Neil Wyatt | 22/12/2022 11:39:54 |
![]() 19226 forum posts 749 photos 86 articles | Great old reel showing some interesting maintenance work and heavy machining. And some other interesting stuff (cars if you rewind to the start). |
Dave Halford | 22/12/2022 17:03:58 |
2536 forum posts 24 photos | Still to be found in the wild on the Isle of Wight. |
john halfpenny | 22/12/2022 19:09:36 |
314 forum posts 28 photos | I don't think so Dave. Islandline is now re-engineered overground stock from Vivarail.
OldMetaller | 23/12/2022 06:53:51 |
![]() 208 forum posts 25 photos | What an amazing film, thanks Neil! I drove underground trains in the late '80's, a typical eight hour shift on the Met and Circle would involve 198 station stops, all of them 'service' stops, ie no tiptoeing in cautiously, all don't-brake-until-you-see-the-whites-of-their-eyes, balls-out stuff, the only way you could keep time! I went on to drive HST's on the 'big' railway, much less stressful! John. |
Hopper | 23/12/2022 07:07:38 |
![]() 7881 forum posts 397 photos | And not a pair of safety glasses in sight, even when hot drop forging! I guess you just squinted a lot in those days. And great shot of the fabulous old Art Deco buildings at East Finchley station at the very start, glassed-in circular stairways and all. They don't build them like that any more, sadly. |
martin perman | 23/12/2022 11:46:25 |
![]() 2095 forum posts 75 photos | Posted by john halfpenny on 22/12/2022 19:09:36:
Bedford to Milton Keynes has to Vivarail sets running but they have been taken out of service as Vivarail were maintaining them until this announcement Vivarail announces administration - Vivarail Martin P |
SillyOldDuffer | 23/12/2022 15:45:52 |
10668 forum posts 2415 photos | In the video that popped up next, An Overall Overhaul! (1934), they refurbish a London bus. I was much taken with the way the body was repainted. Yes, that chap is pouring paint straight from a watering can, no rose. Excess paint collected in the trough below and reused. Proof that all that fuss about master craftsmen applying primers and sanding down multiple coats in a clean room is a waste of time! Dave
Martin Cargill | 23/12/2022 16:53:40 |
203 forum posts | SOD. The company where I served my time painted transformers (the big ones at the end of your street) using flood painting. The transformer tank was hung from a crane over a large trough (about 15' square). The trough had a pump, connected to a hosepipe and the operator hosed a coat of paint over the previously shot blasted surface.
Martin |
Dave Halford | 23/12/2022 17:31:42 |
2536 forum posts 24 photos | Posted by john halfpenny on 22/12/2022 19:09:36:
Changed only two years ago by the look of it |
john halfpenny | 23/12/2022 19:34:08 |
314 forum posts 28 photos | Actually only this year(finally). |
Harry Wilkes | 24/12/2022 12:53:50 |
![]() 1613 forum posts 72 photos | Seeing those traction motors took me back to my days in the steel works changing the traction motors on one of the two material handling cars on the Blast Furnace was one of the worse jobs jn the steel work the top of the material handling car were level with the adjacent canal thus the rails on which the cars ran were level with the bottom of the canal and the canal wall leaked so always wet,wetter even more when it rained between the rails was a small inspection pit much like a concrete coffin without a lid so you got to squeeze into the water filled pit to disconnect the motor then struggle to get the rusty footbolts out drag the motor out and get to do it all in reverse H |
