pipe. |
jimmy b | 05/03/2023 19:00:07 |
![]() 857 forum posts 45 photos | I'd say bore comparator, not sheet material.
Jim |
Rockingdodge | 05/03/2023 20:36:07 |
![]() 396 forum posts 111 photos | I'll take some more photos tomorrow, hopefully they might clarify the action. Roger |
Emgee | 05/03/2023 21:43:15 |
2610 forum posts 312 photos | Bore or groove comparator. Emgee |
Baz | 05/03/2023 22:09:01 |
1033 forum posts 2 photos | Agree with Emgee it’s a bore or groove comparator. |
Andy Ash | 05/03/2023 22:25:13 |
159 forum posts 36 photos | Groovy baby! (It's the pink satin that gives it away!) Edited By Andy Ash on 05/03/2023 22:25:57 |
Rockingdodge | 06/03/2023 11:43:12 |
![]() 396 forum posts 111 photos | Some more photos as promised:- As it's a verdict gauge would it be safe to assume that it's a verdict groove comparitor? Full set of accessories plus a couple of odd ones. What would the extra clamp on the right of the pic be for? Roger |
JohnF | 06/03/2023 12:51:15 |
![]() 1243 forum posts 202 photos | Yes a comparator for measuring internal grooves, used one many time and have one with all accessories -- I'll take some photos later. Made or sold by Verdict, would work for bores but there are much better tools available for this. John |
JohnF | 08/03/2023 20:31:14 |
![]() 1243 forum posts 202 photos | Some more photos of mine, as you will see there are several probes that can be interchanged to use on very narrow groves and to increase the usable diameter. I use either a calliper or micrometer to make the initial zero, with care they can give good accuracy. The additional clamp is I believe so the dial gage can be used units own on a scribing block etc. |
Rockingdodge | 09/03/2023 10:24:16 |
![]() 396 forum posts 111 photos | Nice one John, a few more probes than mine. |
John Reese | 09/03/2023 23:50:59 |
![]() 1071 forum posts | I have a similar device without the pistol grip. It is a real PITA to set, and I have little confidence it will hold adjustment. I do have an attachment for my 6" caliper for measuring grooves, provided the diameter is large enough. |
