Differential Screws
I am probably being dim …
Michael Gilligan29/10/2022 21:46:27
23121 forum posts
1360 photos
I am aware of how ‘differential screw’ adjusters usually work [screw threads with different pitches, working in tandem] … But these have me stumped:
https://www.ebay.co.uk/itm/254633999168
Could some kind soul please post a rough sketch to explain how left and right hand threads of the same pitch can provide differential adjustment ?
… My brain hurts !
John Haine29/10/2022 22:02:23
5563 forum posts
322 photos
I don't think they are the same pitch.
Michael Gilligan29/10/2022 22:07:15
23121 forum posts
1360 photos
Posted by John Haine on 29/10/2022 22:02:23:
I do, John … that’s why it’s puzzling me
M8x1mm
Left-hand one end, Right-hand t’other
Credit Tony4Cats
Edited By Michael Gilligan on 29/10/2022 22:10:50
bernard towers29/10/2022 22:27:32
1221 forum posts
161 photos
How does that make them differential?
Michael Gilligan29/10/2022 22:29:19
23121 forum posts
1360 photos
Posted by bernard towers on 29/10/2022 22:27:32:
That was my question ^^^
They are listed as such crying 2
Neil A29/10/2022 22:34:23
160 forum posts
They are not really what I would call a "differential screw adjuster". As you say, they usually have threads of different pitches and are the same hand to make fine adjustments.
These are just like the threads in the middle of a pair of spring bow compasses, or track rods on a car. As you wind the screw the "nuts' on each end are either pulled together or pushed apart. An adjusting screw, but not differential. Perhaps the description sounds more technical for an advertisement than simply calling it a left and right handed adjusting screw!
Michael Gilligan29/10/2022 22:47:08
23121 forum posts
1360 photos
In the absence of any explanation … I think you must be right, Neil
I asked the question because I was beginning to doubt myself
… Looks like I might be O.K. after all smiley
Trouble is … He also lists these: https://www.ebay.co.uk/itm/313125445600
… which make far more sense.
Edited By Michael Gilligan on 29/10/2022 22:49:36
Bazyle29/10/2022 23:00:57
6956 forum posts
229 photos
Get over it. He just did a cut and paste job on the description without thinking much about it. If you look at his sales count he is a garage trader shovelling out the stuff by the wagon load so isn't going to put a measurable amount of QA checking on his sales pitch.
Ady129/10/2022 23:42:33
6137 forum posts
893 photos
At sea we called them bottle screws but turnbuckle or tensioner screw is probbly a better description
Mark Easingwood29/10/2022 23:46:52
53 forum posts
16 photos
I don't know about their use in engineering tooling, but, the ones in your first picture are used in spindle moulder tooling, (wood machining), along with an olive, (cone shaped nut), to hold the wedge, which locks the knives into the block.
It is not very obvious how they are used from the links below, I can takeyou a picture on Monday if you want.
Screw
Olive
Mark.
Mark Easingwood30/10/2022 00:08:50
53 forum posts
16 photos
David Davies 830/10/2022 05:20:48
202 forum posts
Good morning.
We use them at work to hold a carbide insert into the toolpost of a scarfing machine on a continuous ERW tube mill.
I recently bought some spare ones for the machine and Sandvik do indeed list them under the name 'differential screw'
I assume that this is the literal translation to English from the makers mother tongue.
Cheers
Michael Gilligan30/10/2022 06:31:31
23121 forum posts
1360 photos
Well, Gentlemen :
… aside from Bazyle’s rather stroppy “Get over it.” … I’m grateful for the input.
P.S. “Garage Trader” he may be … but he lists some very useful stuff
DC31k30/10/2022 07:34:31
1186 forum posts
11 photos
Posted by Michael Gilligan on 29/10/2022 22:29:19:
In some sense, they _are_ differential because the rate at which the screw advances (2mm) is different to either of the pitches cut on each end.
If you have assimilated a definition of a differential screw _requires_ it to have different pitches at each end, clearly they do not fall within that.
The eBay listing is confusing as it remarks on the fine adjustment ability of a differential screw, a property which is only true if you adopt the latter definition.
If the diameter is fixed at 8mm, and the application needs 2mm advance, the other option is a 2-start thread, but maybe that is more expensive to produce than the Pushmi-Pullyu.
DC31k30/10/2022 08:25:30
1186 forum posts
11 photos
Thinking about it some more, if we wanted to write a generalised mathematical expression for a differential screw, we would need two inputs for each end of it: the pitch of the thread and the hand of the thread.
If we agree a convention that the pitch of a RH thread is a positive number, we can represent a LH thread in our expression with a negative number.
The fine adjustment mechanism has the same hand at each end and different pitches. We subtract the two pitches and take the absolute value of the result to calculate the differential movement.
That formula works for a length of threaded rod: same hand and same pitch - do the subtraction and you arrive at a differential movement of zero as expected.
For the eBay one, the hand is different but the pitch is the same. Do the same subtraction, but remembering our LH thread is represented as negative, and we arrive at a differential movement of 2mm in this case.
Let us say we have a 1mm RH pitch one end and a 1.25mm pitch LH at the other end. The differential in that case would be 2.25mm. If you happened to need this movement for something, it is hard to buy a tap or die as it is a non-standard pitch. Because of this, it might not feature in the gearbox of a screwcutting lathe.
Edited By DC31k on 30/10/2022 08:28:11
Michael Horner30/10/2022 08:48:03
229 forum posts
63 photos
Hi Michael,
From Wikipedia:- (in case of a single lead equal to the thread pitch), and possibly opposite handedness, on which two nuts move. As the spindle rotates, the space between the nuts changes based on the difference between the threads.
This is not the full description, but the word "possibly" may mean not everybody agrees it's differential.
If they are not left and right hand threads I don't see how it could be differential.
My head hurts all the time now!
Cheers Michael.
Hopper30/10/2022 09:15:21
7881 forum posts
397 photos
The left/right handed combination screws are sometimes called compound screws and other times clamping screws too.
The Free Dictionary defines a Compound Screw thusly:
Compound screw
Also found in: Encyclopedia.
(Mech.) a screw having on the same axis two or more screws with different pitch (a differential screw), or running in different directions (a right and left screw).
See also: Compound
Webster's Revised Unabridged Dictionary, published 1913 by G. & C. Merriam Co.
So it seems both differential and right-and-left screws are types of compound screw. But on the shop floor the blokes using the screws to retain the carbide inserts probably don't give a toss and just refer to them generally as differential screws and get on with the job. Well, the thread on each end is different from the other, in handedness. That's differential enough for practical purposes.
Michael Gilligan30/10/2022 09:27:05
23121 forum posts
1360 photos
Good to see this discussion developing yes
I will just mention Norris … who deserves the credit for my first introduction [decades ago] to differential screws:
https://www.leevalley.com/en-us/discover/revisiting-the-past-the-lee-valley-antique-tool-collection/featured-patent-norris-plane
Howard Lewis30/10/2022 10:07:13
7227 forum posts
21 photos
If these screwed studs have the same pitch, and the same hand at each end, rotating the stud, between two fixed members, will merely move the stud between the fixed members, without changing any dimension
If the stud is stationary, and one end member is rotated there will be a a change of overall dimension.i
This what happens with a cylinder head stud on an engine, although it not unknown for threads of different pitches to be used, such as BSW into the cylinder block and BSF for the outer end,.
If the end threads are of different pitch, but the same hand, there will be a fine adjustment, because the advance at one end will differ from that at the other. The coarse fixed end reduces the risk of stripping the fixed thread, while the finer outer thread allows a clamping load to be applied with greater accuracy.
If the threads are right hand at one end and left hand at the other, and the stud is rotated, the device will act like a turnbuckle, either drawing the fixed members together, or pushing them apart..
In the case of a turnbuckle, the end studs remain stationary and the central member rotates to produce the adjustment.
To produce a differential adjustment, the threads have to be different, either in pitch or hand, (As shown in the picture ).
Michael Gilligan30/10/2022 10:19:47
23121 forum posts
1360 photos
Posted by Howard Lewis on 30/10/2022 10:07:13:
[my emboldening] … Which is very clearly the case in the example under discussion
It was the leap from ‘turnbuckle’ to ‘differential screw’ which troubled me enough to ask the question.
I shall be very interested to see the detail that Mark has kindly offered to post tomorrow
… largely because the ‘Olive’ that he linked only served to confuse me further.
https://www.whitehill-tools.com/spares-accessories/screws-olives/470S00070/
Edited By Michael Gilligan on 30/10/2022 10:21:31
