For a watch dial
Iain Downs | 16/01/2023 08:59:25 |
976 forum posts 805 photos | Hi, all. I'm trying to source some steel to make a watch dial. The dial will be about 37mm across and wants to be between 0.4 and 0.5mm thick. I've actually ordered a couple of bits in from eBay (one stainless and one mild), but neither were flat and the mild looked like it had been at the wrong end of a boxing match! From what I can make out flattening steel sheet is far from trivial so best if it came flat. I was also struggling to cut it without stressing the edges. Shears will almost certainly bend it, bandsaw really needs several bunched together. Dremel will probably work OK, but the attempt was the last gasp for my poor old dremel so I've another (cheap knockoff) coming. My closest to success isn't too bad, though my attempts at pressure turning clearly need some practice! The dial will have a 2.5mm hole in the middle which will help. So a few questions :- where can I get stock (cheaply, of course) which will arrive flat (within 0.05mm say over my 40mm area)? Can I flatten it to that level if it doesn't (with basic tools)? Any suggestions on how I can cut it into squares (or polygons) before cutting to final size (Probably with pressure turning)? Any advice would be much appreciated!
Iain |
roy entwistle | 16/01/2023 09:10:31 |
1716 forum posts | Shim Stock ? Watch dials are usually brass, or at least the old ones were. Roy |
Michael Gilligan | 16/01/2023 09:13:29 |
![]() 23121 forum posts 1360 photos | Might be worth enquiring here: **LINK** https://www.stephensgaskets.co.uk/product/stainless-steel-shim-0-020-0-5mm That listing is probably much more quantity than you want, but at least they do “small” orders MichaelG. |
Martin Connelly | 16/01/2023 09:16:02 |
![]() 2549 forum posts 235 photos | As Roy suggests shim stock would be a good start and then laser or water jet cutting into blanks for further machining should keep it flat. If doing it yourself consider a Dremel type tool with thin cutting disks to cut into useable pieces. just don't let it overheat in order to avoid thermal distortion. Martin C |
martin haysom | 16/01/2023 09:40:50 |
![]() 165 forum posts | shears will cut without distorting. if held right all the distortion is on the waste. there must be loads of utube videos showing how its done |
Iain Downs | 16/01/2023 09:45:01 |
976 forum posts 805 photos | HI, Roy - true, but my plan is to blue the steel rather than paint / enamel the brass. Also I guess I would have similar challenges with brass. Michael - that looks good. The steel version (shim in a can) is quite a bit cheaper at around 20 quid with postage - 10 sheets at 6 x 10 inches - which is a LOT cheaper per square inch than eBay can provide. I think I will go with that, though it blows through the top of my already broached engineering budget for January. Don't tell the wife! Martin. Laser cutting is a good thought, but there doesn't seem to be anyone offering that near me. Also, it kind of feels like cheating ....
Thanks all. Iain
noel shelley | 16/01/2023 09:46:00 |
2308 forum posts 33 photos | Shim stock often comes coiled so flattening would be needed but is available in steel, brass or stainless in many thicknesses. It can be had in flat packs. Noel. |
Iain Downs | 16/01/2023 09:46:50 |
976 forum posts 805 photos | Ah forget that. I didn't do the postage correctly. they want 15 quid and I'm not paying that (brings the total cost up to £40). Sounds perfect otherwise Iain |
Iain Downs | 16/01/2023 09:47:30 |
976 forum posts 805 photos | Martin - I've got some left hand shears and some flat shears so I will try that on one my my remaining offcuts. Thanks
Iain |
Gary Wooding | 16/01/2023 10:15:48 |
1074 forum posts 290 photos | You can use a jeweller's piercing saw to cut shapes from very thin metal - 0.4mm steel is no problem. |
John Haine | 16/01/2023 10:34:40 |
5563 forum posts 322 photos | There was a recent thread about making shim washers that suggested making a stack of blanks and compressing them between end plates before turning the OD. I make suspension springs from beryllium copper shim, only 0.1mm. I find that it cuts easily using a paper guillotine (Aldi special a few years back) without warping. I've tried it also on thin steel and it's OK but probably even worse for blade wear! Also have used a method where the bit you want is clamped firmly in the jaws of my machine vice - faint scribed line showing where the cut is needed aligned with the top of the jaw. Then have a "shear" for which I used an old wood chisel, but better would be an old file with a straight sharp edge at say about 45 degrees ground on the end. Plave this against one end of the shim and tap to make the cut. Works very well with BeCu, a properly made "chisel" would be better for steel I think. My local suppliers, which stocks everything from plastic buckets through engineering fasteners to power tools, sells sheets of steel shim in various thicknesses over the counter, I'm not sure what the thickest is. Home laser cutters are a thing, they don't need to be too rigidly made like a router. I'm not sure if one could manage 0.5mm steel though, but they can do engraving as well. |
Bazyle | 16/01/2023 10:52:54 |
![]() 6956 forum posts 229 photos | Litho plates might be available from a small printing firm. Not sure of the thickness. |
John Haine | 16/01/2023 11:06:02 |
5563 forum posts 322 photos | I think litho plates are aluminium?
Iain Downs | 16/01/2023 11:34:50 |
976 forum posts 805 photos | Gary - I've ordered a piercing saw from cousins. being in my mind as a want for a while (and quite cheap). John - Joe Pie has an excellent video on pressure turning. Something I tried but with less success. I've learned a few things from that and hopefully my next attempt will creep towards quality! My local suppliers (Metals4U) are generally good but don't have anything thin enough. Iain |
Hopper | 16/01/2023 12:13:39 |
![]() 7881 forum posts 397 photos | If you search for Steel Shim Pack on eBay UK you will find you can buy 10 sheets of .020" for 3 Quid. Auto parts stores and bearing and engineering supply shops often sell packs of mixed steel shim that are usually flat, packed in a flat cardboard sleeve. Otherwise, are there not horological supply vendors online who specialise in this stuff? |
Michael Gilligan | 16/01/2023 13:19:05 |
![]() 23121 forum posts 1360 photos | Iain … Sorry, I have only just remembered : Dash along to your local HomeBargains store Last time I looked they had a ‘Jane Asher’ stainless steel cake-lifting sheet for some trivial price. MichaelG. |
not done it yet | 16/01/2023 13:46:56 |
7517 forum posts 20 photos | What is wrong with blueing brass? |
Iain Downs | 16/01/2023 15:58:12 |
976 forum posts 805 photos | Hopper as I read it you can buy one for £3.25 or a selection (of 10 different sizes) for 12 quid. Michael. Should I pass a HomeBargains, I will look in. Not Done It: for reasons which are probably poor (and or aesthetic) I wanted to heat blue the steel rather than chemically. I may also try a sample chemically (Steel blue compound) as one of a set of tests for how things look. I'm not great at understanding how something looks until I hold it finished.
Iain |
Michael Gilligan | 16/01/2023 18:32:16 |
![]() 23121 forum posts 1360 photos | Posted by Iain Downs on 16/01/2023 15:58:12:
. £2.99 MichaelG. |
