Michael Callaghan | 17/09/2022 13:54:17 |
173 forum posts 7 photos | Hi, my old garage wooden doors are rotted out and need replacement. I have been looking at electric roller doors and have a few questions. I know that carador are good quality and they are only down the road from me. But nearly £4000 for a single door is a bit much. I have seen doors for sale on eBay and Facebook, but think that these are of Chinese origin and any warranty would be worthless if called on. So can anyone point me in the direction of a good quality insulated door for a single garage which they had fitted and they are happy with. Thanks. |
Bezzer | 17/09/2022 15:02:35 |
203 forum posts 16 photos | There's Lymers up the road in Leek Link . They did our sectional door a couple of years ago but we decided not to motorise it. They were competitive at the time and no complaints about quality or the fitters.They do all styles/types and motorise if required.
Oops I read Michael Gilligan not Michael Callaghan sorry if you're not this way Edited By Bezzer on 17/09/2022 15:03:45 Edited By Bezzer on 17/09/2022 15:06:12 |
Dave Halford | 17/09/2022 15:04:28 |
2536 forum posts 24 photos | Consider one with an external override lock if you have no internal access from the house. Big panels are better. I have had a Teckentrup (Cartech) door for years, Yale lock hidden behind the makers name plate. Needs an 8ft clear run I had to attack a brick pillar with the chisel to get clearance.never had any trouble. Fitted myself |
Mark Rea | 17/09/2022 15:06:03 |
32 forum posts 7 photos | Hi. I have a double door from Rollerdoor fitted. A bit cheaper than garadoor I think but it was fitted when I bought the house. Three years I have lived here and I am happy with it. I would imagine most parts are made in china whoever is selling them nowadays. |
SteveW | 17/09/2022 16:06:05 |
![]() 140 forum posts 11 photos | I’ve had a roller door from Access doors for about 10 years. Very space saving and insulates making it ok to work in with 20 minutes of a fan fire. I found Access ok to deal with and the installation is neat. I just had to provide a 13a socket. SteveW |
Clive Brown 1 | 17/09/2022 16:50:16 |
1050 forum posts 56 photos | My electric roller door was fitted in 2017 by a local firm. Cost £1395. A 13 amp socket was already to hand. Works fine, no problems as yet. |
Bizibilder | 17/09/2022 17:04:40 |
![]() 173 forum posts 8 photos | Had a single garage roller door fitted by a local firm for £780 all done - back in 2018. Your quote for 4K seems rather excessive!! |
Peter Cook 6 | 17/09/2022 17:34:38 |
462 forum posts 113 photos | One thing to watch - assuming you are going to put a car in the garage - is the width of the mechanism at the side. I have considered replacing my old up and overs with rollers, but the side mechanisms takes more space than I can afford if I still want to get the car in. |
peak4 | 17/09/2022 21:30:19 |
![]() 2207 forum posts 210 photos | When we had the new garage built, I ordered the door from Garage Doors Online. Edited By peak4 on 17/09/2022 21:41:47 |
Dave Halford | 17/09/2022 23:38:06 |
2536 forum posts 24 photos | Posted by Peter Cook 6 on 17/09/2022 17:34:38:
One thing to watch - assuming you are going to put a car in the garage - is the width of the mechanism at the side. I have considered replacing my old up and overs with rollers, but the side mechanisms takes more space than I can afford if I still want to get the car in. You need a panel door like myself and Peak they go inside the door opening so you get full door width and when it opens everything is above door height. |
geoff walker 1 | 18/09/2022 05:59:19 |
521 forum posts 217 photos | Hi Micheal, Had a double Premier door fitted last year by rollerdor of Norwich. Extremely happy with it. Rollerdor do a nationwide service which of course includes a no obligation survey. Check out their website, Rollerdor, one o in door. Geoff |
Robert Holton | 18/09/2022 10:19:07 |
40 forum posts | My partners mother had a single elactic roller door fitted by a local chap one year ago. It cost her £2000 . It is a brilliant piece of work. Very reliable. I am impressed with it. She lives in Priorslee Telford.
Peter Cook 6 | 18/09/2022 10:38:31 |
462 forum posts 113 photos | Posted by Dave Halford on 17/09/2022 23:38:06:
That would work for width, but then I would loose the 10 inch thickness of the brick pillars in the overall length, and with a 2020 SUV and a 1970's integral garage I only have about four inches spare in length. The only real answer is a smaller car!!
Edited By Peter Cook 6 on 18/09/2022 10:39:34 |
Martin Johnson 1 | 18/09/2022 13:01:57 |
320 forum posts 1 photos | We have a double width door by Steel Line, installed by a local chappie. Good kit and they do an insulated option. The insulated ones are panels, which usually slide up and along runners at ceiling height - kiss goodbye to any suspended storage of timber etc. Also lighting battens might need shifting. Peak4's photo shows the problem. Also beware of draughts around the head of the door. That can make a mockery of "insulation" and lets a lot of dust in if you are thinking of painting anything. I installed a Gliderol motor as a Diy job. Simple enough, but I needed some scaffold tower to take the weight of the door while one end bracket is removed and the motor slid along the pivot tube. The motor will require a bit more width in the door rebate. The door runners also take about 3 inches off the opening width - something to check with your supplier. Have also had a couple of issues with the motor that needed the scaffold to sort them out. HTH Martin |
Anthony Knights | 18/09/2022 16:27:09 |
681 forum posts 260 photos | When my "UP-and-OVER" door mechanism failed I did a really cheap repair. Works for me! |
Michael Callaghan | 18/09/2022 18:35:23 |
173 forum posts 7 photos | Thanks chaps. The £4000 is for a carador with all the bells and whistles. You need to get it fitted or they will not honour the warranty. I agree it’s an awful lot of money for a garage door. Apart from carador who I know use all English made items, I think that the rest use Chinese bits and bobs to max out profits. Due to having an office build into the Centre section of the garage roof which means I can’t fit an up and over which would work out a lot cheaper for sure. I have asked a number of National firms for quotes in the coming week, so will take it from there. Thanks |
Nigel McBurney 1 | 18/09/2022 19:24:51 |
![]() 1101 forum posts 3 photos | Several years ago I went for a electrically operated Horman door,just over 6 metres,very good door.Its made from hinged panel,insulation is an option ,watch out for the cheap ones,a neighbour has one that is just one sheet with lots of folded creases which rolls onto a drum,dont know how long it will last. When you are older the electric door allows you to drive up to the door ,you open it with remote control drive in park the car ,walk to the house and then close it by remote. I built my garage away from the house, safer regarding fire risk etc. |
Clive India | 19/09/2022 09:39:53 |
![]() 277 forum posts | Roller doors - advantages - quite well insulated and good draught-proofing My experience as follows. Two singles fitted 5 years ago. The tubular motors do run hot and are in a small cavity, but do not operate for long periods so seem to be OK for most - just not wonderful. Edited By Clive India on 19/09/2022 09:41:48 |
Martin Johnson 1 | 19/09/2022 12:58:48 |
320 forum posts 1 photos | ",a neighbour has one that is just one sheet with lots of folded creases which rolls onto a drum,dont know how long it will last." Mine is thin gauge corrugated steel as described. Ours has put in 17 years so far. By the way, it faces south west straight down the Drumochter pass, so we only get an occasional slight brèeze. NOT! Martin |
