look out for your boilers
Bazyle | 09/12/2022 17:43:21 |
![]() 6956 forum posts 229 photos | Our club sec at St Albans DMES sent round a timely (ok one day late) warning to make sure to drain down boilers, even little ones, that are in sheds and garages and even lofts.
JohnF | 09/12/2022 20:39:03 |
![]() 1243 forum posts 202 photos | Another item to consider is a pressure washer ! I know of two that were ruined by frost -- not mine ! John |
Ady1 | 10/12/2022 03:10:01 |
![]() 6137 forum posts 893 photos | Back in the 80s we had an apple split itself open in the car one year |
Speedy Builder5 | 10/12/2022 07:00:03 |
2878 forum posts 248 photos | Preferably run your engine on air to drain injector tubes, water feed pumps etc, and don't forget the hand pump and side tanks if you have them. |
David George 1 | 10/12/2022 08:30:30 |
![]() 2110 forum posts 565 photos | Watch the outlet for your boiler if you have a condensing boiler as if the condensate drain freezes the boiler can flood and cut out. NO HEAT. David |
Clive India | 10/12/2022 09:57:50 |
![]() 277 forum posts | I'm not draining anything - it's not a problem in England in a reasonably insulated workshop, even without heat. |
Nick Clarke 3 | 10/12/2022 19:30:53 |
![]() 1607 forum posts 69 photos | In an unheated engine shed pressure gauges are uncoupled to avoid the chance of water in the syphon expanding on freezing and causing damage |
peak4 | 10/12/2022 21:39:04 |
![]() 2207 forum posts 210 photos | I had my hot water hand wash heater burst/leak last year; think a smaller version of an electric shower. |
Mike Poole | 10/12/2022 22:23:31 |
![]() 3676 forum posts 82 photos | RAF Benson hit -9°C, about 4 miles from me. The frost has persisted all day in the shade. My wife is caning the heating. Mike |
