Aluminium sheet coatings
Speedy Builder5 | 15/10/2022 06:44:59 |
2878 forum posts 248 photos | Some time ago, I was given a Good Housekeeping aluminium baking tray - never been used as it was too big for the domestic staff. I had a project in mind for it and cut and folded it etc. I needed to epoxy glue some divisions onto it - but the glue would not bond. Cleaned the joint area with alcohol and re-glued the joints. Still no joy and then I assumed that the hard anodised finish was in fact some sort of non-stick finish which certainly worked ! Moral of this text - not all material is what it seems!! Bob |
David George 1 | 15/10/2022 07:36:39 |
![]() 2110 forum posts 565 photos | I used to make aluminium mould parts for making plastic gas pipe fittings and they were hard anodized and PTFE coated to prevent wear as they were pulled from the plastic part after moulding. David |
John Rutzen | 15/10/2022 09:11:33 |
411 forum posts 22 photos | I bought some hard anodized aluminium sheet and tried to spray paint it with etch primer for aluminium, the paint just fell off! You have to sandpaper it with fairly coarse stuff to get a key. Another piece of bare aluminium was ok. |
not done it yet | 15/10/2022 09:33:06 |
7517 forum posts 20 photos | SB5, If those dividers were aluminium the ‘alutite’ (on sale at the exhibition) might be an ideal method of attachment.? I replenished my stock on Thursday, so that I don’t have to be so stingy in choosing to use it, for a while.🙂 |
Grindstone Cowboy | 15/10/2022 11:00:29 |
1160 forum posts 73 photos | I believe most modern baking trays do come with a non-stick PTFE coating. Rob |
roy entwistle | 15/10/2022 11:12:59 |
1716 forum posts | How do they stick the non-stick coating on? |
larry phelan 1 | 15/10/2022 12:00:24 |
1346 forum posts 15 photos | How do they get the figs into the fig rolls ??? |
Grindstone Cowboy | 15/10/2022 12:13:40 |
1160 forum posts 73 photos | And how do they do those pork pies with an egg in the middle and in every slice the egg is the same size? (I know the answer, but it might spark discussion Rob |
Baz | 15/10/2022 12:42:13 |
1033 forum posts 2 photos | Posted by Grindstone Cowboy on 15/10/2022 12:13:40:
And how do they do those pork pies with an egg in the middle and in every slice the egg is the same size? (I know the answer, but it might spark discussion Rob Specially bred chickens that lay continuous eggs? |
pgk pgk | 15/10/2022 15:14:29 |
2661 forum posts 294 photos | Instead of allowing them in the henhouse you get them to lay by the yard. Note: you can boil eggs in a kettle but you can't pour them out. |
duncan webster | 15/10/2022 15:27:59 |
5307 forum posts 83 photos | Pressed the wrong button Edited By duncan webster on 15/10/2022 15:28:28 |
Baz | 16/10/2022 13:41:24 |
1033 forum posts 2 photos | Grindstone Cowboy, I had to take her indoors shopping yesterday and we visited a Marks and Spencer’s food hall, I made a point of looking at their slices of pork pie with egg in the middle and they were using proper eggs, one slice of pie was an end piece and the other a middle bit with yolk. Being a rather sad person I checked all the packs on display and they were the same, obviously Marks and Spencer need to be informed of the continuous egg process, come on, spill the beans! |
Grindstone Cowboy | 16/10/2022 14:06:00 |
1160 forum posts 73 photos | Well, I read an explanation of it in a Reader's Digest "How Do They Do That?" type book many years ago, and it involved various metal tubes and rods (but luckily for the chickens AFTER their input has ended). Firstly, the whites are cooked in a tube with a central rod, forming an egg white cylinder, then the rod is extracted and raw yolk inserted and cooked. So you have, effectively, a very long egg which can be cooked into the pie. Full marks to M&S (no pun intended) for not going fully industrial. Why don't chocolate chips in chocolate chip cookies melt when they are being baked? Rob |
Peter Greene | 16/10/2022 19:26:04 |
865 forum posts 12 photos | Posted by larry phelan 1 on 15/10/2022 12:00:24:
How did they get the tube-trains down the escalators? (they took them down in pieces and reassembled them). |
mark costello 1 | 16/10/2022 21:31:34 |
![]() 800 forum posts 16 photos | They are tough chips, They can take the heat? |
