Centec 2B Mill buying
Mark B02/03/2023 15:37:16
79 forum posts
36 photos
I've been on the lookout for a milling machine for smallish operations (mostly clockmaking) for a while. I've decided that Bridgeport sized machines are too big for my workshop so Tom Senior / Centec sized machines are better for me.
I've been talking to Home and Workshop Machinery about this machine and wondered if anyone had any opinions or advise https://www.homeandworkshop.co.uk/stock-item/centec-2b-/1389/
The price is not far off what I'd spend for a new Chinese machine, but I feel an old and better made machine is the best option.
I've read a few posts on this forum which are generally positive about the Centec machines.
Thanks
peak402/03/2023 15:51:45
2207 forum posts
210 photos
I have one almost exactly the same and find it does every (reasonable) thing I've asked of it.
Mine also has the swivelling universal table, so make sure you don't need that facility before committing.
It might well be three phase, so do you have a suitable supply?
If it is the same as mine, the main 1HP motor is dual voltage, so easy enough to run off a inverter/VFD, but the table feed motor is 415v only.
I replaced it with a single phase motor, but it's too big and heavy, and does cause a bit of tilt on the table.
I must get around to finding the star point of the old motor, so I can swap it back and run it off a second inverter.
In the short term I help balance it with a universal dividing head bolted to the left hand end, which is useful anyway as it takes a Myford chuck.
The need for two inverters wouldn't be a problem, if I'd gone down the route of a Transwave or similar setup.
Bill
Frank Gorse02/03/2023 16:18:38
104 forum posts
They are great machines and that one looks to be in fair condition but I would have thought it was on the big side for clockmaking, especially as you say your space is limited.
Also,if you plan to do both horizontal and vertical milling you will soon get fed up with lifting the vh on and off and will be looking for a raising block- see correspondence on this site.
I’ve got a Tom Senior ‘E’ type now which suits me much better and would probably do all you need.
Mark B02/03/2023 16:45:05
79 forum posts
36 photos
Thanks for the replies. The machine is 3phase and I've only got a single phase supply in my workshop but I'm happy with setting up VFDs. The table motor as mentioned needs rewiring from star to delta. I found some photographs on this forum from someone who did this already.
Do people think the price of the machine is fair? I appreciate that you will pay a premium from a dealer, but they are able to get it delivered easily which as I live in Scotland is very handy.
duncan webster02/03/2023 17:23:19
5307 forum posts
83 photos
Centec with a single phase motor mounted in the cabinet is very noisy. As you intend, get a vfd and keep the 3 phase motor. I'm very happy with mine, but the top speed of the vertical head is a bit slow for little cutters @ 1400 rpm. Even at this speed the head gets quite warm, so I wouldn't be tempted to drive it faster. When you decide you need power feed on the x axis send me a pm.
Dave Halford02/03/2023 19:09:30
2536 forum posts
24 photos
I think Gary Wooding has a 3000 rpm version. You just need to double all the plated speeds.
The quill vertical head has doubled the price.
The positives are
The gearbox shaft bungs are undamaged so the gearbox has never failed.
The power traverse claims to have the other gear ratios (they should be sitting in the top of the motor.)
Negatives
Where is the horizontal abor and bearing support.
It's outside.
RobCox02/03/2023 19:42:10
82 forum posts
44 photos
How about a Centec 2A? There's one for sale on mig-welding.co.uk for 2/3 of the cost of the 2B.
Dave Halford02/03/2023 21:01:43
2536 forum posts
24 photos
Posted by RobCox on 02/03/2023 19:42:10:
If ever there was a classic case of to big a vice that's it.
peak402/03/2023 22:03:00
2207 forum posts
210 photos
Also on Facebook Marketplace
https://www.facebook.com/marketplace/item/581167547382965/
Bill
duncan webster02/03/2023 22:25:18
5307 forum posts
83 photos
I think 2B has more x travel, lathes.co.uk would know
not done it yet02/03/2023 22:49:29
7517 forum posts
20 photos
Posted by Mark B on 02/03/2023 16:45:05:
My power feed runs on a 230V VFD, but remains wired in star config. I've never experienced any problem, as yet, with the reduced power. The spindle motor on mine, as a matter of fact, is running with a 220V VFD but is wired Star. But I have taken into account the reduced power output in this configuration for its duty.
I consider the 2B to be a fair improvement over the 2A (the knee operation, table size and headspace. Mine also has a long riser block, so even more height available over the table when vertical milling - and I don’t need to remove the vertical head to go milling horizontally.🙂
The power feed versions lose about an inch of long travel, if that is important and I really appreciate the DRO on mine. Avoids any backlash adjustments when positioning the work.
I find that supplier usually inflates the listed sales price somewhat above reality.
vic francis03/03/2023 00:52:06
125 forum posts
21 photos
Hi Mark, A good thing is if it comes with the extra head raising block, as they never come up for sale, even eBay.. The coolant tray is massive so getting through a doorway is a problem, and mine was welded on.Its much heavier than I thought!Gary Wooding has a beautiful example, and shows what can be done with this machine with skill and vision.
Vic
not done it yet03/03/2023 07:36:05
7517 forum posts
20 photos
Posted by vic francis on 03/03/2023 00:52:06:
Vic
I cut my base horizontally, after fitting several brackets across where the cut was to be made. It is now re-assembled exactly as it was originally - less the kerf. Yes it is B. heavy! Mine was slid off the Ifor Williams trailer (like the machine body and base) down an inclined plane.
Bill mentioned a single converter, as opposed to two inverters, but converters are likely rather more expensive than two VFDs. Also no programming, variable speed - and with other cons, to boot!
Dave Halford03/03/2023 10:24:39
2536 forum posts
24 photos
Posted by not done it yet on 02/03/2023 22:49:29:
Centec's are currently a good investment.
Quill V heads have gone from £300 to £1500 in 12 years
Even a Centec 2 has gone up £500 and an 'overarm' is now £160
Clive Steer03/03/2023 10:42:06
227 forum posts
4 photos
For a small compact vertical milling machine I purchased a Boxford VM30. It is simple and well constructed with mechanical variable speed head. The only downside is that the hi/lo spindle speed range selector uses an idler gear arrangement that is always engaged for either range so the head is very noisy. My workshop is in the garage which is inside the house so this was a problem. So I grafted a Bridgeport M head on to it and an VFD to reduce the need for belt swapping. The M head has a quill which the VM30 doesn't have which makes drilling more difficult. The more common J head might work but being larger looks out of proportion.
All of this came in for less than £1k.
CS
Gary Wooding03/03/2023 11:37:01
1074 forum posts
290 photos
Cherry Hill, one of the very best, if not the best, model engineers, uses a Centec 2B.
I've fitted VFDs to the the spindle and power feed motors, and added a DRO to mine. It makes for a very nice machine. See my album. One rare thing on mine is that the spindles are ISO30.
Mark B04/03/2023 03:42:17
79 forum posts
36 photos
Thanks again for all the replies this is all very helpful. I've decided to go ahead and purchase the machine so I'll report back once I have it and I start to VFDs to bring it alive.
not done it yet04/03/2023 13:40:55
7517 forum posts
20 photos
Posted by Mark B on 04/03/2023 03:42:17:
Mark, you have a PM.
Mark B15/03/2023 20:56:40
79 forum posts
36 photos
Well I took delivery of the Centec 2B this afternoon.
On balance I'm pleased with my purchase; it feels like an honest machine so far, but I've yet to power it up. I'm selecting VFDs.
"not done it yet", you mention that you've got the power feed working from a 240V VFD but you've left it in star config. I'm liking the idea of this as I don't relish the thought of picking into the windings to rewire it delta. How did you select a VFD rating for this? The fact that I might lose a little power doesn't worry me as I make small things and make light cuts. Are there any other disadvantages to this approach?
not done it yet16/03/2023 08:08:04
7517 forum posts
20 photos
Mine came, with a single phase main drive and with a tiny VFD already fitted to the power feed. The VFD is a tiny fractional HP device which I’ve never interfered with.
I don’t even change the gear ratio of the power feed since selecting the combination that seems to work OK for me. Highest speed setting is OK-ish for return travel - I’m not usually in a rush - and is less arduous than winding the table back to origin (no half-nuts on my table).
