Peter Bell | 05/12/2022 13:25:06 |
399 forum posts 167 photos | Hello, From all accounts they are not regarded as feasible but just wondering if anyone has built (as an experiment perhaps) or bought a smallish wind turbine, vertical or otherwise? Iv'e looked at them over the years but never found anyone who had tried one and what the results were like in a typical UK rural location? Thanks Peter |
John Haine | 05/12/2022 14:00:17 |
5563 forum posts 322 photos | This might be if interest: **LINK** And many people use small wind generators on boats and maybe caravans too - https://www.marlec.co.uk/wind-power/boats-and-marine/ Edited By John Haine on 05/12/2022 14:01:41 |
Peter Bell | 05/12/2022 14:05:47 |
399 forum posts 167 photos | Thanks John, I've seen lots of articles like that over the years but it was more of the prctical experience and just wonderered if anyone had experimented with a smallerish one bought or otherwise? Peter |
Ady1 | 05/12/2022 14:56:28 |
![]() 6137 forum posts 893 photos | They need to be scaled up to be reasonably useful, size matters Local authorities don't like them (planning issues) Farmers can put them up with permission Yachts have used tiny ones for decades for small scale use, I've also seen a few for roadsigns in the country |
SillyOldDuffer | 05/12/2022 16:16:33 |
10668 forum posts 2415 photos | Posted by Ady1 on 05/12/2022 14:56:28:
They need to be scaled up to be reasonably useful, size matters ...Big is better because the amount of power obtainable is proportional to the square of the blade length. So if a 33cm blade has a goodness factor of 3419, then a 100cm blade is good for 31400, and a 1000cm blade gets 3140000. It's why commercial turbines have blades the size of a jumbo jet wing. The other secret is location. Well away from ground clutter, because the resulting turbulence severely reduces their efficiency. Large flat open plains, hilltops, and off-shore rather than backyard installations. A 30 metre tower wouldn't get me much in my sheltered inland location, whereas a turbine 100 metres on top of a nearby hill is almost always spinning. Dave |
Harry Wilkes | 05/12/2022 16:51:19 |
![]() 1613 forum posts 72 photos | On the route back home from my Daughters I pass a house with a wind generator in the back garden and I have to say I rarely see it turning H |
ega | 05/12/2022 17:12:34 |
2805 forum posts 219 photos | What happened to those wind sails rotating on a vertical axis and carrying adverts that one used to see on the pavement outside shops? The seemed to function even in light winds but looked potentially hazardous. |
duncan webster | 05/12/2022 18:44:01 |
5307 forum posts 83 photos | Big turbines also benefit from being a long way up off the ground. Boundary layer means that wind speed near the ground is lower. Here's some guff on vertical axis wind turbines. There are some close to the Pier Head Liverpool |
Bazyle | 05/12/2022 19:16:07 |
![]() 6956 forum posts 229 photos | You have probably already seen it but a search for 'Scoraig wind turbine' will find you Hugh Piggott the king of the DIY wind turbine. Unfortunately planning regulations are designed to make small turbines impossible in most locations. You need about 10ft span for 1Kw and above 12ft they become a bit unwieldy for an amateur. |
Michael Gilligan | 05/12/2022 19:25:21 |
![]() 23121 forum posts 1360 photos | On 29-November … it being a pleasant day after several rainy ones, and the car needing ‘the cobwebs blowing out’, I had a jolly to Llandudno for a few hours. The massive offshore wind-farm was clearly visible, but … to the best of my knowledge not one of the turbines turned blade whilst I was there. Emperor’s New Clothes ? … or just a rare day with no wind available ? I know not. MichaelG. . https://en.wikipedia.org/wiki/Gwynt_y_Môr Edited By Michael Gilligan on 05/12/2022 19:31:49 |
duncan webster | 05/12/2022 19:48:08 |
5307 forum posts 83 photos | According to gridwatch, wind is doing 10% right now, which is a lot more than it was doing last Monday. It must be windy somewhere in the UK |
peak4 | 05/12/2022 23:42:07 |
![]() 2207 forum posts 210 photos | Here's a bit of info from The Centre for Alternative Technology Edited By peak4 on 05/12/2022 23:42:27 |
not done it yet | 06/12/2022 06:41:11 |
7517 forum posts 20 photos | Posted by Peter Bell on 05/12/2022 13:25:06:
Hello, From all accounts they are not regarded as feasible but just wondering if anyone has built (as an experiment perhaps) or bought a smallish wind turbine, vertical or otherwise? Iv'e looked at them over the years but never found anyone who had tried one and what the results were like in a typical UK rural location? Thanks Peter Give us a clue as to what you mean by ‘smallish’. Chocolate teapots on house roofs are all expensive failures. Proven 2.5kW and 6kW were successful when situated in the right place. There are others, since Proven, as a company, disappeared. Maybe you need to describe your typical rural location, too? |
Michael Gilligan | 06/12/2022 07:10:33 |
![]() 23121 forum posts 1360 photos | Posted by peak4 on 05/12/2022 23:42:07:
Here's a bit of info from The Centre for Alternative Technology . Must pay them a visit … probably next Springtime Haven’t been since the early days: **LINK** https://cat.org.uk/visiting/plan-your-visit/history-of-cat/ MichaelG. |
Peter Bell | 06/12/2022 08:02:59 |
399 forum posts 167 photos | Thanks for all the replies. I've been to the CAT a few times over the years and always found it interesting and inspiring even in the times before climate change became a recognised issue. I also got the literature from Hugh Scoraig a few years ago which convinced me they needed a steady supply of wind to generate anything useful and it was a no go for me. What I see is a lot of interest around small vertical axis machines, which are not so effiecient, on Utube and the like and also lots of 500w+ verticalaxis amchines on Ebay and just wondered if any of the MEW crew had tried one or even knew of one which worked hence my original post, Thanks once again Peter |
Frances IoM | 06/12/2022 09:08:30 |
1395 forum posts 30 photos | Michael's visit to the Great Orme was on a flat calm day in the Irish sea (Peel bay was like a mill pond) - two days prior wind had been generating 40% of UK power - all it proves is that alternative sources are needed (on that winter day solar around midday was generating twice the power of wind) it was also a day in which coal powered station was active. |
Michael Gilligan | 06/12/2022 09:20:19 |
![]() 23121 forum posts 1360 photos | Posted by Frances IoM on 06/12/2022 09:08:30:
Michael's visit to the Great Orme was on a flat calm day in the Irish sea (Peel bay was like a mill pond) - […]
- all it proves is that alternative sources are needed […]
. Thanks Frances MichaelG. |
