Martin Dilly 2 | 17/11/2022 21:52:35 |
50 forum posts 7 photos | I'm not even sure what the offending item is actually called. However, it is a washer about 10 thou thick and 14mm in diameter, with four tabs on the inner edge that are sprung upwards and engage in a groove on a shaft about 6mm diameter so as to lock it to a large metal disk. It's actually part of a cafetierre and has a stripped thread. The intention is to make a new part and replace it, preferably using the same lock washer. So far I've tried sliding dressmaker's pins under the tabs in the hope that this will force them apart enough to free the washer. The first pin works fine but later ones will only go below the washer rather than above it when they emerge from the other tabs, as the washer is distorted by the first pin. |
Michael Gilligan | 17/11/2022 22:03:01 |
![]() 23121 forum posts 1360 photos | You will be very lucky if you manage to re-use that washer … they are, as you have no-doubt already realised, designed to go on, and stay on. I would concentrate on getting it off, whilst causing minimal damage to the other components. MichaelG. . It may be a special, but in principle it’s like these: https://www.springmasters.com/push-on-fasteners/ Edited By Michael Gilligan on 17/11/2022 22:04:59 |
Clive Foster | 17/11/2022 22:06:53 |
3630 forum posts 128 photos | I believe the official generic name for these never to be sufficiently cursed things is "spire - nut". I have shifted the big ones using a teeny pair of pliers to bend the tabs back one at a time to clear the groove and packing the washer up just enough, in line with the tab, to stop it springing back down. Once over the groove it could be walked off but the shaft wasn't pretty afterwards. Creative swearing was involved! Things got re-engineered on assembly. The smaller ones on 3 - 4 mm or imperial equivalent shafts can be brute force twisted off using a screwdriver underneath but that doesn't work on the bigger ones. With reference to Michaels link the multiple tab push on style can be inverted by careful levering so the clip can be worked off. Sometimes the quicklocks can be inverted too, most likely if on a plain shaft rather than in a groove. Right size starlock on right size shaft with groove are there for life. Clive Edited By Clive Foster on 17/11/2022 22:13:27 |
Huub | 17/11/2022 22:14:11 |
220 forum posts 20 photos | That "washer" isn't meant to be taken out. The outer top ring is probably pressed in. Maybe an inner bearing puller could pull it out. It looks like a "Star Lock Washer".
Edited By Huub on 17/11/2022 22:14:35 |
Martin Dilly 2 | 17/11/2022 22:38:47 |
50 forum posts 7 photos | Many thanks gentlemen. Is there a speed record for replies I wonder? I'll hold fire for a while in case someone with magic powers comes up with a solution but I can see my next step will be trying to buy a single StarLock push on fastener after butchering the current one, and being told there's a £25 minimum order (+postage and packing...). |
mgnbuk | 17/11/2022 23:03:16 |
1394 forum posts 103 photos | Star lock washers are available singley on Ebay from £1.25 Other sizes than the one I selected to get a link are available from drop-down menus on the page linked to. Nigel B. |
Martin Dilly 2 | 17/11/2022 23:36:50 |
50 forum posts 7 photos | Thanks, mgnbuk. I'd done a bit of sleuthing too and found the same site, so my normal cynicism for once was unfounded. |
Jeff Dayman | 17/11/2022 23:58:49 |
2356 forum posts 47 photos | These items are called "external shaft retainer clips / washers / rings" - just mentioning it for your part search. +1 on cutting the old one with a Dremel grinding wheel or similar. If you try pick or lever tools usually so much damage is done to the adjacent parts or the shaft that even with a new ring the repair isn't good. Cutting gets them off with no trauma to adjacent bits. A link to a major US based suppliers' range for info only is below. https://www.mcmaster.com/shaft-retainers/retaining-ring-type~external/push-on-external-retaining-rings-6/ Edited By Jeff Dayman on 17/11/2022 23:59:53 Edited By Jeff Dayman on 18/11/2022 00:00:13 |
Hopper | 18/11/2022 01:13:37 |
![]() 7881 forum posts 397 photos | Can you wrap a piece of thin brass shim around the shaft and slide it down to the star washer then pry one leaf of the star open at a time and slide the shim in then slide the whole lot off as one? |
Howard Lewis | 18/11/2022 08:19:01 |
7227 forum posts 21 photos | These washers are intended as an easy to fit, non reuseable item. Almost always, removal requires it to be damaged beyond reuse, plus damage to the shaft Cut with a dremel, and replace (see below ) would be my choice. In UK, one brand is "Salterfix", but no doubt, places like Machine Mart, Toolstation, or Screwfix will sell you a box containing about 100 in different sizes! In the past, faced with this, where possible, I have drilled the shaft and fitted a washer retained by a split pin. That old fashioned arrangement allows disassembly and reassembly without problems. Howard |
Samsaranda | 18/11/2022 10:00:36 |
![]() 1688 forum posts 16 photos | You say the washer is part of a cafetierre, is this part immersed in the coffee, if so is probably made out of some form of stainless so replacement should be a likewise material. Not sure how ordinary steel or zinc plated steel would hold up in that environment, probably not good to dissolve zinc coating into your coffee although according to doom merchants coffee is rated as toxic anyway. Dave W |
Circlip | 18/11/2022 10:22:26 |
1723 forum posts | If the shaft has a groove to retain the spire clip it must be a luxury item. Circlips saved threads, spire fix saved having a groove. Regards Ian. |
bernard towers | 18/11/2022 10:25:43 |
1221 forum posts 161 photos | The last one I had to remove the outside edges were lifted up so the washer was effectively reversed then prised off.Oh and replaced with a thin washer and circlip Edited By bernard towers on 18/11/2022 10:26:33 |
Martin Dilly 2 | 18/11/2022 10:28:11 |
50 forum posts 7 photos | Circlip, it's a pretty basic cafetierre, but the shaft is grooved, which rules out Hopper's cunning plan. I'm away for a while now but it sounds like a bit of light Dremelling will do the trick when I'm home again. |
Martin Dilly 2 | 18/11/2022 12:30:32 |
50 forum posts 7 photos | Samsaranda, yes it's immersed in the coffee but I have in mind to make the replacement from brass. Those small conical pots used to make real Turkish coffee are brass; it's strong stuff and it doesn't seem to kill many of the Turks. |
old mart | 18/11/2022 14:01:22 |
4655 forum posts 304 photos | We have a box of Starlock washers at the museum, a range of sizes, but they are spring steel zinc plated, you need stainless steel. You would need four custom made spikes to try to get the ears to move outwards as they are pressing into the end of the shaft. A difficult task, a lot of luck required as well as skill. |
David Jupp | 18/11/2022 14:07:51 |
978 forum posts 26 photos | If planning to make a new part anyway, consider drilling or turning the part away to release the washer. |
larry phelan 1 | 18/11/2022 16:05:05 |
1346 forum posts 15 photos | We used to refer to them as "Marriage Clips ", there till death do us part !, no second rounds ! |
iNf | 18/11/2022 16:40:18 |
58 forum posts 46 photos | This website might have what you need. I've bought from them in the past. Dave |
old mart | 18/11/2022 17:14:28 |
4655 forum posts 304 photos | Stainless steel starlock washers are available on ebay, by searching for "stainless starlock washers", the size will be the shaft diameter. |
