Mike Freeman | 11/11/2022 13:17:53 |
5 forum posts | Hi I am a complete novice in terms of machining and am coming from a 3D printing & 3D design background. I'd like to learn some machining skills and have been looking at lathes with a view to building some steam engine kits and eventually getting into steam loco building. I don't have a large budget and was looking at old Myfords on ebay but then started looking at the Chinese offerings and found the Sieg SC3 on Arceuro. I have no issue with Chinese machines and know from 3D printing that you can get some capable machines and the fettling and upgrading is all part of the fun. I don't however want to buy a machine that just isn't capable of doing what I want or have to buy twice so my question is, would the Sieg SC3 be capable of machining things like the Stuart models engine kits and then also be able to do the machining required for something like a 5" loco? Regards
Mike |
Martin Kyte | 11/11/2022 13:57:25 |
![]() 3445 forum posts 62 photos | You need to identify the largest component on the loco or Stuart engine which generally is the driving wheels or flywheel. If you can swing that it the large you are looking good to go. You need to be able to bore cylinders either on the faceplate or boring table (cross slide in Myford terms). |
Nicholas Farr | 11/11/2022 14:13:35 |
![]() 3988 forum posts 1799 photos | Hi Mike, welcome to the forum. As Martin has said, you need to know the biggest diameter of the engine you wish to build is, for instance, some loco wheels in 5" can be 7-1/2" or bigger diameter castings, which you won't be able to do on a C3, and depending on any lathe such wheels being either loco or flywheels, you will need to make sure you can get the tool close enough to do the work, this may mean you will have to clear the lathe saddle as well as the bed, and the cross slide will also need to be able to be retracted out far enough. Regards Nick. Edited By Nicholas Farr on 11/11/2022 14:17:23 |
Mike Freeman | 11/11/2022 14:38:10 |
5 forum posts | Thanks for the replies.
I'm currently trying to decide on a loco to eventually build but it will be something suitable for a beginner. I was thinking of a small tank loco such as the Boxhill or Simplex which both have 4 3/8 wheels. Other than the size of the parts would this machine be man enough to do the job?
Clive Brown 1 | 11/11/2022 15:02:12 |
1050 forum posts 56 photos | Hi Mike, welcome. The SC3 will machine almost all of the Stuart engine range, and also most 5" locos, the exceptions being designs based on large, main line prototypes and, say, single wheelers such as the Stirling. I'd go for the longer lathe bed length as the 300mm version sounds a bit short to me for comfortable working. An issue that I'd see with the small, far-eastern offering is the fairly high bottom speed, over 100rpm in many cases. This is on the high side for machining large diameter castings although the Simplex isn't too bad at 4.375". My Boxford has a low speed of <40 rpm and that can be useful. Be aware that any 5" loco is a major undertaking in terms of cash and perseverance, don't under-estimate this. Another essential will be a basic milling capability, these days usually by a milling machine, but a vertical slide for the lathe will suffice. I've built a Simplex using one. Best of luck. |
Nick Clarke 3 | 11/11/2022 15:06:36 |
![]() 1607 forum posts 69 photos | I bought the sc3 a few years ago and can recommend it as a first lathe. The only drawback is supposed to be power at low speed as it has no back gear - but it has never proved to be a problem for me. Basically I felt the advantages of buying new with a guarantee far outweighed the suggestion to buy a second hand unknown quantity that I would not only not know if was any good and would not know how to rectify if it wasn't. The only issue with asking this question is that there are people like me who own a mini lathe (although I have used many different types over the years) and those who have bought second hand lathes - not many of us do both. |
Nick Clarke 3 | 11/11/2022 15:10:07 |
![]() 1607 forum posts 69 photos | As you are intending to build a loco are you going to join a club with a track to run it on? If so many clubs have workshops where jobs too large to do at home could be machined. Possibly an indication of your location (but definitely NOT your address) might bring forward some club suggestions Edited By Nick Clarke 3 on 11/11/2022 15:10:42 |
not done it yet | 11/11/2022 15:24:05 |
7517 forum posts 20 photos | Good myfords (and some, err, less good ones) seem to fetch high prices. I have neither a myford, nor a chinese lathe. The attraction of a new lathe, for a beginner, might well outweigh the urge to buy second hand. Arceuro are a respected supplier and are well-recommended on the forum. I’ve never bought a main machine from them, but most of my other requirements are sourced from there. |
SillyOldDuffer | 11/11/2022 15:46:12 |
10668 forum posts 2415 photos | All lathes have pros and cons. The SC3 is a mini-lathe like the one I started with, except mine had a fancy digital controller with an RPM display and a slightly more powerful brushed motor. However, RPM is only mildly useful and cheap point and shoot meters are easily had online. Also, the latest SC3 as sold by Arc has a brushless motor, efficient, no brushes or commutator to wear out, and markedly better slow speed torque. Physically the machine is what the American's call a 7x12 lathe, meaning it can turn a maximum of 7" in diameter, and 12" in length. Both figures are optimistic, requiring the operator to jump through hoops as the maximum capacity is approached. For that reason, unless specifically doing small work, beginners are advised to buy the biggest lathe they can manage. It's because big lathes can do small work at a pinch, whilst small lathes are useless when the job won't fit. The diameter of the hole in the spindle is 20mm, which can be a problem turning long rods or pipes. On the face of it a 7" (180mm) lathe should hold most of what's needed for a 5" gauge but I'm not a loco builder. I guesstimate the biggest part to be the driving wheels, about 100mm in diameter. These could be turned in a chuck with a stub-mandrel, or bolted to the faceplate. Which loco is it? Someone who has built one will know what the largest part is. Mini-lathes don't take up much space, are quiet, and a one man lift provided you're in good health. (Too heavy for this retired office worker now!) Disadvantages:
I learned a lot from my mini-lathe and only swapped up because it turned out to be too small for about 20% of what I wanted to do. Next step up hobby lathes also fix most of the disadvantages listed above. An SC4 is usefully bigger, and a WM250 bigger yet again. I run a WM280 which is rather bigger than a Myford 7, and the biggest machine I had space for! Three other cutting machines are also extremely useful:
Dave Edited By SillyOldDuffer on 11/11/2022 15:46:31 Edited By SillyOldDuffer on 11/11/2022 15:47:39 |
Nigel Graham 2 | 11/11/2022 16:06:06 |
3293 forum posts 112 photos | Nick - Re retracting the cross-slide enough for large diameters (wheels). I've sometimes overcome that problem by using a left-hand tool mounted to project "sideways" from the outer side of the top-slide. Rather than the conventional pointing inwards set-up. Nevertheless the biggest lathe you can sensibly manage to buy and install is the real answer! |
Buffer | 11/11/2022 16:13:49 |
430 forum posts 171 photos | It would be worth buying the book a beginners guide to model loco building by Tim coles. He explains all this stuff for you. |
Nicholas Farr | 11/11/2022 16:24:26 |
![]() 3988 forum posts 1799 photos | Hi Nigel, I have done similar on my Boxford, but it's not always the best idea and at times when the diameter is on absolute maximum, there is more overhang than I wish for, as the saddle won't go close enough, so you have to be aware that your cuts can't be too heavy, and if you have a larger diameter in front of where you need to machine, it makes even more overhang as the tool post itself maybe in the way. Not something a beginner needs to try doing. Regards Nick.
JasonB | 11/11/2022 16:27:43 |
![]() 25215 forum posts 3105 photos 1 articles | SC3 is a 7 x 16 not 7x12 Just use carbide tools and you won't have to worry about needing a slow speed for larger diameters. In fact using a higher speed than the lowest setting is an advantage in getting more performance out of the motor. SC3 can be run backwards without fear of the chuck unscrewing so no need for a LH boring bar, just mount a standard RH one upside down and hold in the side of the toolpost closest to you. Likewise if you screwcut away from the chuck you don't need a slow speed to allow for reaction time |
HOWARDT | 11/11/2022 17:28:12 |
1081 forum posts 39 photos | I have an SC3 and have most of the frame, cylinders and all wheels, in other words the working elements of both a 5” Super Simplex and 3 1/2” 9f made and roughly assembled. All parts were turned and milled from solid bar, no castings. A little ingenuity is needed at times but most of the 9f milling was done on an SX2. Yes the SC2 does have its limits but one of the things I did was use the mill as a vertical lathe to turn the rims of some of the wheels, more out of curiosity than need. |
Bazyle | 11/11/2022 17:42:54 |
![]() 6956 forum posts 229 photos | Just looked at the prices. I'd go for the Myford on the for sale links on the right of this page although I'm not normally a fan of them and know little about the post war ones. However I believe that Keith Wilson who wrote extensively in ME years ago and also made locos professionally used one even for 7 1/4 in Kings. |
Mike Freeman | 11/11/2022 17:59:53 |
5 forum posts | Thanks for all the replies, some great advice here. I would rather buy a new machine if possible. I just don't know enough about it to check what I'm buying and whether it's set up and working properly. I live in Ashford Kent so will join one of the local clubs at some point. There is one in Romney Marsh and also Canterbury. The main aim really is to learn machining skills. Ending up with a loco will be a bonus as I've always been interested in railways but there is no rush to get it built. The whole thing is a learning exercise as much as anything.
Hollowpoint | 11/11/2022 20:38:58 |
550 forum posts 77 photos | I'm not a big fan of the Chinese mini lathes. If it was my money I'd be looking for a good Myford ML10. |
Howard Lewis | 11/11/2022 21:01:53 |
7227 forum posts 21 photos | As a beginner in machining, may I caution you to learn your trade BEFORE machining expensive parts for a loco. Better to make your mistakes, and learn from them, on a piece of relatively cheap mild steel, rather than a costly casting. It may better to,learn the basics by starting with High Speed Steel tooling. Find a local Model Engineering Society and join. You will be among like mined inviduals, who can advise, guide and SHOW you how to do things. Buy one or more books; there is quite a list. Dave Clark, David Fenner and Neil Wyatt have all written books on the mini lathe. Stan Bray, Harold Hall and L H Sparey have all written books on lathe work,in more general terms Any one of these will provide useful information and advice.(Which will answer a question almost before you have formed it, and solve a lot of puzzles ) Do buy a set of Zeus Charts. I till regularly use the one bought bin 1958! Where are you located? There may well be one nearby. You can learn how the various clearance angles affect the way in which a tool cuts. (Carbide will cut harder materials, but moulded tips are not as sharp as well ground HSS tools. Ground tips are good, but don't take kindly to being banged. As a beginner, you will have collisions, in all probability, One of the mistakes that we all have made, even if we won't admit to them! HSS will stand a lot of abuse. Basic projects enable you to learn, gain experience, and confidence, and a tool which can be used for years to come. My suggestion for a first, would be a Centre Height Gauge. making this will give experience of Facing, possibly straightforward turning, Drilling, using a Tap and a Die. Once made and set tools can easily be set to Centre Height, so that they cut properly. (If not at Centre Height, they won't, and will leave a pip around the real centre point of the work ). If you want to, you can make one or more Tap Wrenches, or a sliding Tailstock Die Holder, maybe even a sliding Tailstock Tap Holder (A protege is making these currently!) HTH Howard |
SillyOldDuffer | 11/11/2022 22:17:46 |
10668 forum posts 2415 photos | Posted by Hollowpoint on 11/11/2022 20:38:58:
I'm not a big fan of the Chinese mini lathes. If it was my money I'd be looking for a good Myford ML10. Tread carefully though. Because many overvalue the brand in my opinion, prices tend to be high, even if the machines are worn or damaged. ML10s used to be a good buy, but prices have shot up even though they're distinctly inferior to other Myfords. Perhaps I'm jaded because second-hand lathes are rare where I live whilst everyone else is surrounded by bargain machine tools in tip top condition! For me it was much safer and considerably less fuss to buy a mini-lathe. Didn't regret it. Dave
Robert Atkinson 2 | 11/11/2022 22:53:52 |
![]() 1891 forum posts 37 photos | Speaking as a Myford owner and a ARC Eurotrade customer (mill and tooling), I suggest you purchase the SC3. It will do most of what you want, their service is excellent and If you do decide to get something bigger later it won't have lost much value unless you abuse it. Remove some variables, don't learn about outdated systems (single phase motors that need a clutch for example) Get the SC3-300 HiTorq Robert G8RPI. |
