3/8/M10
Steve35517/09/2022 16:02:01
321 forum posts
235 photos
Hi
Very simple and quick question…
The engineering suppliers in the UK do not realise that home machining is about as imperial as Jacob Rees-Mogg.
I want to buy a shell mill. ALL of the MT2 arbors I can find for sale have an M10 thread. My DW mill has a 3/8” drawbar and will not accept a M10 drawbar. I have read that they are so close as to be interchangeable. Is this correct, or is it a no-no for some reason?
(i.e. can I screw an M10 arbor onto a 3/8” drawbar?)
thanks
Steve
Edited By Steve355 on 17/09/2022 16:05:38
noel shelley17/09/2022 16:17:57
2308 forum posts
33 photos
3/8" is 9.5mm so you are looking for 20thou. If you havn't got that to spare it's a tight hole. I have an imperial Centec 2B, I can get a 10mm drawbar in ! I used 10mm threaded rod, cheap, comes by the 1m. remember it is only to stop the arbor/ cutter falling out DO NOT DO IT VERY TIGHT ! Noel. Good Luck
JasonB17/09/2022 16:36:49
If it's an insert shell mill you are looking at then it's more than likely to be 16, 22 or 27mm bore so the metric arbors these fit come with metric drawbar threads, If you find a 3/8W drawbar one it is more than likely to be 5/8 or 7/8 so won't be much use anyway
As M10 is reasonably coarse and the MT taper will do the griping consider making a drawbar from 3/8 round bar with an M10 thread cut on the end
Edited By JasonB on 17/09/2022 16:37:10
Roderick Jenkins17/09/2022 16:37:14
2376 forum posts
800 photos
A 3/8" BSW will go about 4 threads into an M10 hole which is probably enough but I have run a 3/8" BSW tap into my M10 tooling and that then works fine with a 3/8" draw bar. As Noel says, a loose fit in the thread is OK for nipping up a 2MT.
Rod
Howard Lewis17/09/2022 17:14:00
7227 forum posts
21 photos
I have converted M12 tappings in blank arbors to 3/8 BSW by Loctiting in a piece of M12 studding and then drill and tap to 3/8 BSW.
M10 (0.393" )is 8.5 mm ( 0.3362) Tapping size (Core dia 8.159 mm 0.321" ) 1.5 mm (p 0.059" ) pitch
3/8 BSW is 0.3125" Tapping Size, (Core diameter 0.295" ) 16 tpi (0.06252 ) pitch
The sizes and pitches seem all a little too close for plugging and retapping to be feasible.
My method would be to make up a drawbar with a M10 thread on the end, if that will pass through the spindle.
old mart17/09/2022 17:49:13
4655 forum posts
304 photos
Try a length of 10mm studding down the spindle, it may fit without any modifications. When I converted the Tom Senior light vertical from MT2 to R8 it was easier to retain the top half of the spindle which had fine splines than to make one. The bore was intended for 3/8" Whitworth drawbars. I managed to get a 7/16" reamer through after silver soldering an extension to it. That is 11.11mm diameter.
John Haine17/09/2022 20:54:17
5563 forum posts
322 photos
Loctite in a short bit of M10 studding, drill and tap M6 and use M6 studding for drawbar. For MT tapers you don't need a strong pull, M6 plenty strong enough.
Bob Unitt 118/09/2022 10:29:55
323 forum posts
35 photos
Posted by Howard Lewis on 17/09/2022 17:14:00:
I can confirm that plugging and tapping won't work, having tried it myself. I made up an extra drawbar for the other thread in the end.
old mart19/09/2022 15:19:43
4655 forum posts
304 photos
It would help if the exact bore size of the spindle was posted.
John Reese24/09/2022 06:06:49
1071 forum posts
The Chinese vendors on eBay offer shell mill adapters wth either metric or Imperial threads.
John Rutzen24/09/2022 08:14:12
411 forum posts
22 photos
I have two drawbars for my Amadeal mill. The milling R8 arbor is M10, the drill chuck and boring head are 3/8th BSW. I don't find it a problem, I just use the appropriate one.
not done it yet24/09/2022 12:00:21
7517 forum posts
20 photos
Posted by old mart on 19/09/2022 15:19:43:
More than 9.5mm and less than 10mm. I might just ream it to accept a 10mm thread.
TPI and pitch are different for those two threads? They are not compatible.
Andrew Moyes 124/09/2022 13:14:02
158 forum posts
22 photos
I have a DW mk1 mill that I made from the kit circa 1980. The spindle blank was supplied pre-drilled through at 11/32" for a 5/16" drawbar. Neither 3/8" nor M10 will fit. The tail of the spindle is 5/8" diameter with two opposed keyways cut into it 3/32" deep. There isn't enough metal left to drill it out for the larger drawbars. The OP might have the mk2 version of course and that might have a larger spindle - I can't help if so.
old mart24/09/2022 18:57:57
4655 forum posts
304 photos
If you can ream to 9.8mm and then use a length of 10mm studding with a long nut loctited to the top you would be good to go.
