wayne ollerenshaw | 12/01/2023 18:08:47 |
40 forum posts 4 photos | Hi all Got a project here that needs a foot switch wiring to a single phase motor with a VFD. Usual cheap chinese one as below. Is this possible?
https://www.ebay.co.uk/itm/393329744803?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=fX8V16uPTo2&sssrc=2349624&ssuid=Wi78z-7jSx-&var=&widget_ver=artemis&media=COPY It will be a off/on/off switch. So put foot on switch then telease to stop the motor.
Thanks Faffer Edited By wayne ollerenshaw on 12/01/2023 18:11:14 |
Oldiron | 12/01/2023 18:51:54 |
1193 forum posts 59 photos | Cannot see a problem with that. It is no different than adding a remote pendant but just connecting the on off switch. Only downside I can see is that I dont think reverse will be possible just using the foot switch. regards |
Emgee | 12/01/2023 19:01:46 |
2610 forum posts 312 photos | Hi Wayne You will need to check in the electrical instructions to find if the start/stop paramaters provide 2 wire control for the simplest solution. Emgee |
old mart | 12/01/2023 19:55:24 |
4655 forum posts 304 photos | VFD's are usually started by momentary off to on or on to off switches. The common switches usually have the choice when you wire them, you will need to see if the foot pedal works like that. |
noel shelley | 12/01/2023 20:09:06 |
2308 forum posts 33 photos | single phase motor and VFD ? |
old mart | 12/01/2023 20:15:59 |
4655 forum posts 304 photos | I missed that, Noel, maybe a sewing machine pedal would work, no need for a VFD. |
Ian P | 12/01/2023 20:36:40 |
![]() 2747 forum posts 123 photos | Posted by old mart on 12/01/2023 19:55:24:
VFD's are usually started by momentary off to on or on to off switches. The common switches usually have the choice when you wire them, you will need to see if the foot pedal works like that. Many, or probably most, VFD's can be set up or programmed to work with momentary or latching switches. Ian P
wayne ollerenshaw | 12/01/2023 21:03:37 |
40 forum posts 4 photos | Posted by noel shelley on 12/01/2023 20:09:06:
single phase motor and VFD ? Yes I have a motor I want to alter rpm/Hz.
I do have instructions somewhere from.another VFD I fitted just can't find themamd don't want to go buying another incase I can't run the motor from a VFD with a foot switch. I was thinking on using a sewing machine pedal aswell .my last sewing machine only had two wires going to it. It was an old Reeds. I know the VFD can be set up for all sorts and dead.stoppong which I want aswell . Thanks for the help aswell
Andrew Johnston | 12/01/2023 22:21:54 |
![]() 7061 forum posts 719 photos | The point Noel was making is that some single phase motors have poor performance when run from a VFD, and many types of single phase motor simply won't work with a VFD. Ideally you need a shaded pole or permanent split capacitor motor. Andrew Edited By Andrew Johnston on 12/01/2023 22:22:11 |
Ian P | 12/01/2023 22:50:16 |
![]() 2747 forum posts 123 photos | Posted by Andrew Johnston on 12/01/2023 22:21:54:
The point Noel was making is that some single phase motors have poor performance when run from a VFD, and many types of single phase motor simply won't work with a VFD. Ideally you need a shaded pole or permanent split capacitor motor. Andrew Edited By Andrew Johnston on 12/01/2023 22:22:11 Ideally, you need a three phase motor with the VFD if you want a usefully wide range of speed control. Ian P |
wayne ollerenshaw | 13/01/2023 06:06:05 |
40 forum posts 4 photos | This is only a tester to see if what I am doing works so I can get a 3phase later if need be. This is the motor I am using now though. https://i.postimg.cc/MGbSsKmc/IMG-20221223-WA0000.jpg |
wayne ollerenshaw | 13/01/2023 06:08:18 |
40 forum posts 4 photos | https://i.postimg.cc/s2Rz9Z7d/20221223_113257.jpg |
wayne ollerenshaw | 13/01/2023 13:37:37 |
40 forum posts 4 photos | Ok just seen these forn the speed control. Which can .I think be easy wired.to foot.control.. This will.do away with a VFD which is more complex
The motor is 0.55kw so under the 4kw speed.controer.
How does that sound
https://www.ebay.co.uk/itm/394417395091?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v6hzlpy9s_a&sssrc=2349624&ssuid=Wi78z-7jSx-&var=&widget_ver=artemis&media=COPY Edited By wayne ollerenshaw on 13/01/2023 13:38:10 Edited By wayne ollerenshaw on 13/01/2023 13:46:11 |
Andrew Johnston | 13/01/2023 14:01:49 |
![]() 7061 forum posts 719 photos | Sigh, the unit is a thyristor phase angle voltage controller. It does not change frequency so will not change the speed of an induction motor. As an aside note that the 4kW rating is for a resistive load, which a motor certainly isn't. It would be much better to tell us what you want to achieve and then those forum members who understand the technology can advise on the best solution. Andrew |
Les Jones 1 | 13/01/2023 14:26:36 |
2292 forum posts 159 photos | Looking at the information in the advert for the VFD I can't decide if there are two different versions of the VFD or the same version can be used with either three phase or single phase motor. The picture with a singe phase motor seems to connect the main winding to one phase and the start winding to another phase. (I assume that the capacitor that is normally in series with the start winding is removed.) Can you post the manual for the VFD so we can see if any configuration settings need to be changed. Les. |
Clive Brown 1 | 13/01/2023 14:34:05 |
1050 forum posts 56 photos | If it's to be of much help,I hope that any VFD manual that might be provided is written in better English than the tortured text of the eBay listing. Edited By Clive Brown 1 on 13/01/2023 14:34:41 |
duncan webster | 13/01/2023 14:50:40 |
5307 forum posts 83 photos | I thought you weren't supposed to have a switch between a vfd and the motor, but a single phase motor often has a centrifugal switch on the start winding. If you bypass that, it will might overheat, as not continuously rated |
peak4 | 13/01/2023 15:14:33 |
![]() 2207 forum posts 210 photos | I'll stand to be corrected, as the later models might allow different facilities/programming. Edited By peak4 on 13/01/2023 15:16:51 |
Ian P | 13/01/2023 15:39:57 |
![]() 2747 forum posts 123 photos | Whilst I knew there were some variable speed inverter type controllers available, I understood the concensus was that they had limited speed control and were of dubious value. These AT2 inverters look to be an answer for some situations. Whilst I am perfectly happy to continue with VFDs with 3 phase output, curiosity got me looking for an online AT2 manual, but I've drawn a blank! Just watched a youtube video of an AT2 being unboxed, but the box did not seem to contain any documentation. Has anyone got an AT2 or a link to its user manual?
Ian P
wayne ollerenshaw | 13/01/2023 15:43:48 |
40 forum posts 4 photos | Posted by Andrew Johnston on 13/01/2023 14:01:49:
Sigh, the unit is a thyristor phase angle voltage controller. It does not change frequency so will not change the speed of an induction motor. As an aside note that the 4kW rating is for a resistive load, which a motor certainly isn't. It would be much better to tell us what you want to achieve and then those forum members who understand the technology can advise on the best solution. Andrew All I want to do is use the motor I have to run at lower speeds than the 1440rpm it is. Maybe as low as 500rpm. Also be used with a foot control pedal. If I can use a VFD, which one AT1 or AT2. Would be good to use the dead stop feature as I use on the o e on my lathe.
The project is to fit a thick wall tube inside an outer tube thay is fitted to the motor spindle to use a grinder to do the job to round off the edges. |
