Silver soldering question
Soldering steel to brass
Chris Gill16/02/2023 21:39:56
74 forum posts
29 photos
I encountered a bit of a puzzle when silver soldering recently and I wondered if anyone could advise.
I was trying to solder brass valve chests onto steel cylinders (EN1 or EN3, not Pb) for a model I was tinkering with. I cleaned everything, applied flux and heated inside the cylinder primarily.
I picked the finished item in dilute citric acid for a short time. All the cylinders had a black coating on the inside and I assumed it was just a little oxidation but wet-and-dry paper wouldn't touch it.
Then a little bit flaked off and I discovered it was a thick, glass-like glaze. After a few experiments I found I could turn the glaze off using carbide tools but HSS didn't seem happy.
Any idea what the glaze might have been?
In terms of the model, there were several other "lessons learned" so it runs off a small motor rather than air or steam!
David George 116/02/2023 22:04:28
2110 forum posts
565 photos
Hi the glass like coating is flux left over. I use an acid descaler and use brick cleaner.
David
JasonB17/02/2023 06:52:41
Also possible it was an oxide like you get on "black bar" if the heating was prolonged and is quite hard to remove manually. This will flake off in brick cleaning acid.
rachel tibbriani19/02/2023 06:48:23
5 forum posts
Posted by Chris Gill on 16/02/2023 21:39:56:
if the flux is not thoroughly cleaned off, it can react with the citric acid and form a glass-like glaze on the surface of the metal. This residue can be difficult to remove, especially if it has been allowed to sit for a long period of time.
To prevent this issue in the future, it's important to make sure that all flux is thoroughly cleaned off after the soldering process is complete. You can try using a wire brush or sandpaper to remove the residue, or you may need to use a more aggressive cleaning agent to dissolve the glaze.
It's also possible that the glaze could be a byproduct of the citric acid reacting with the brass or steel. However, this seems less likely given that you were able to remove the glaze with carbide tools.
Simon Johnson 219/02/2023 17:08:07
9 forum posts
I suspect your problem was "dilute citric acid for a short time".
Next time, try a stronger mix for 20 mins or even better a commercial pickling product such as 'Safety Pickle' -its about a tenner/kilo from jewellery tool suppliers and should be used warm
noel shelley19/02/2023 19:05:10
2308 forum posts
33 photos
If your near me I can give you some pickle - free. N Norfolk. Noel.
Chris Gill19/02/2023 20:27:33
74 forum posts
29 photos
Thanks all
I never thought of a reaction between citric acid and flux but I have some brick acid which I can try next time.
Noel - many thanks for the offer but I'm in Leeds.
Simon - I had heard of sodium bisulphate pickles but I just happened to have citric acid in stock. I couldn't find it at quite that price although I did find a supplier offering 25kg sacks. I think I'll start with something smaller
shaun meakin 120/02/2023 13:47:54
62 forum posts
Hi Chris,
it sounds like you have overheated the flux. A flux is like a sponge absorbing oxide as well as creating a barrier to further oxides forming. After a while, like a sponge, it can become 'saturated'. Plus if you get above the working temperature of the flux it will 'bake' on leaving a glassy hard residue difficult to remove. This is especially true if the joint takes a long time to reach brazing temperature. In future please consider a flux with a longer working life, for example our HT5.
Hope that is of interest.
\Shaun.
Chris Gill20/02/2023 16:38:08
74 forum posts
29 photos
Shaun - that sounds like good advice. I've added HT5 to my shopping list. If you're at the Harrogate show I'll call in
Chris
bernard towers20/02/2023 21:00:17
1221 forum posts
161 photos
Really surprised that you failed with your soldering as EF flux should have coped with that and I remove that flux in boiling water. If you use HT5 flux CUP Alloys recommend a 10% caustic soda solution
Tim Stevens20/02/2023 22:07:16
1779 forum posts
The silver-solder fluxes I am familiar with are all based on boric acid. Some of the patented recipes include salts which enable the glass-like residue to dissolve quickly in very hot water. Otherwise the borate glass will dissolve slowly in dilute suphuric acid (used on sterling silver, but not so clever for steel).
Even if you don't get it all off, it will (in my experience) weather away and rub off - looking like whitish mould in the process.
Another way to remove glassy deposits which have melted to a metal surface (including real enamels) is to heat the object to a dark red, and sprinkle saltpeter* on the glassy surface. This results in a more liquid glaze which includes nitrates and so (when cooled) dissolves in water.
* Potassium Nitrate - use a bit more than the same volume of it as the deposit to be removed.
[Or if you are making your own fireworks, ask for Nitre - it's the same stuff but an even older name. If you use the scientific name the next question will be 'What do you want it for, sonny?']
Cheers, Tim
JasonB21/02/2023 07:04:57
Without knowing the size of the steel cylinders and what Chris has in the way of heating equipment it is impossible to say if standard "easyflo" type flux would have worked as it may have taken a long time to get upto temp or got overheated in which case as Shaun says the flux would have been exhausted but HT5 will stay active for a lot longer.
Chris it would be interesting to know if you covered the whole inside of the cylinder with flux, or just where the joints were and whether the hard layer was all over the fluxed surface or on bare metal too.
